Digital Art Zone
DAZ Studio 4.5 on Ubuntu Problems
Posted: 19 November 2012 05:38 PM   [ Ignore ]
New Member
Joined  2012-09-20
Does anybody know how they got the plugin “dzcolladax” to work on DAZ Studio 4.5 that was ported to Ubuntu on WINE?
Thanks for any help.
grin
Profile
Posted: 19 November 2012 05:59 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Poll removed.  Please note item #19 of the DAZ 3D forum TOS
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge for June        June Freebie Challenge
11915 was the number
Profile
Posted: 19 November 2012 06:03 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
What version of WINE? Ubuntu?
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 21 November 2012 07:02 PM   [ Ignore ]   [ # 3 ]
New Member
Joined  2012-09-20
WINE v.1.5.17
Ubuntu Studio 12.10
Profile
Posted: 21 November 2012 07:26 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
I haven’t had much success with 1.5.17.
You may want to undo any dll overrides you may have set for DS….
I get a crash every time I go to render.  I was thinking it was something specific to the build for Slackware, but I rebuilt the package myself and still had problems.  Maybe Kendall will spot this one…
But after rebuilding the package, I started getting random plugin errors.  I’ve had the most success with 1.5.12…it runs DS the most stable for me.  Also, running it with winecfg setting the version for DS to Windows Vista is more stable than Win7 or 8.
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 22 November 2012 12:09 AM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Wha… somebody call for me?  grin
There was a change made in wine 1.5.13 that has caused a few (cough… understatement… cough) problems with Windows programs that use OpenGL directly.  The wine folks are trying to fix/add the mess that is the DIB layer.  I would recommend that the average user hang back with the 1.4 releases, as the last truly stable 1.5 version for DS/Carrara/Poser is 1.5.3.  The 1.5 branch is subject to rapid change and regressions are common, so unless you are at a level where you can work out what is a Wine issue vs a Windows issue vs an Application issue, then the 1.4 is the best bet.
Anything after 1.5.3 *WILL* cause spurious crashes in 3Delight and with the versions beyond .12 getting a full successful render is an anomaly not an expectation.  To get any use out of post .12 there are a number of wine registry settings that must be used to turn off specific “new features” and these settings have adverse effects of other parts of both Wine and DS.  If one does decide to use newer than .12, I’d suggest that one get real cozy with RIB files and external rendering, or use Reality coupled with Lux in Linux Mode.
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 22 November 2012 07:13 AM   [ Ignore ]   [ # 6 ]
New Member
Joined  2012-09-20
Weird….I’ve never had a problem rendering…..Only problem I’ve had is not being able to export to .dae files…..This gets stranger and stranger…
Profile
Posted: 22 November 2012 08:37 AM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
bob.hostern - 22 November 2012 07:13 AM
I’ve pulled .17 from my machines due to the problems, however, I just successfully export a collada from DS4.5.1.6 and load it into carrara 8.5 using Wine 1.5.3.  I’ll see about loading a .17 and trying it if I can find a moment.
Kendall
 Signature
Profile
