Digital Art Zone
Furify Question
Posted: 24 November 2012 06:33 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2009-08-08
Okay. I’ve modified a garment model by adding a couple of matt zones so I can turn part of it off. The result looks rather like a collar, and I thought that a fur collar might look rather spiffy. However, the “collar” is, in fact, the inside of the garment, so the fur is on the underside rather than the top.
It’s only one layer of “fabric”, and with anything else any applied surface shows on both sides. But not with the fur shaders. Is there any way that this can be adjusted so the fur shows up on the outside? Just making the displace setting negative doesn’t do it.
Profile
Posted: 24 November 2012 11:35 PM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  2006-03-02
Can you try reversing the normals on that material zone? If you have Hex you can do it there; I’m not sure if you can do it inside of Studio.
Profile
Posted: 25 November 2012 01:12 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2009-08-08
Not sure I want to do that. I won’t always want that garment to have a fur collar.
Profile
Posted: 25 November 2012 11:28 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2005-12-31
Try reversing the positive and negative settings on (I am guessing) displacement.
Profile
Posted: 26 November 2012 01:23 AM   [ Ignore ]   [ # 4 ]
Power Member
RankRankRank
Joined  2005-09-05
Khory - 25 November 2012 11:28 AM
That could work…if I understand correctly the fur is going inwards instead of out.
Just change the displacement settings to negative and that should be a start then look at whether you need to increase the depth of the displacement.
Edited to add you may need to change the directional settings also…not sure and my computer is currently being fixed so can’t check. I’m not sure if Marieh renamed the point brick it could be listed as direction or point.
 Signature
Shadermixer tutorials and recipes
My Website
My ShareCG Gallery
Shadermixer Documents
Profile
Posted: 26 November 2012 01:32 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2009-08-08
Well, I did change the displacement setting to negative and it didn’t do anything relevant (the matt zone was suddenly in wireframe when rendered with the fur still going down instead of up). I’ll check and see if there are any other settings that I can reverse.
Profile
Posted: 26 November 2012 01:49 AM   [ Ignore ]   [ # 6 ]
Power Member
RankRankRank
Joined  2005-09-05
JOdel - 26 November 2012 01:32 AM
Can you post an image? Unfortunately I won’t get my computer back until the end of the week…if I can see what is happening I might be able to suggest something more useful.
One question is the area you are using where the modeller has turned the mesh under to add depth to the garment? That the only reason I can think for it going inwards like you have described.
 Signature
My Website
My ShareCG Gallery
Profile
Posted: 26 November 2012 12:07 PM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2009-08-08
It isn’t going inwards. Where the fur is is the outside of the garment. But that part of the garment folds over, so in that area I want the fur on the inside.
I’ll do a render, give me a few minutes…
Profile
Posted: 26 November 2012 12:53 PM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2009-08-08
Okay. I see that the problem is a bit more complex than I’d anticipated. I’m probably not going to be able to give the garment a fur collar at all. I’m probably going to have to get rid of the whole collar area and make a new matt zone and give it a fur edge.
For that matter, I’m going to have to do that for the whole garment anyway. There is an “edge” matt zone, which wraps around the edges of the garment, and when that is given a fur shader, the fur pokes through from the inside. Doing an adjoining zone on the outside of the garment will probably take care of that, but there doesn’t seem to be any way to give it a collar that will take the shader properly. Brocade collar, sure. Leather collar, sure. But not fur.
The first of these is with the shader simply applied to the area. The second is the shader applied with the displacement made negative. I can’t show the weird little grid that appears in the render because it needs to be too high resolution to be able to see it as anything more than an odd set of floating pixels.
Image Attachments
Profile
