Digital Art Zone
File editing
Posted: 22 November 2012 09:15 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2012-02-07
I remember a while back reading about a way to directly edit files for things like removing calls to unused morphs or pointing to the wrong directory.  What programs can be used for this?
 Signature
http://streetteam.bigcartel.com
Profile
Posted: 22 November 2012 09:41 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
If these are plaint text files, then any text editor should manage the job.
I use Notpad++, but most of the latest text editors will do.
What file types are you wanting to edit?
Profile
Posted: 22 November 2012 09:49 AM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
It depends on the file…
If it is a cr2, pp2, dsa, ds,  etc any text editor will work (notepad, but it is very limited…Notepad++ is a favorite alternative)
If it is an uncompressed dsf/duf, the same thing, any text editor.
If it is a compressed dsf/duf, it will need to be decompressed or edited within DS.  This also goes for any compressed Poser files (ppz, etc)...decompressed first.  Something like the command line version of 7zip should work to decompress the files.  Or there is a way to do it from within DS (for Daz format files) or Poser.
Another way, but one that isn’t very easy…for Windows, is to use a text editor that can edit compressed files on the fly.  The setup usually involves setting up the text editor, because I haven’t found one that doesn’t have to use some sort of plugin that needs to be configured before it will work (that’s where the complexity lies).
Also for DS there is the DSFToolbox.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 22 November 2012 09:54 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2012-02-07
Trying to fix a duf.  Attempted to use Notepad++ but it was a scrambled mess.  For this specific instance I’m trying to make a dial spun character preset but I only want to add the face morphs.  Can’t find any other info on options for doing this outside of just outright removing the “zeroed” parts since I’d like to be able add it onto any body without reverting things.  Plus, I have an automatic joint fix installed that seems to be getting called as well.
 Signature
Profile
Posted: 22 November 2012 09:55 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2012-02-07
Ah, my post didn’t come through until after but that info should be useful.  Thank you.
 Signature
Profile
Posted: 22 November 2012 09:59 AM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
You can uncompress a DUF file by using WinRar or WinZip or any of the free versions as well.  I just drop it on the WinRar icon, and I get the plain text DUF file.
Profile
Posted: 22 November 2012 10:34 AM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2007-01-04
ZamuelNow - 22 November 2012 09:54 AM
If your saving as a Character preset then you don’t have much choice, as it’s coded to either load a fresh Genesis with the settings in the preset, or replace the selected Genesis with a fresh one using the settings in the preset, so there isn’t anything in the DUF you can remove with a text editor to fix this.
Your best bet is a shaping preset, as you can select which modifiers are recorded into it, that way you can mix & match morphs without wiping out the other settings.
 Signature
**shuffles of with a new headache** tongue wink
Profile
Posted: 22 November 2012 11:23 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2012-02-07
I guess that begs the question: What are the pros and cons of using a Character Preset or a Shaping Preset?  I’m assuming shaping would be limited to what’s on the Shaping tab while character has the overwriting issues but I could be wrong on that.
 Signature
Profile
Posted: 22 November 2012 01:22 PM   [ Ignore ]   [ # 8 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
My understanding, and it may be limited or ‘off’, is that Character presets are for complete characters…where you’ve set up everything, face, body, etc.  And want it to load as a complete unit.
And Shaping presets are for ‘parts’.
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 22 November 2012 01:33 PM   [ Ignore ]   [ # 9 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
A character preset saves both shape and materials, a shape preset saves only shape.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 22 November 2012 03:18 PM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2012-02-07
Testing things out, it looks like a shaping preset is exactly what I was needing.  Thank you, everyone.  I’ll still note the other info since it’s still good information to have.
 Signature
Profile
