Digital Art Zone
Instructions for GenX plugin
Posted: 18 November 2012 02:08 PM   [ Ignore ]
New Member
Joined  0
Hi.
I can’t understand the instructions of GenX (GenX.pdf).
Is there any video instructions for this plugin?
I follow the instructiones and something is wrong; see pictures
Image Attachments
Profile
Posted: 18 November 2012 05:30 PM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
What version of DAZ Studio are you using?  The latest version is 4.5.1.6
What version of GenX are you using?  The latest version is 1.2, and was released in September for the DS 4.5 versions.  Did you update it if you are using DS 4.5 or higher?
Profile
Posted: 18 November 2012 06:10 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  0
JimmyC_2009 - 18 November 2012 05:30 PM
Yes, I have DS4.5.1.6 and yesterday i did it with GenX 1.2
I do not know how to interpret the instructions to use the GenX tab.
Profile
Posted: 19 November 2012 01:09 AM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
There is a video here:
http://takoyakida.webs.com/apps/blog/show/13803069-genx-plug-in-tutorial
 Signature
I like Bryce, DazStudio, Poser and Vue ... in alphabetical order. And I would probably like Carrara too, if I could find the time to become acquainted with it. Peace?
Profile
Posted: 19 November 2012 07:28 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  0
I’m in the same; I follow all the steps, but after pressing the “Transfer” button, the window to save the result does not appear.
Profile
Posted: 19 November 2012 08:32 PM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Here’s what I will do if nothing else works.
I load Victoria 4.2.
I load the morphs (I have the powerloader, so it’s easy) but I used to not, so I had to go to the Folder under the Poser libraries and load the morphs from the injection file.
Then I inject the Character morphs.
Then I export the figure to Cr2 format.
Then I create a new scene, and go to my libraries, find that new Cr2 and drag that icon into GenX
THEN, you must select a morph, right click, and activate all morphs or all morphs that have non-zero values.
Then I transfer those to a single morph (I never, ever, make multiple morph files when transferring a character…)
Then the dialog appears, I name the morph and I am VERY VERY CAREFUL about where to group it.  Because it can get lost.  I created my own group under Actor/Characters/Girls and Actor/Characters/Boys
Then I can load Genesis and use the new morph.
Hope this helps.
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 20 November 2012 05:41 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2006-08-26
There’s a good tutorial over at Renderosity that is easier to follow than the PDF.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2851334
Profile
Posted: 20 November 2012 06:13 PM   [ Ignore ]   [ # 7 ]
New Member
Joined  0
Thanks a lot for all.
Profile
