Digital Art Zone
1 of 2
1
Measuring Genesis
Posted: 21 November 2012 11:24 AM   [ Ignore ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
I’d like to start a discussion on the measurments of Genesis, V5, M5, S5 and all other default characters that people have, just to make sure I’m seeing what everyone else is.
How I measure:
1. Create: Primitive: Cylinder
2. In the Create Primitive Dialog box, Select dimensions in inches and set the height to 1, hit accept
3. select the cylinder, in Parameters, hit the gear button and deselect PERCENT in the dialog.
4.  Set the Y scale value of the cylinder to 72 (six feet) and adjust it till you can just see it over the crown of your figure’s head.  The value of Y at that point is your figure’s height in inches.  You can also do this in Centimeters should you choose.
Here are my results:
Default Genesis Figure (Male, Female, Neuter) 5’10.5”
Victoria 5: 5’7”
Victoria 5 Supermodel: 5’10”
Michael 5: 6’3”
Michael 5 Heroic: 6’6”
Stephanie 5: 5’2” (plus, actually…)
Stephanie 5 Model Body: 5’6”
Stephanie 5 Curvy Body: 5’2” (same as S5 Default)
Victoria 4 and Stephanie 4 do not change the height of the default Genesis figure.  I do not have Michael 4.
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 21 November 2012 11:26 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2008-11-10
wancow - 21 November 2012 11:24 AM
They do, just slightly.
Profile
Posted: 21 November 2012 11:54 AM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
I’ll take your word for it smile My eyes ain’t that good anymore :(
 Signature
My ShareCG Gallery
Profile
Posted: 21 November 2012 12:01 PM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
You need something that will measure a bit finer than full inch increments…it’s something like 5’ x.nn’‘, with the ‘nn’ being less than 0.25, if I remember, correctly.
And the important thing…it’s not the total height, but the proportions are different.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 21 November 2012 01:31 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2010-09-19
When I did this chart, I used basic ratio proportion equation to confirm numbers, so should be pretty accurate…
http://www.sharecg.com/v/56340/gallery/21/DAZ-Studio/Height-scaling-guide-for-the-Genesis-base-figure
...some purchased characters will change Genesis height and still show 100% scale in parameters - I suppose you could load a default Genesis and scale height to match character and see where it sits percentage-wise.
But there’s more than one way to skin a cat, this just so happens to be the method I use for creating Genesis characters e.g. having celebs the same equivalent height as real-life counterparts rather than having everyone at 5’ 10”
 Signature
My deviantART page
My ShareCG freebies
Some of my music
Profile
Posted: 21 November 2012 01:59 PM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
mjc1016 - 21 November 2012 12:01 PM
it does go to 100ths, even when each full unit is an inch… so if I had better eyes, or if I wasn’t too lazy, I could go in and measure the figure to 1/100th of an inch using my method.
What I would like to do, and have wanted to do for years, is to take waist, hip and bust measurements!  Cup size would be nice as well smile
 Signature
My ShareCG Gallery
Profile
Posted: 21 November 2012 08:04 PM   [ Ignore ]   [ # 6 ]
Active Member
RankRank
Joined  2003-10-09
How do you set dimensions? Thanks.
Profile
Posted: 21 November 2012 09:55 PM   [ Ignore ]   [ # 7 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
I’ve been using centimeters. I think it’s default measurement.
Centimeters is accurate enough… Inches has too much variation.
 Signature
I’m not Spyro the dragon… We just look alike! tongue wink
“Anything in the real world can exist in 3D”
Eyeshine Tutorial for Daz3D vampire
- - My Render Thread - - My Deviant Art - -
- - xSPYROx ShareCG Freebies - -
Profile
Posted: 21 November 2012 10:26 PM   [ Ignore ]   [ # 8 ]
Active Member
RankRank
Joined  2003-10-09
I don’t know even where the dimensions are ... But I have need of it for something I am working on.
Profile
Posted: 21 November 2012 10:46 PM   [ Ignore ]   [ # 9 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
I don’t know how to change the measurement type, all I know is it is Centimeters by default. 1.0 = 1cm
When creating a primitive, you can specify the size as centimeter, meter, inch, yard, foot in the drop down menu beside the scale you specify for the primitive.
 Signature
Profile
Posted: 21 November 2012 10:50 PM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
It’s true that centimeters are more accurate.  My problem is I"m so used to inches and feet for heights… I know, for instances, that I’m 170cm tall… but I couldn’t tell you how tall a woman of 5’3” is without doing the math…  All I know is that it’s the height of a very petite woman who’s not miniature, and that the average american woman is 5’5-5’6
 Signature
My ShareCG Gallery
Profile
Posted: 21 November 2012 10:52 PM   [ Ignore ]   [ # 11 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
GhostofMacbeth - 21 November 2012 10:26 PM
It’s VERY easy to use primitives, especially cubes and/or cylinders to measure, GOM…
Try forming a cube in either inches or cm (your prefference) and make it’s dimensions 1.
Change the X,Y and Z scale from Percent to Value, and dial it up to whatever measurement you want, X,Y or Z…
 Signature
My ShareCG Gallery
Profile
Posted: 21 November 2012 11:01 PM   [ Ignore ]   [ # 12 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Oh, I see what you’re doing. Your making a primitive the height you want your character. I thought you were changing the format of measurement, which is either % or Cm.
I create a primitive that’s rather small and set the Y position to the height of character to accurately measure the character which gives me the approx Cm value of the characters current stature…. By creating the primitive the full height you get what ever measurement you set the primitive.
 Signature
Profile
Posted: 21 November 2012 11:05 PM   [ Ignore ]   [ # 13 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
I actually do both.  If’ I’m creating a character, I set the hight first, usually… then use the proportion Morphs converted by AdamR… if I get a character that already has a height value, like I just did, I set the primitive to one inch and dial it up…
 Signature
My ShareCG Gallery
Profile
Posted: 21 November 2012 11:07 PM   [ Ignore ]   [ # 14 ]
Active Member
RankRank
Joined  2003-10-09
Thanks, I thought you were setting the dimensions, as well.
Profile
Posted: 21 November 2012 11:10 PM   [ Ignore ]   [ # 15 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
I"m trying to figure out how I explained it wrong in my OP… smile
 Signature
My ShareCG Gallery
Profile
1 of 2
1
