Digital Art Zone
1 of 3
1
How do I create Textures?
Posted: 17 November 2012 07:02 PM   [ Ignore ]
Member
Rank
Joined  2011-10-27
I know I’ve been doing a shirt on another thread, but this thread relates to modelling textures…
I am after a material similar but not exactly to the example below…
I have Paintshop Pro, and Photoshop and have had no success in either.
What does everyone else use and how would they achieve mats like the example below please
Thank you.
Image Attachments
Profile
Posted: 17 November 2012 07:29 PM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2003-10-09
There are several methods to use.
Use a sample of material that contains basic design pattern,
then make it seamless by removing one row from bottom and left side
Insert that into pattern stamp tool of Photoshop and paint new texture on template of clothing.
You can also google “seamless fabric” or similar and obtain a great many resources already done in this manner
Less successful is finding picture of clothing in approximate shape as UV template and pulling it into shape.
Profile
Posted: 17 November 2012 07:33 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Until you UV map the shirt, there’s not really any point, because the textures won’t work.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 17 November 2012 07:36 PM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2011-10-27
I thought UV mapping was part of the process of attaching materials - I’m soooo confused here…
Profile
Posted: 17 November 2012 07:39 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
UV map it, lay out the map so that it makes sense to you and export the template.  In Photoshop draw the texture on layers.  The texture will only “take” on the lines of the UV template - the blank areas will not show any texture.  Be sure that the template is fully covered, or make the template layer invisible, collapse the layers and save as .jpg, png or other format.  Import that into Studio under the surfaces tab, diffuse.
Alternately, you can paint the texture directly onto the shirt in Hex, or use a 3D paint app like Blacksmith (the paint only version is free)  Blacksmith does automatic UV mapping, but doesn’t give you a template you can use to make subsequent texture variations - you will have to paint each variation from scratch.
Profile
Posted: 17 November 2012 08:29 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2011-10-27
OK - so I have gone to uvmapping and selected the region for the shirt body…
I then selected cylindrical UVMapping (because it started with a cylinder…
I then saved the resultant area as a BMP…
What now???
Am I best doing it as a cylinder or as a flat surface???
How can I get the garment flattened out?
I know I’m a dimbo but I honestly haven’t a clue!
Thanks
Profile
Posted: 17 November 2012 08:39 PM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Here’s a shot of the UV mapping I did for it…
I used Blender which allows you to make seams to split the item along. There are other programs with that ability too, but I don’t think Hex is one of them. I find it one of the easiest methods of mapping around.
Yeah, it could use a little clean up to minimize stretching and even out some of the areas, but for a quick map it’s fine.  Also I wouldn’t worry too much about it if there are any mesh edits planned.  A map like this is fine for plain, solid color textures or to get an idea on how tiled ones would look.  But as a ‘final’ map, I’d clean it up first.
Image Attachments
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 17 November 2012 08:40 PM   [ Ignore ]   [ # 7 ]
Member
Rank
Joined  2011-10-27
EEEEH! Mine looks nothing like that - mine looks like a strangled octopus!
Profile
Posted: 17 November 2012 09:39 PM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2009-01-27
tdrd - 17 November 2012 08:40 PM
Welcome to the world of UV mapping!
UV mapping can be one of the most complex issues you’ll face when modelling. There are SO many ways of “getting the job done” that it becomes an art unto itself aside from the actual modelling.
Many people start with a primitive (which maps very cleanly) and then deform the primitive to create the model. Unfortunately, this only works as long as you don’t add/remove a single vertex. Doing so destroys the mapping.
Most people map their model using material domains after the model is finished. This allows you to work on discrete sections of a mesh without having to untangle the rat’s nest presented by mapping the entire model.
Most folks here use a 3rd party app for mapping (I use UVMapper pro, but there’s a free version available), while others, such as Mjc mentioned, prefer programs like Blender. I’ve seen a few other dedicated mappers mentioned often in these threads (and will probably get mentioned in this one) that get rave reviews by the users.
I find Hexagon’s unwrapping tool difficult to decipher, but that could be because I’m used to using UVMapper. UVMapper also let’s you save texture templates in exquisite detail while Hexagon’s templates are just plain cheesy.
Hexagon does use seams in it’s unwrapping scheme, and another tool called “pinning”. I believe Roygee in a past thread mentioned that he figured out how to use Hex’s unwrapping tool using these pins to achieve a satisfactory layout.
Bottom line is that there’s no simple one-size-fits-all magic bullet answer we can give you on how to map your shirt.
Just take a deep breath and relax because this could be a wild ride, but when the smoke clears you can end up with a nicely formatted UV map.  smile
 Signature
For any arguments or illustrations I give, my system specs are:
Hexagon version 2.5.1.79,  XP pro 32 bit,  pentium core2 duo,  ATI radeon 3870, 2 gigs ram
Profile
Posted: 17 November 2012 10:07 PM   [ Ignore ]   [ # 9 ]
Member
Rank
Joined  2011-10-27
I’ve been looking at some tutorials on UV mapping but not really any the wiser because they are all mapping a single flat surface.
I’ll look at uvmapper and see what it can offer….
I am limited to free versions at the moment having spent my budget buying this new computer out of my redundancy money a couple of months ago.
I figured I may as well have a decent PC since i’m going to have a bit more free time for a while.
Oh well - i’ll see what I can find - thank you.
Profile
Posted: 17 November 2012 10:58 PM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  2011-10-27
I’ve downloaded UVMapper - loaded the object file and the picture I got is as shown below
What am I supposed to do with THAT!
Image Attachments
Profile
Posted: 18 November 2012 12:03 AM   [ Ignore ]   [ # 11 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
With UVMapper, the ‘cleanest’ result is Planar, Z axis alignment…
Image Attachments
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 18 November 2012 01:50 AM   [ Ignore ]   [ # 12 ]
Member
Avatar
Rank
Joined  2003-10-09
mjc1016 - 17 November 2012 08:39 PM
Actually Hex does this as well and it’s really fast. Just go into Edge mode and select all the edges you want to split then go to UV and click the Head and then Validate.  Downer is that you have to move all the islands into the uv space since hex lines it up outside the uv space.
Nowadays I just export it once I determined where I want it to split and then use UV Master in ZBrush to make the final map.
 Signature
My store at Renderosity. http://www.renderosity.com/mod/bcs/index.php?vendor=29771
Rendo Freebies. http://www.renderosity.com/mod/freestuff/index.php?username=ghostman
Profile
Posted: 18 November 2012 07:40 AM   [ Ignore ]   [ # 13 ]
Member
Rank
Joined  2011-10-27
Ah! I’m guessing UV isn’t UV as in photography… it’s something to do with 2 dimensional projection.
I read that xyz already used in 3d so uv was used instead????
OK - so if I want my collar to have a different material do I save this map to a seperate file to work on it?
Same for the arms and main body - seperate files????
Profile
Posted: 18 November 2012 07:56 AM   [ Ignore ]   [ # 14 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
You can just save all of the UV Mapped parts to the same UV template.  That is the whole idea, so that you can paint each area with a different colour (or texture) in Photoshop.  When you paint on to the template, 3D programs know where to apply the different parts to the UV model, assuming taht you have re-saved the OBJ file after creating the Template?
Profile
Posted: 18 November 2012 08:03 AM   [ Ignore ]   [ # 15 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
AS a texturer I have to say that the original UV map that MJC showed is the one I would choose to use.  It reflects how a shirt would be put together in realy life, and thus would produce the best textures for it.  Ithe UV grid lines are nice and clean, and thus wouldn’t produce too much stretching or deformation of the material used to create any textures.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
1 of 3
1
