Digital Art Zone
How to open?
Posted: 13 November 2012 11:54 AM   [ Ignore ]
Member
Rank
Joined  2011-06-17
  Ok, I am being stupid I guess. But how do you open and start the Bryce program?? I don’t find the icon, it doesn’t show up anywhere in my computer.
Profile
Posted: 13 November 2012 12:27 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
Find where Bryce is installed and in the main folder, launch Bryce.exe. Once you’ve located it, you might want to create a shortcut for later use.
 Signature
**  [ Stuff by David Brinnen and Horo**  [ My Website**  OPC 4565 **
Profile
Posted: 13 November 2012 10:57 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2011-09-25
@texjones:  You haven’t said which operating system you’re using, so I’m assuming it’s Windows.  If it’s other than Windows them someone else will have to help.
If you let Bryce install automatically, you should find the program under Program Files > DAZ 3D > Bryce7 > Bryce (the icon looks like a mountain on a flat surface).  Once you find the program icon in the above folder, you can then double click on it or right click on it and scroll down to Send.  When you reach Send a side menu opens and you can choose Send to Desktop(short cut) to send a copy of the Bryce program icon to your desktop.
If you can’t find the Bryce program under the path I mentioned above, click on Start and enter Bryce in the Search programs and files box.  You should then see every instance of Bryce on your computer.  Note the path so you can go there through Computer on the Start Menu.  Also, if you let install wizard install Bryce on your Start Menu, you can click on Start and you should see the Bryce icon there.
 Signature
If you constantly look backward, it’s guaranteed you’ll run into something on your forward journey.
Profile
Posted: 14 November 2012 12:29 PM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2011-06-17
ok, I got it. I forgot to download the main program when I downloaded everything else, duh. Looks cool, can’t wait to see what I can come up with.
Profile
