Digital Art Zone
Newbie Question:  how do I…
Posted: 20 November 2012 03:58 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2008-09-17
...put an object (OBP) I downloaded into my scene?
I have it installed to my Bryce7/Presets/Objects folder but I don know if I import it; open it or merge it.
Bryce 7.1 Pro.
 Signature
Resistance is futile.  You will be DAZzimilated
Old post count: 5719
Profile
Posted: 20 November 2012 04:05 PM   [ Ignore ]   [ # 1 ]
Addict
RankRankRankRank
Joined  2004-07-01
BWSman - 20 November 2012 03:58 PM
Bryce 7.1 Pro.
click it - then click the check mark for ok
it will load into your scene
Profile
Posted: 20 November 2012 04:07 PM   [ Ignore ]   [ # 2 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Open your Create preset screen by clicking the little arrow beside the word creat e on the top line, then import the OBP into a folder there.  You have a nice big empty folder called user, which you can find if you click the arrow besides “Installed” at the bottom of the box.
If it is already there than you don’t need to import it.
THen once it is in there you click on it to bring it into your scene.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge for June        June Freebie Challenge
11915 was the number
Profile
Posted: 20 November 2012 04:09 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
Bryce 7.1 Pro.
If you have it in the right place (see http://www.horo.ch/docs/mine/pdf/BryceContent_v4.pdf if you are uncertain).
Goto the create shelf and open the object library (image1)
If it is not in the list on the left.  Check for other categories (image 2)
When you have found it.  Click on the thumb and then click on the check (image 3)
It should now appear in your scene.
(and no I don’t know why the images are out of order - that’s this fruity website for you!)
Image Attachments
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 20 November 2012 04:15 PM   [ Ignore ]   [ # 4 ]
Addict
RankRankRankRank
Joined  2004-07-01
see what happens when I give a answer - I love it LOL
Profile
Posted: 20 November 2012 04:19 PM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
bigh - 20 November 2012 04:15 PM
No answers were there when I started answering… but then again, I am quite slow at reading and moderately sluggish at formulating a response.  Much to Len’s irritation, if I am in a thread with him, I will often “cross” him inadvertently.
 Signature
Profile
Posted: 20 November 2012 04:24 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Bryce 7.1 Pro.
If it’s in your presets then it’s ready to go and should come up by accessing the objects library which is accessed by clicking the triangle to the right of the word create at the top of the Bryce interface. The only problem you might have that I can think of would depend on how you put it in your presets. I’m assuming you put it there manually? Many people, myself included, like to organize things on their computer by grouping things in specific folders. To illustrate lets take a look at how I might have organized objects. You already start with the folder presets/objects. Now if I had many objects from the same vendor I might want to group them that way, lets say that artist’s name was JSmith. So then I would have presets/objects/JSmith. If I just put the objects directly in that folder with no other sub folders then everything would be fine. Let’s say though that some objects by JSmith are buildings and some are plants. I would be inclined then to seperate those by having a sub folder under JSmith for Buildings and one for Plants. Yielding presets/objects/JSmith/Buildings and presets/objects/JSmith/Plants. Unfortunately if I did that I would not see any of those objects because Bryce only recognizes one folder level deep beyond the objects folder (same is true for other presets catagories as well). So just be careful how you organize things when manually bringing them into presets otherwise you might not be able to access things you put there.
Now assuming that isn’t an issue in your case the process of getting it into your scene is: Open Bryce, load scene, click the little triangle next to create at the top of the Bryce interface, find the desired object, select the object by clicking on it, click the green check mark at the bottom right corner of the objects library window. This will then return you to the scene with the object loaded into the scene. You may still need to use the edit functions to move it around or resize it within your scene.
Profile
Posted: 20 November 2012 04:26 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Well I gave more details, and David did it the really good way.  Lots of answers is better than half an answer for new users.
David Brinnen - 20 November 2012 04:09 PM
David.  Add your first image, then click Preview post, then you get an empty box to add the 2nd image, and then do it again to get the 3rd image.
 Signature
Profile
Posted: 20 November 2012 04:33 PM   [ Ignore ]   [ # 8 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
chohole - 20 November 2012 04:26 PM
Yes I did that.  Twice even!
 Signature
Profile
Posted: 20 November 2012 07:19 PM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2008-09-17
Thanks for providing the information & images for locating the file.  That did the trick.
 Signature
Profile
