Digital Art Zone
2 of 2
2
Genesis:Dynamic Clothes:Supersuit:2
Posted: 19 November 2012 10:37 AM   [ Ignore ]   [ # 16 ]
Member
Rank
Joined  2011-01-15
i get the standard options “what was the item made for? ”  i selected V3
only have ” Boots thigh length ”
still cant get the shoes to fit.
Image Attachments
 Signature
smilemalmaoo
Profile
Posted: 19 November 2012 10:37 AM   [ Ignore ]   [ # 17 ]
Member
Rank
Joined  2011-01-15
so i tried many other things… i’m playing around with it still,
but parent item. unparent item.  nothing does the trick.
Autofit, or apply smoothing modifier nope
just can’t get it to work.
any ideas?
Image Attachments
 Signature
smilemalmaoo
Profile
Posted: 19 November 2012 10:47 AM   [ Ignore ]   [ # 18 ]
Member
Rank
Joined  2011-01-15
JimmyC_2009 - 18 November 2012 04:40 AM
Malmaoo - 17 November 2012 07:08 PM
thanks,
i have some questions about the red bolls i seem to get quite oftern,
can you help
and i have always this problem with shoes fitting, the genisis figure,
they were made for victoria 3 , so there is no option, on autofit,
can you help please with making shoes fit?
First of all, the red balls are shaping handles to help you to pose the dress.  Look in the Surfaces pane for them, and turn the Opacity slider down to 0% and they will go away.
Thank you, i have it..
In Body handle Turned Down Opacity. and it worked!!
well done!!
 Signature
smilemalmaoo
Profile
Posted: 19 November 2012 12:05 PM   [ Ignore ]   [ # 19 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
It says ‘you have chosen to fit an Unsupported item…..’
You must click on the part where is says ‘Unsupported’, and choose the character the boots were originally made for.
Profile
Posted: 20 November 2012 04:51 PM   [ Ignore ]   [ # 20 ]
Member
Rank
Joined  2011-01-15
i can not get this to work.
Image Attachments
 Signature
smilemalmaoo
Profile
Posted: 20 November 2012 06:03 PM   [ Ignore ]   [ # 21 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
You are still not choosing the item type, it is also a drop dwon list.  Select ‘Boots’ from that list.
Footwear does not always fit perfectly using Autofit, and you may have some work to do.
Profile
Posted: 20 November 2012 07:21 PM   [ Ignore ]   [ # 22 ]
Member
Rank
Joined  2011-01-15
thank you for taking the time to write to me, yes i did try the boots from the drop-down list.
i got the “Gen 3 Iconic Shapes for Genesis” it does work with the cloths mostly ok without too much fiddling with it
and looks quite good. excellent on some items,
but Autofit Does Not Work on Boots. i did that right at the biginning before i asked anyone how to do it.
at least i can’t make it work. Autofit tool works amazingly on some things and its quite briliant on cloths items.
but feet seems to pose a problem for Autofit tool.
so i thought i would post this picture to show i selected the menue Boots
i have seen a video tutorial on making boots fit. when there not supported.
the boots partly cover the feet, i have tried positioning the feet first, but that does not work
the only way i can see at the moment is to manually correct the shape and positioning first.
then parent it to genisis figure after , and after that try appy smoothing modifier. but there is a lot more tools in Daz i don’t know about and a lot more to learn
best wishes
Image Attachments
 Signature
smilemalmaoo
Profile
2 of 2
2
