Digital Art Zone
Skin texture problem
Posted: 22 November 2012 03:33 PM   [ Ignore ]
Member
Rank
Joined  2012-08-19
Hello I attached the problem I have.
It’s a clear spot and I can not remove it. Appeared after making a smoth on that part in zbrush. Appears with all skin textures.
Anyone had a similar problem or Does know why this happens??
I use Poser Pro 2012 and the figure is V4
Thanks
Image Attachments
Profile
Posted: 22 November 2012 04:00 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI smile
this looks like a raised deformation caused by a brush stroke, ..as you say you’ve used Z-brush to edit the model..
Q: Does this deformation appear in Z-brush ? ..or only in Poser
Image Attachments
Profile
Posted: 22 November 2012 04:04 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2012-08-19
3DAGE - 22 November 2012 04:00 PM
HI smile
Only appears in Poser. But the problem is that isn’t elevation, is smooth.
Image Attachments
Profile
Posted: 22 November 2012 04:33 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2012-08-31
Is it an elevation on the bump map?
Profile
Posted: 22 November 2012 08:23 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2012-08-19
ghastlycomic - 22 November 2012 04:33 PM
It isn’t seen as an elevation, as seen in the second image is smooth but light affect it as if it is elevation…
Profile
Posted: 23 November 2012 06:33 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2012-08-31
rickfoxxx7 - 22 November 2012 08:23 PM
That’s why I thought it would be on the bump map, since the bump map doesn’t alter the physical geometry like the displacement map does, it just paints the lighting on the texture map.
Profile
Posted: 23 November 2012 08:37 AM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2012-08-19
ghastlycomic - 23 November 2012 06:33 AM
Is there any solution?
Profile
Posted: 23 November 2012 10:39 AM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi smile
The first place to look is the texture maps you’ve exported from Z-brush.
see if that appears on any of them.
I agree that the BUMP channel is the likeliest , since Bump is a lighting effect,. not a mesh deformation.
Hope it helps smile
Profile
Posted: 23 November 2012 11:58 AM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2012-08-19
3DAGE - 23 November 2012 10:39 AM
Hi smile
Hope it helps smile
On Z-Brush it is perfect….
Can I remove BUMP channel??How?. I’m newbie…
Image Attachments
Profile
Posted: 23 November 2012 03:16 PM   [ Ignore ]   [ # 9 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
In any 3D program,. the Bump is a channel of the surface Shader, or Material..
It’s an image map,. so, yes you can remove it completely, or swap it out for another Bump map for that object.
Depending on what you’re exporting from Z-Brush, you’ll have the model, or the model plus a bunch of texture maps,
Look at where those maps are being saved,. and then have a look at them in an image editor, to see if there’s anything in the maps which would cause this problem.
In poser,. You can Go to the Material room,. then select the Poser surface for that area of the figure, then you should be able to see the shader list of channels, and the BUMP channel should be about halfway down.
You should be able to see what texture map is loaded, and, browse for another map for that figure,. then check what it looks like in an area render.
In Daz Studio,. you would select the figure, then go to the Surfaces tab,. look down the shader list for Bump and then adjust or change the Bump map. then check what’s changed.
Hopefully,. one of those options should help smile
Profile
Posted: 23 November 2012 03:53 PM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  2012-08-19
3DAGE - 23 November 2012 03:16 PM
Nothing happens when I disconnect the bump..
There is a layer called “traslucence color” in color black but when I change it to white then spots disappear. However, the render loses much realism…
Profile
