Hi
I have noticed a odd behavior in Carrara 6 pro when creating a ” Group ” which I then drag into” my objects” folfer to create an object.
This particular group has 4 objects. When I click on the group the bounding box is quite a bit larger then the sum of it’s parts.
If I ungroup and click on each object the individual bounding boxes are tight to the objects, But if I then group again, the bounding box is about 50% longer and 25% deeper the the area of the group. The group does contain anything glows and I wondered if that could effect the overall size of the bounding box, but if I click on anything glows alone the box looks correct.
This makes life a little more difficult because I use collision detection to assemble objects, and this “large box ” makes it tough.
Short question is it possible to change the size of a bounding box on a group without effecting the size of the group itself.
Thanks
8068
