Digital Art Zone
Maybe a silly question but as im new here he goes…
Posted: 24 November 2012 02:08 PM   [ Ignore ]
New Member
Joined  2012-02-21
How do we make a separate object like in image if we wish to make it only that part? Thxs
Image Attachments
Profile
Posted: 24 November 2012 02:21 PM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  0
Trialg - 24 November 2012 02:08 PM
Select the parts that you want.
Choose Edit/Copy.
Go back to the Assemble room and insert a new Vertex object.
Edit/Paste the copied object into the vertex modeler window.
 Signature
-Dean
Profile
Posted: 24 November 2012 02:21 PM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI Trialg
Welcome smile
There’s no silly questions,. just simple answers smile
With the item selected, go to Edit /Copy.
Jump back into the scene,.. Assembly room.
Go to Insert, Vertex object,. and once you’re in there,. Edit / Paste.
The object you copied will be pasted into the same position as it was when you copied it.
but it’s now a completely separate model.
Another method is to use the option in the Assembly room to Edit / Split object,. which will take a multi poly-mesh object and create an object from each separate poly-mesh.
this isn’t always the most ideal solution if you want to just work one one part of a model in the vertex modeller, you can select and Hide the parts you don’t want to work on, and then make them visible again, when you’re done.
Hope that makes sense smile
Profile
Posted: 24 November 2012 03:24 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2004-11-07
I have an even simpler answer http://www.daz3d.com/products/hexagon/hexagon-what-is-hexagon
cool smile
 Signature
Profile
Posted: 24 November 2012 03:43 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  2012-02-21
Thanks Desan and 3Dage lol Manstan I know that answer smile but i cant hold so many crashes it turns my mind crazy even I like a lot Hexagon smile
Profile
