Digital Art Zone
4 of 5
4
Computer Specs
Posted: 13 December 2012 09:27 PM   [ Ignore ]   [ # 46 ]
Member
Avatar
Rank
Joined  2006-09-05
Hi Korvan and Prixat. I used Prixat suggestions. These are the settings I used for the render. Original size same as Korvat’s. Picture reduced to 90%. Rendertime: Bucket size 16 = 4min-32 secs.
Rendertime using Bucketsize 64= 4min-54 secs.
Best Quality (ie, 4)
Default Shader
Pixels = 1680 x 1050
Bucket size = 16
Max Ray Trace Depth = 3
Pixel Samples (x) = 4
Pixel Samples (y) = 4
Shadow Samples = 8
(I generally don’t use a large bucketsize, usually only 2 or 4.)
Image Attachments
Profile
Posted: 13 December 2012 10:43 PM   [ Ignore ]   [ # 47 ]
Member
Avatar
Rank
Joined  2006-09-05
And another thing: Corel Painter X, Photoshop 5.5 and other apps which ran fine on Vista 32 bit 4GB-RAM, do not run on Windows7 64 bit 16 GB-Ram. So I am having a BIG problem here. I know I can remove 8 GB RAM, but what is the point of doing that?!!
Profile
Posted: 14 December 2012 01:38 AM   [ Ignore ]   [ # 48 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
Frodi:
PainterX and W7 64bit more than 8GB RAM
http://painterfactory.com/forums/p/2534/13647.aspx#13647
 Signature
I like Bryce, DazStudio, Poser and Vue ... in alphabetical order. And I would probably like Carrara too, if I could find the time to become acquainted with it. Peace?
Profile
Posted: 14 December 2012 07:38 PM   [ Ignore ]   [ # 49 ]
Member
Avatar
Rank
Joined  2006-09-05
Thanks Kerya, I do have that fix. It worked great for a very old Corel Painter Classic, which had a message “out of memory”. But the fix for Corel Painter X does not work on this machine. Mind you, I like that old little program much better than the later versions. It just is so strange that Painter X is not supported, I paid enough for it! I have not updated it, as Corel is so expensive, even for an update.
Profile
Posted: 15 December 2012 02:53 AM   [ Ignore ]   [ # 50 ]
Member
Avatar
Rank
Joined  2004-04-07
Making a 32bit program check the system for an 8GB limit is a very peculiar thing for Corel to do.
...but as a long time CorelDraw user I’ve come to expect that sort of thing from Corel!
“xpmode” might be an answer, though it comes with such a low spec. graphics emulation, I doubt it qualifies for Painter’s minimum requirements..
 Signature
regards
prixat
Profile
Posted: 15 December 2012 04:40 PM   [ Ignore ]   [ # 51 ]
Member
Avatar
Rank
Joined  2006-09-05
Hi prixat, xpmode does not work at all! It is there, but not available. I have used Painter X for about 8yrs, I have the boxed version. I am not about to buy a later product as Painter X suited me very well. The very oddest thing is that Painter Classic is very old, I got it in 1998. It was out of memory at one stage, but Geert de Peuter’s marvellous intercept dll. fixed that. I thought I would have lost that and tried to use Geert’s solution for 64bit machines. Strangely that was not accepted after using the cmd. However, after the failure of X, I just hit the Application Mode of Classic and up came a window telling me to use the intercept dll. So I stuck the intercept dll. in again and HEY PRESTO, it worked. Corel knows about the problem, I have seen that on the forum. They sent a message saying they were working on it, that was YEARS ago, and still no working solution. I am not going to recommend Corel to anyone again, I’ll tell them to use another well-known product.
Profile
Posted: 15 December 2012 09:43 PM   [ Ignore ]   [ # 52 ]
Member
Avatar
Rank
Joined  2006-09-05
Just found where one can find the Windows program where Painter X worked ok. In my case Vista Home Premium. I selected the one with the correct updates. Got a nice little window telling me that Painter X was ready to be installed and guess what: it didn’t work. What a joke.
Profile
Posted: 16 December 2012 01:32 AM   [ Ignore ]   [ # 53 ]
Member
Avatar
Rank
Joined  2011-07-07
aaron1716 - 12 December 2012 05:25 PM
Processor: Intel Core i5 3570K 3.4GHz
Chipset: Gigabyte GA-Z77X-UD3H Socket 1155
Memory: 16GB DDR3 1600Mhz Ram
SSD; 120GB
HDD: 1TB
Graphics: EVGA GTX 670 FTW 2048MB GDDR5
Operating System: Microsoft Windows 7 64Bit
Get an i7 CPU since they are multi-threaded.  DAZ apparently has not tested D|S with anything more powerful than an i7 (4 cores/8 threads), but I can say from experience that the more threads you have, the better your performance will be.  i5 CPU = 4 cores / 4 threads).
The newer Xeon CPUs have 8 cores / 16 threads.  I was interested in finding how fast D|S renders would be with one of those, but so far, nobody has submitted any data on if D|S can use all 16 threads.
 Signature
Reality is perception.
Profile
Posted: 16 December 2012 02:12 AM   [ Ignore ]   [ # 54 ]
Member
Avatar
Rank
Joined  2011-07-07
frodi - 13 December 2012 09:27 PM
Default Shader
Bucket size = 16
Shadow Samples = 8
I re-rendered my baseline using your specs.
Bucket size 16 = 7 min 6 sec
Your render took 272 seconds
My render took 426 seconds
So your render was done in 64% of the time it took mine to process.  Considering your CPU has 2 more cores and 4 more threads, that would indicate a 33% faster render time assuming the same core/thread efficiency and same clock speed.  Since you have more efficient cores, and perhaps a bit faster clock, the 36% faster render time makes sense.
Now we have a definitive answer, D|S supports at least 12 threads!
 Signature
Profile
Posted: 16 December 2012 02:55 AM   [ Ignore ]   [ # 55 ]
Member
Avatar
Rank
Joined  2011-07-07
Well, it seems I have also placed an order for a new computer. But not the one I had intended to get.
Chatting with the wife, she persuaded me to get a mobile graphics workstation.  I should get it in about 8 days.
The system will have:
Intel Mobile Core i7-3840QM 2.80 GHz (up to 3.80 ) 4 Cores /8 Threads
8GB DDR3-1600
4GB GDDR5 NVIDIA GTX 675MX 256-bit GPU/VRAM Clock 600MHz/1800MHz
Seagate Momentus 750GB 7200rpm SATA 3Gb/s 16MB cache
17.3-inch 1920x1080 Non-Glare LCD
According to the CPU performance charts, the i7 3930K scores 12060 @ 3.5GHz.
The i7 3840 scores 8839 @ 2.8GHZ.  Overclocking it to 3.4GHz would result in a score of 10773.
My current i7, overclocked to 3.5GHz, scores 6661.
I know I can OC the CPU to 3.4GHz without an issue so it will give me a good performance boost compared to current system.  Won’t be quite as fast as the i7 3730K, but it will be a portable computer which is what I will need if I am going to do the work I plan on doing.  Based on the baseline renders, my current system took 7 min 6 secs.  Frodi’s render took 4 min 32 secs.  I would estimate that the new laptop should do the baseline render in 5 minutes 5 seconds.
The graphics card in the notebook will certainly do OpenGL renders fast, so spot renders will be a breeze!
The sad part is that I probably won’t have D|S installed until AFTER the new year.  Well, D|S, Maya, 3ds Max, Sculptris, 123D, Sketchup, Autocad, Adobe CS 6, and a few other graphic design programs and utilities also need to be installed.  Might put World of Warcraft on it too, if I have room!
We should keep this thread going, so other people will have a good idea of relative performance levels of computers.
 Signature
Profile
Posted: 16 December 2012 04:30 PM   [ Ignore ]   [ # 56 ]
Member
Avatar
Rank
Joined  2006-09-05
Looks a nice setup Korvis, I never thought of a laptop! I have a lappie for business stuff only, so that I cannot mess anything really important up.
Profile
Posted: 21 December 2012 02:02 AM   [ Ignore ]   [ # 57 ]
Member
Avatar
Rank
Joined  2011-07-07
Well, the notebook is now setup.
Did the test render with your settings and it took 4 minutes and 45 seconds.
Not as fast as your rig, but still a whack faster than my desktop.  Also, was unable to overclock the notebook, so it is running at 2.8Ghz.
Dang manufacturer locked the BIOS settings.
Drat!  LOL.
Now, if the BIOS were unlocked .... mwhahahahahaha!  World domination would be mine!  OK, maybe not.
 Signature
Profile
Posted: 21 December 2012 02:53 PM   [ Ignore ]   [ # 58 ]
New Member
Avatar
Joined  2011-10-03
frodi - 24 November 2012 05:17 PM
Thanks for all that input guys, yes I can stretch to i7 and 16GB. The 8GB was chosen as I read somewhere that my 32bit apps would not work on 64 bit with 16GB. I looked at an SSD drive, but don’t know how to use it.
What do you think of Processor:  Intel Core i7 3770K 3.5GHz
                      Chipset:    Intel P8Z77-M
                      SSD:        60GB SSD
And should I upsize the cooling to: 2x 120mm Red LED Fans, 1x 200mm Red Led Fan? Any suggestions?
Or is that overdoing it?
As this thread is almost a month old, this maybe a moot point.  But will share my methodology.
CPU:  Always buy the best you can afford. Not a component you want to change frequently.  Intel Core i7 3770K 3.5GHz, great choice has built-in HD4000 GPU, so if your budget is tight you can hold off on a Graphics Card. Then save for a killer graphics card.
Motherboard: Asus P8Z77-V several models do a compare on the ASUS site for features. Again not something you want to change frequently. The V on the model means built in video. It allow you to use the HD4000 GPU, and one of the features LucidLogix Virtu allows the hardware to manage the GPU and Graphics card, it you can use both.
Power Supply: You will see power supplies listed a Bronze, Silver and Gold. Go Gold, and buy a bit more than you need.  Talk to staff at a shop you trust, and buy with your future needs in mind. High-End Graphics cards draw a lot of power, so more is better.
CASE: Again something you really don’t want to change.  I recommend the Thernaltake Level 10 GT (I have the Snow Edition). If size is an issue, go with the Level 10 GTS.  Best thing about these is easy to change drives without opening the case, and FILTERS. Lots of Filters, keeps the inside dust free.  My Level 10 GT keeps things dust free and cool.
MEMORY:  The Asus P8Z77-V can handle 4 x DIMM, Max. 32GB, DDR3 2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
Here is the trick, Windows 7 PRO can handle upto 192GB, while Win7 Premium can only handle 16GB. The thing to consider is the speed, pick the fastest memory you can afford that is for one of the O.C. speeds.  I run 2133 and did test, big difference over running at 1600.  As to amount, well I will say 16GB for sure.  If you find a good deal on 32GB and have Win7 Pro, or Win8 then go for it.  But if it comes down to $$, speed first.
As to Fans, get the Level 10 GT case and you’ll never have to worry about fans or dust.
Now SSD.  Many ways to use one.  There is Intel Smart Response that uses a 64GB SSD as a cache for your primary HD.  Or you can use an SSD for your boot drive.  Then carefully configure to remap your user files to a large 2nd drive. ie Documents, Music, Pictures, Video would be on drive D:. Instructions can be found online somewhere.  I would go with this option, get a BIG 2nd drive, put Windows on the SSD (they are expensive so a 128 or 256), then immediately re-map the user path to D:. Then only Windows and software will be on C:.
Now Video Card.  Depends on you budget.  If you take the above advice, then you have very good built-in video from the on i7 HD4000 GPU. If you planned correctly in choosing a Power Supply you could put off buying a Video Card until you can save for a higher end one.  I have an i7-2700k with HD3000 graphics, and it does me fine. Had it since Feb’11.  Will be watching sales after Xmas for video cards.  When I say save, you could get a good mid-range GeFore GTX 660 for $230-$340 (local prices) depending on memory/speed. While higher end cards like GeForce GTX 690 can run over $1000.  If you can live with the on CPU HD4000 graphics, you could save for that higher end Video Card. One of the few part you can defer, so you finish with the best.
Profile
Posted: 21 December 2012 04:17 PM   [ Ignore ]   [ # 59 ]
Member
Avatar
Rank
Joined  2006-09-05
This is what I ended up with Panther:
OS Windows:              7 Home Premium 64 bit
CPU:                        3.20 gigahertz Intel Core i7-3930K
Motherboard Board:        ASUS P9X79 PRO Rev 1.xx
Memory:                    16.0 GB
Graphics Card:              NVIDIA GeForce GTX 680 2GB
Sound Card:                NVIDIA High Definition Audio
Monitor:                    CMO CMC 22 W
Case:                        Coolermaster HAF XM Case with Window
Cooling:                    Coolermaster Hyper 212 EVO CPU Cooler
Hard Drives:                ATA SanDisk SDSSDX12 SCSI Disk Device (120.03 GB)
                            ATA ST2000DM001-1CH1 SCSI Disk Device (2000.40 GB)
Profile
Posted: 05 January 2013 10:48 AM   [ Ignore ]   [ # 60 ]
Member
Avatar
Rank
Joined  2004-04-07
My time with the test scene on an AMD X6 1055t, win7-64, 8GB is 11m 34s.
...taking out the uberenvironment (occlusion and directional shadows) and using point cloud occlusion about 2m 40s
switching to ray traced shadows and full GI with Uberenvironment about 47 minutes cheese
...taking out the uberenvironment and using point cloud occlusion about 7m 40s
 Signature
regards
prixat
Profile
4 of 5
4
