Digital Art Zone
2 of 2
2
Problem with Ultimate Dynamic Tee Material
Posted: 05 December 2012 12:03 PM   [ Ignore ]   [ # 16 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Yes, there is something wrong with the mesh…look at the areas around the shoulder seam.,,and the side seam on the wireframe of the mesh.  Try redownloading the item.  If that doesn’t help, submit a support ticket.
Image Attachments
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 05 December 2012 01:29 PM   [ Ignore ]   [ # 17 ]
New Member
Avatar
Joined  2012-02-02
Unfortunately it is not a simple mesh problem. The mesh is fully intact. I tripple checked that. No duplicate vertices, no stray vertices, no nothing obviously wrong with the mesh. Since i am the second user who reports this issue here, i believe that something is broken either in the distribution of the Dynamic Tee item or it is simply a compatibility issue with Studio-4.5 and/or the Genesis character.
The most puzzling point is that although the item is declared as compatible to Genesis, it provides material sets only Victoria 4, but neither for v5 nor for genesis. Maybe that is the true cause of the problem.
btw a re-download does not help either. And i have already reported the issue to daz people 2 days ago and patiently wait for the answer smile
Profile
Posted: 07 December 2012 01:26 PM   [ Ignore ]   [ # 18 ]
New Member
Joined  2007-01-23
Hi folks,
Another user also reported the same issue with this product.  I forwarded it as a bug report in our Mantis Bug tracker.  The tester was *not* able to duplicate the bug.  He did provide some helpful recommendations that I have taken the liberty of pasting here.  I recommend that you follow these instructions.
MANTIS 48466
“https://bugs.daz3d.com/view.php?id=48466” (may require Mantis user account to view)
“Hello!
I have a clean install (64 bit) of DAZ Studio 4.5.1.6 Pro, DCC 1.2.1.6 and Version 1.0 of the Dynamic Tee. I was unable to reproduce your issue.
Here are the steps I used:
Load Genesis
Load Dynamic Tee
Fit the Tee to Genesis then unfit it.(Tried with and without parenting to chest same results for both)
Open animation pane set FPS to 15
Select frame 10 and apply morph/pose to Genesis and create the new key frame.
Go to Dynamic Clothing pane and select Collide with Genesis making sure the Tee is unselected.
Select the Animated radial and hit the Drape button.
Once draping is completed I then ran through all the material options with no issues. See attached render “DynamicTeeDS4516.jpg”
I tried this will all the versions of the Tee.
I did have an issue like this on my system a while back and it turned out to be DS4 DCC and DS4.5 DCC not liking to be installed side by side on the same machine. If that is not the case with your system I would say you may have a corrupted installer file and to redownload and reinstall the DCC.
Elli”
Profile
2 of 2
2
