Digital Art Zone
2 of 2
2
does anyone know of a hair that can look like this?
Posted: 17 November 2012 10:38 AM   [ Ignore ]   [ # 16 ]
Member
Avatar
Rank
Joined  2010-06-12
I was thinking that - about the trans map that is.
I will post when I find out more.
Profile
Posted: 17 November 2012 04:59 PM   [ Ignore ]   [ # 17 ]
Member
Avatar
Rank
Joined  2008-02-24
luxgabu - 17 November 2012 08:10 AM
OK, so here is an example of it being actually used (wispy bits not removed yet):
Awesome fallen angel!
Profile
Posted: 18 November 2012 07:17 AM   [ Ignore ]   [ # 18 ]
Member
Avatar
Rank
Joined  2010-06-12
Well, I am at a complete loss as to why the wispy bits are appearing.
I am going to go through this hair tutorial before I seriously get into disecting/fixing this hair so that I know something about the basics:
http://www.daz3d.com/forums/viewthread/5646/
Can anyone suggest anything else that is worth consulting?
The hair sort of works but has a lot of problems if you try to push it, but I think it is too good to toss out so I am going to try to make it more usuable for genesis.
Herakleia: The angel is made from all new stuff that I have just bought from RDNA. I am afraid I am buying increasingly from them now.
Profile
Posted: 19 November 2012 01:55 AM   [ Ignore ]   [ # 19 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
Did you look in the material room for Transparency edge and transparency falloff?
 Signature
I like Bryce, DazStudio, Poser and Vue ... in alphabetical order. And I would probably like Carrara too, if I could find the time to become acquainted with it. Peace?
Profile
Posted: 19 November 2012 02:22 AM   [ Ignore ]   [ # 20 ]
Member
Avatar
Rank
Joined  2010-06-12
I am trying to use it in Studio 4.5.1
Should I look for something particular in the surfaces settings?
Profile
Posted: 19 November 2012 04:08 AM   [ Ignore ]   [ # 21 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
OK, DS doesn’t have the above settings (maybe in Shader mixer, but this hair is so old it definitely can’t have shader mixer material).
Hmmmm Opacity Strength is at 100%?
Did you take a look at the Transmap.jpg (whatever it is called, I don’t have that hair)?
Maybe there is some greyish streaks at the outlines?
What about your render settings?
Maybe it is a effect like those lines of UVmaps showing with the elite textures.
Try turning the shading rate down to 0.2 or even 0.1.
 Signature
Profile
Posted: 19 November 2012 05:55 AM   [ Ignore ]   [ # 22 ]
Member
Avatar
Rank
Joined  2010-06-12
Thanks for the suggestions.
I am using the default DAZ shaders, opacity set to 100%.
There is no grey pixels at the top of the transmap for the hair.
I did a render with the rate set to 0.1 as you suggested, the lines almost disappear but not quite.
It would be good to get rid of them but even with them the hair is still usable, whether the lines are noticeable depends on the colour of the hair and the background and how close up you are to the hair in the image.
Of course if you know they are there you can see them, but ...
Attached is a render with standard shader settings to show they still look OK.
Image Attachments
Profile
Posted: 19 November 2012 06:10 AM   [ Ignore ]   [ # 23 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
One thing is sure: you made me put the hair and the styles into my wishlist ... thank you.
I think. wink
 Signature
Profile
Posted: 19 November 2012 06:17 AM   [ Ignore ]   [ # 24 ]
Member
Avatar
Rank
Joined  2010-06-12
I am not going to let this beat me. I would like to rebuild the hair from scratch. It would be a good learning exercise.
Profile
Posted: 19 November 2012 06:21 AM   [ Ignore ]   [ # 25 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
You know how to make hair?
I’ve got some links to tutorials:
http://www.daz3d.com/forums/viewthread/447/#2963
(Scroll down for the tutorials below the Hair fits)
 Signature
Profile
Posted: 19 November 2012 06:25 AM   [ Ignore ]   [ # 26 ]
Member
Avatar
Rank
Joined  2010-06-12
Thanks for the link, I am going to need all the help I can get. Up to now I have been a simple ‘consumer’ and this will be my first effort ‘under the hood’.
Profile
2 of 2
2
