Digital Art Zone
Can I use Bryce/Carra content in Studio?
Posted: 21 November 2012 06:38 PM   [ Ignore ]
Active Member
RankRank
Joined  2009-12-07
I’m a DS-only user (not even Poser!) but at times I’ve seen some nice looking products in the DAZ store for Bryce or Carrara. I’ve never purchased these because I don’t know if it works in Studio. Can anyone advise?
 Signature
PoseMaster for DAZ Studio and PoseMaster People Pack now sold at Rendo.
Profile
Posted: 21 November 2012 07:30 PM   [ Ignore ]   [ # 1 ]
Addict
RankRankRankRank
Joined  2004-07-01
cridgit - 21 November 2012 06:38 PM
if you don’t Bryce or Carrara I wouldn’t buy any thing for them .
I use both - but I sent from DS to them .
Profile
Posted: 21 November 2012 09:00 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2004-11-07
No. They are a different file format so Bryce and carrara content wont work in studio.
 Signature
Profile
Posted: 21 November 2012 10:02 PM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
studio stuff mostly and pretty much all Poser stuff works in Carrara.
some of the later Poser characters with weightpainting may need conversion using a free program by Fenric but those don’t work in studio anyway.
materials may need highlight removed.
and Carrara is way cool, renders quicker, has many more features. but going out of Carrara is not supported much with some exceptions or workarounds.
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 22 November 2012 05:42 AM   [ Ignore ]   [ # 4 ]
Active Member
RankRank
Joined  2009-12-07
And Cararra is still in beta right? wink
Thanks for the feedback. Guess I won’t be spending anything on Bryce or Carrara content then.
 Signature
Profile
Posted: 22 November 2012 07:01 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2004-11-07
Carrara 8.5 is still in beta. Don’t know why, hasn’t been an update to the beta in 6-7 months. But hey, when you are tired of working with that tinker toy app, come on over to carrara wink
 Signature
Profile
Posted: 22 November 2012 08:23 AM   [ Ignore ]   [ # 6 ]
Active Member
RankRank
Joined  2009-12-07
Poser? wink
 Signature
Profile
Posted: 22 November 2012 08:44 AM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Depending what the Products are that you are interested in, some may be able to be used (indirectly) in Poser.
Materials will not, obviously, in the same way that DS shaders cannoot ne used in Poser, and vice versa.
However props are sometimes packed with OBJs as well, and even if the are in fact OBPs, you can always open them in Bryce and export them to use as OBJ in Poser.
I must admit I do this in reverse though, I export OBJs from Poser and render in Bryce. (That shouldn’t surprise you too much, I don’t excatly hide my software preference cool smirk)
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge for June        June Freebie Challenge
11915 was the number
Profile
Posted: 22 November 2012 09:11 AM   [ Ignore ]   [ # 8 ]
Power Member
RankRankRank
Joined  2011-11-16
Thank you chohole, was about to say the same thing basically. Most software will allow one to export their proprietary formats objects to obj generic type objects. Whenever exporting to a more generic format much is going to be lost, mostly in the form of textures, sometimes in detail etc… depending on the structure of the item in the proprietary format and how much translates to the obj format. So, can x be used in y… usually, but one’s mileage may vary on how much translates and whether it is enough for a given persons situation or need. This can mean an object translates pretty well, or that it translates grey with no textures and even that is distorted. Even different objects from the same source/person can vary in how they transfer. So, be cautious on how much you spend on an object you want to transfer, and realize it isn’t going to look like it does in it’s native software without some amount of work.
 Signature
Just because I may have a strong opinion doesn’t make it any more (or less) correct than any other, just that I feel passionately a particular way at that moment.
Profile
Posted: 22 November 2012 10:08 AM   [ Ignore ]   [ # 9 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
some things are just software specific too
Carrara replicators and fur for example, or Poser hair
others like dynamic cloth only work in a software suite that does it.
Howie Farkes scenes in Carrara for example use replicators, you could create real instances but it would bog it down very fast and the export file would be massive.
 Signature
Profile
Posted: 22 November 2012 10:11 AM   [ Ignore ]   [ # 10 ]
Power Member
RankRankRank
Joined  2011-11-16
Yes, important point… ty for filling that in wendy smile
Along the same lines, even when two different pieces of software do support advanced things like instances, this information isn’t transferred between the two different products using a common format.
 Signature
Profile
