Digital Art Zone
Symbol on a Supersuit
Posted: 02 June 2012 11:08 AM   [ Ignore ]
New Member
Joined  2011-05-24
For more simple textures, I’ve previously figured out how to pull up the texture files and make minor alterations as desired, but the supersuit appears to be something quite different.  I’m making a superhero, and would like to put a symbol on his chest… but I have no idea how to even start to do so.
How would I go about doing so?
Thank you for the assistance.
Profile
Posted: 02 June 2012 12:38 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Although the Supersuit is designed to use shaders it is still uv mapped, so you should be able to add a symbol in the usual way
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 02 June 2012 12:55 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2011-05-24
Perhaps I’ve not been doing it in the usual way, then.  Normally, I select the surface texture map, open it in photoshop, make modifications I desire, and apply the new surface texture map.  I’m not seeing that as an option here.  Is there a different way I’m unaware of?
Profile
Posted: 02 June 2012 01:20 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2009-03-17
Although there is no default textures for the Supersuit as it is shader driven you can download the texture template at this link - http://www.sharecg.com/v/62282/view/21/DAZ-Studio/Supersuit-Templates.
Using the template as a guide you can then create a custom texture with symbol.
It is also possible to add a symbol using shader mixer and alpha maps if you wish to use the shaders but this is a rather advanced method and would require you to know your way around shader mixer.
 Signature
My life is a symphony nearing a crescendo. There have been too many segues in this piece and I long for a caesura.
Profile
Posted: 03 June 2012 08:39 AM   [ Ignore ]   [ # 4 ]
New Member
Joined  2009-04-22
In the preview thread for the suit a Daz staffer (DAZ_Rand?) created symbols by applying the texture to Genesis and using a displacement map to pus it through the suit.
Profile
Posted: 03 June 2012 04:20 PM   [ Ignore ]   [ # 5 ]
New Member
Joined  2011-05-24
Thank you for your help!
Profile
Posted: 03 June 2012 06:16 PM   [ Ignore ]   [ # 6 ]
New Member
Joined  2011-05-24
I’m still lost—I’ve downloaded the template and created the texture I want—but I can’t seem to apply the texture to the supersuit.  Whenever I try, it just repeats a smaller copy of the texture several times, instead of applying the texture as intended.  I must be missing something obvious.
Profile
Posted: 03 June 2012 07:43 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
gavindowning - 03 June 2012 06:16 PM
See if tiling is set on the Surfaces tab.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 03 June 2012 07:47 PM   [ Ignore ]   [ # 8 ]
New Member
Joined  2011-05-24
That did it!  Thank you so much!
Profile
