Digital Art Zone
60 of 91
60
SITE UPDATES, ANNOUNCEMENTS, AND CUSTOMER SERVICE INFORMATION
Posted: 12 August 2012 10:03 PM   [ Ignore ]   [ # 886 ]
Active Member
RankRank
Joined  2011-04-12
I believe the issue is wanting to click on (for example) Forum Home, moving the cursor one line too far (easy enough to do , especially with some trackpads), and getting the Shop menu covering the intended link.  Either separating the lines further or having a brief delay before the menu opens should solve the problem.
Profile
Posted: 12 August 2012 10:27 PM   [ Ignore ]   [ # 887 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Say I’m on this page and I happen to barely run the cursor over The Commons link but a little upwards then the Products drop down activates!  That’s what I’m getting at least.
 Signature
—-Wolff On The Prowl—-
Posts: 28,985 and counting!
        RAMWolffsWorld
Profile
Posted: 13 August 2012 03:05 AM   [ Ignore ]   [ # 888 ]
Member
Avatar
Rank
Joined  2005-10-21
If you use the Community tab and hover over that, then Forums instead, it gives you all the forum options.  That’s the way I do it. smile
 Signature
May I be excused? My brain is full….... tongue wink
My Renderosity store
My dA Gallery
Profile
Posted: 13 August 2012 09:29 PM   [ Ignore ]   [ # 889 ]
Addict
Avatar
RankRankRankRank
Joined  2007-11-06
...most likely it has to do with the fact I am on a notebook with a small display and using the touch pad which is not extremely accurate. One slight twitch (common with my arthritis) can force the cursor to momentarily “overshoot” which is probably what is causing this.
When I’m at home I need to use my USB modem to get online which, because of its width, does not allow for another device (such as a mouse or my trackball) to be plugged into the port next to it, so I am stuck with having to use the touchpad.
 Signature
...forsaken daughter is watching over you…
Profile
Posted: 13 August 2012 09:36 PM   [ Ignore ]   [ # 890 ]
Active Member
Avatar
RankRank
Joined  2007-02-16
Kyoto Kid: You should look into one of those little USB Hub things…. I forget the exact name. It plugs into an empty USB slot and has a little hub with extra usb slots. I bought one about a year ago at a Target store (they had them with the computer and laptop stuff) for about $12 and it had 4 ports. There was another for $15-20 with more ports (8, I think). They are cheap, handy and would be worth looking into smile
Profile
Posted: 13 August 2012 10:47 PM   [ Ignore ]   [ # 891 ]
Addict
Avatar
RankRankRankRank
Joined  2007-11-06
...as long as the ports are far enough apart to accommodate both the modem and my trackball that would work.
 Signature
Profile
Posted: 14 August 2012 12:19 AM   [ Ignore ]   [ # 892 ]
Power Member
RankRankRank
Joined  2005-04-16
Kyoto Kid - 13 August 2012 09:29 PM
Why not get a powered USB hub?  You can get one pretty cheap these days.  I got one for under $10 at buy.com a couple years ago and it works great.  I use my Logitech MX Revolution mouse with it (wireless USB receiver, best wireless desktop tool I’ve ever had).  Being powered, the hub won’t drain energy from your laptop.
Dana
 Signature
Old post count: 7511
Profile
Posted: 14 August 2012 12:21 AM   [ Ignore ]   [ # 893 ]
Power Member
RankRankRank
Joined  2005-04-16
I see I wasn’t the first to suggest this.  red face
Dana
 Signature
Profile
Posted: 14 August 2012 11:24 AM   [ Ignore ]   [ # 894 ]
Active Member
Avatar
RankRank
Joined  2007-02-16
Hehe, except you idea was better. The one I have doesn’t have an AC plug and draws power from the computer itself.
The USB modem….  is it a dialup one or one that runs off the cell signals? We tried one of those here once when I friend let us see if it would work where I live but it was a Virgin and we don’t get a signal for them anywhere until your already in town :(  I forget how big the modem was, but the 4-port one should work but there is always the larger ones. I think the 8-port one had 2 rows which would make spacing easier perhaps too smile  The stores around here carry them in the electronics sections sort of where you find the laptop stuff and various extra usb cables to buy.  You should be able to see if they’ll work just by looking at them and they are fairly cheap and very handy. Too many things run off USB now days LoL
Profile
Posted: 14 August 2012 01:56 PM   [ Ignore ]   [ # 895 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
There’s also a “squid” USB hub with the ports on short cables for exactly that problem.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 14 August 2012 07:53 PM   [ Ignore ]   [ # 896 ]
Active Member
Avatar
RankRank
Joined  2010-03-01
So are there any others that can’t get Plantinum Club to work? No access to Members Only and no PC items? Anybody know what the deal is?
Profile
Posted: 14 August 2012 10:54 PM   [ Ignore ]   [ # 897 ]
Power Member
RankRankRank
Joined  2005-04-16
Dollygirl - 14 August 2012 07:53 PM
Log out.  If you have forums open in a separate tab from your account or store, log out on both pages before refreshing either.  Then log in to your account.  Let us know if that helps.  I know that every time I click a link from a newsletter to the store, I’m not logged in.  It’s really annoying.
Dana
 Signature
Profile
Posted: 14 August 2012 11:34 PM   [ Ignore ]   [ # 898 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Your profile isn’t showing you as being a PC member—you’ll need to open a support ticket to get it fixed
 Signature
Products In Zips
Profile
Posted: 15 August 2012 10:44 AM   [ Ignore ]   [ # 899 ]
Active Member
Avatar
RankRank
Joined  2010-03-01
fixmypcmike - 14 August 2012 11:34 PM
Thanks Dana and Mike for the advice. Before posting in here I had issued a support ticket. I am being taken care of as we speak. I was just hoping that it was a gobal thing which it seems it is not. I would really like to know why this happened so as to avoid such behavior in the future. It is rather scarry not being allowed to see the PC stuff.  ohh
Profile
Posted: 15 August 2012 10:57 AM   [ Ignore ]   [ # 900 ]
Member
Avatar
Rank
Joined  2003-10-09
Just a note that I got a new bug. The shop deleted my entire wishlist by replacing it with one single new added item. I am UPSET now…
So just a quick note here, I don’t want to double-post. A slightly longer and even more angry description could be found here:
http://www.daz3d.com/forums/viewthread/5495/P165/#73263
Will be a busy evening now.
Profile
60 of 91
60
