Digital Art Zone
Modified preset sharing
Posted: 13 November 2012 10:34 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2012-02-04
I modified a material preset that came with a DAZ weekly free item. Basically I got rid of the mapped reflections and modified the surfaces to have nice real reflections. A few other tweaks were made, too. Another DAZ user would like to use the preset I created. I know meshes can’t be shared, but I don’t know about material presets. I modified and saved it in DS4.5, so it is a DUF file. Does anyone know the rules on this, or do I need to submit a help ticket to get an answer? Thanks.
Profile
Posted: 13 November 2012 10:56 PM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2012-04-07
I’m also interested in the answer to this. In my case it’s that I purchased a .duf texture set which doesn’t work of course in 4.0 so I remade the presets to .dsf files.
 Signature
A couple of tutorial re-ups for those wanting them.
Making skins [basic start]
Unpacking Zip Folders [i.e. how to deal with a gazillion folders if not using DIM]
Profile
Posted: 13 November 2012 11:30 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
If there are no textures involved, just the settings of how they are applied, I don’t see why it wouldn’t be ‘redistributable’...
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 13 November 2012 11:43 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2012-02-04
mjc1016 - 13 November 2012 11:30 PM
So when the surface has a JPG file listed in the Diffuse Color, etc.,does the preset just have a pointer to the file in the user’s runtime rather than the JPG file itself, making it OK to distribute the preset? The preset file I created is only 22KB, so it can’t contain much.
Profile
Posted: 14 November 2012 01:13 AM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
barbult - 13 November 2012 11:43 PM
Yep…just the path to the file.  It should be written as a ‘relative’ path, if memory serves, so if the file exists, then it will be found and used.  If it doesn’t exist, the preset may cough up an error, but it should still load
Basically, most of the ‘shaders’ around are just presets, some with their own textures. And so are any ‘third party’ materials presets (which is essentially what you are creating)...
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 14 November 2012 04:29 AM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
The jpg file itself is the intellectual property of the creator, whether it came with a freebie or a purchased product. As long as you are not sharing the jpg you should be fine, but will need to let people know that the new shader settings will not work unless people already “own” the original file.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge for June        June Freebie Challenge
11915 was the number
Profile
Posted: 14 November 2012 05:46 AM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
To be safe you should probably be selective with the preset, storing only the settings you have changed, then the user can apply the original followed by your adjustments.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 14 November 2012 09:01 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2012-02-04
Thank you all for the guidance. I feel comfortable now that I will not be violating the EULA if I follow this advice.
Profile
