Directory help please!
Hunter63Hunter63 Posts: 0
Hi,
I recently upgraded to 4.5...and then immediately uninstalled it and went back to 3.1.
The directory where I stored all my DAZ files shows up in the DAZ Native directory but when I try to open them I get a directory error message telling me it cannot find the right files and to consult the log file.
(curiously, it does not tell me what to look for in the log file, or what to do with that unknown information.)
I also notice that there is an 'S' on those folders.?
I have tried every conceivable configuration with no luck.
What is going on here?
Thank you for any help and I hope I explained this right.
    You need to have your content folder listed in Edit > Preferences > Directories in DS3. Mine is in Documents/DAZ 3D/Studio3/Content, do you have that listed?
    The stylised 'S' is to tell you that the item is DAZ Studio content, and that symbol only appears when you are looking in a Poser Formats runtime folder.
    Your Poser Formats and DAZ Studio formats directories should both point to the same place, Documents/DAZ 3D/Studio3/Content, or whatever folder you have them stored in. You can look at the log file in Help > View Log File, and you should see an error messgae with the name of the object you were trying to load that generated the error.
    Can you post a screenshot of your Directories in Preferences for both Poser and DS formats?
  • Hunter63Hunter63 Posts: 0
    Both the DAZ and poser directories are identical as shown in the pic.
    I have DAZ installed on my C: hard drive but all my storage on and external drive E:. That wouldn't effect it would it?
    Here is what the log file says...
    +++++++++++++++ DAZ Studio 3.1.1.73 starting +++++++++++++++++
    DAZ Studio Raw Version: 50397513
    Qt Version: 4.5.2
    Running on Windows Unknown, Build 7601, Service Pack 1
    Total Physical Memory: 4095 Mb (4294967295)
    Available Physical Memory: 4095 Mb (4294967295)
    Total Virtual Memory: 4095 Mb (4294836224)
    Available Virtual Memory: 3970 Mb (4163440640)
    Current Memory Usage: 21%
    Tue Nov 13 09:39:02 2012
    Temp folder: C:/Users/Hunter/AppData/Roaming/DAZ 3D/Studio3/temp
    Total temp disk size: 131061 Mb, Available: 48872 Mb
    Locale: en_US
    No translator found.
    Reading style definition C:/GRAPHICS/resources/style/Default.style
    WARNING: .\interface\style\dzstyle.cpp(273): Failed to load style definition file "Default". Loading default style...
    Reading style definition C:/GRAPHICS/resources/style/Nouveau.style
    Creating managers
    Reading help file C:/GRAPHICS/resources/dazhelp.dsh
    Reading help file C:/GRAPHICS/resources/hexbridge.dsh
    Reading help file C:/GRAPHICS/resources/lipsync.dsh
    Reading help file C:/GRAPHICS/resources/optitexcloth.dsh
    Reading help file C:/GRAPHICS/resources/puppeteer.dsh
    WARNING: .\interface\dialogs\dzbasicdialog.cpp(176): No parent specified for DzBasicDialog!
    Scanning import folders
    Scanning content folders
    Supported OpenGL extensions:
    GL_ARB_base_instance : NOT INITIALIZED
    GL_ARB_blend_func_extended : NOT INITIALIZED
    GL_ARB_color_buffer_float : NOT INITIALIZED
    GL_ARB_compatibility : NOT INITIALIZED
    GL_ARB_compressed_texture_pixel_storage : NOT INITIALIZED
    GL_ARB_conservative_depth : NOT INITIALIZED
    GL_ARB_copy_buffer : NOT INITIALIZED
    GL_ARB_depth_buffer_float : NOT INITIALIZED
    GL_ARB_depth_clamp : NOT INITIALIZED
    GL_ARB_depth_texture
    GL_ARB_draw_buffers : NOT INITIALIZED
    GL_ARB_draw_elements_base_vertex : NOT INITIALIZED
    GL_ARB_draw_instanced : NOT INITIALIZED
    GL_ARB_ES2_compatibility : NOT INITIALIZED
    GL_ARB_explicit_attrib_location : NOT INITIALIZED
    GL_ARB_fragment_coord_conventions : NOT INITIALIZED
    GL_ARB_fragment_program
    GL_ARB_fragment_program_shadow
    GL_ARB_fragment_shader
    GL_ARB_framebuffer_object : NOT INITIALIZED
    GL_ARB_framebuffer_sRGB : NOT INITIALIZED
    GL_ARB_geometry_shader4 : NOT INITIALIZED
    GL_ARB_get_program_binary : NOT INITIALIZED
    GL_ARB_half_float_pixel : NOT INITIALIZED
    GL_ARB_half_float_vertex : NOT INITIALIZED
    GL_ARB_imaging : NOT INITIALIZED
    GL_ARB_instanced_arrays : NOT INITIALIZED
    GL_ARB_internalformat_query : NOT INITIALIZED
    GL_ARB_map_buffer_alignment : NOT INITIALIZED
    GL_ARB_map_buffer_range : NOT INITIALIZED
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_occlusion_query
    GL_ARB_occlusion_query2 : NOT INITIALIZED
    GL_ARB_pixel_buffer_object : NOT INITIALIZED
    GL_ARB_point_parameters
    GL_ARB_point_sprite
    GL_ARB_provoking_vertex : NOT INITIALIZED
    GL_ARB_robustness : NOT INITIALIZED
    GL_ARB_sampler_objects : NOT INITIALIZED
    GL_ARB_seamless_cube_map : NOT INITIALIZED
    GL_ARB_separate_shader_objects : NOT INITIALIZED
    GL_ARB_shader_bit_encoding : NOT INITIALIZED
    GL_ARB_shader_objects
    GL_ARB_shading_language_100
    GL_ARB_shading_language_420pack : NOT INITIALIZED
    GL_ARB_shading_language_include : NOT INITIALIZED
    GL_ARB_shading_language_packing : NOT INITIALIZED
    GL_ARB_shadow
    GL_ARB_sync : NOT INITIALIZED
    GL_ARB_texture_border_clamp
    GL_ARB_texture_buffer_object : NOT INITIALIZED
    GL_ARB_texture_compression
    GL_ARB_texture_compression_rgtc : NOT INITIALIZED
    GL_ARB_texture_cube_map
    GL_ARB_texture_env_add
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_crossbar : NOT INITIALIZED
    GL_ARB_texture_env_dot3
    GL_ARB_texture_float : NOT INITIALIZED
    GL_ARB_texture_mirrored_repeat
    GL_ARB_texture_multisample : NOT INITIALIZED
    GL_ARB_texture_non_power_of_two
    GL_ARB_texture_rectangle : NOT INITIALIZED
    GL_ARB_texture_rg : NOT INITIALIZED
    GL_ARB_texture_rgb10_a2ui : NOT INITIALIZED
    GL_ARB_texture_storage : NOT INITIALIZED
    GL_ARB_texture_swizzle : NOT INITIALIZED
    GL_ARB_timer_query : NOT INITIALIZED
    GL_ARB_transpose_matrix
    GL_ARB_uniform_buffer_object : NOT INITIALIZED
    GL_ARB_vertex_array_bgra : NOT INITIALIZED
    GL_ARB_vertex_array_object : NOT INITIALIZED
    GL_ARB_vertex_buffer_object
    GL_ARB_vertex_program
    GL_ARB_vertex_shader
    GL_ARB_vertex_type_2_10_10_10_rev : NOT INITIALIZED
    GL_ARB_viewport_array : NOT INITIALIZED
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_ATI_texture_float
    GL_ATI_texture_mirror_once : NOT INITIALIZED
    GL_S3_s3tc : NOT INITIALIZED
    GL_EXT_texture_env_add
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_bindable_uniform : NOT INITIALIZED
    GL_EXT_blend_color
    GL_EXT_blend_equation_separate
    GL_EXT_blend_func_separate
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract
    GL_EXT_compiled_vertex_array
    GL_EXT_Cg_shader
    GL_EXT_depth_bounds_test
    GL_EXT_direct_state_access : NOT INITIALIZED
    GL_EXT_draw_buffers2 : NOT INITIALIZED
    GL_EXT_draw_instanced : NOT INITIALIZED
    GL_EXT_draw_range_elements
    GL_EXT_fog_coord
    GL_EXT_framebuffer_blit : NOT INITIALIZED
    GL_EXT_framebuffer_multisample : NOT INITIALIZED
    GL_EXTX_framebuffer_mixed_formats : NOT INITIALIZED
    GL_EXT_framebuffer_object : NOT INITIALIZED
    GL_EXT_framebuffer_sRGB : NOT INITIALIZED
    GL_EXT_geometry_shader4 : NOT INITIALIZED
    GL_EXT_gpu_program_parameters : NOT INITIALIZED
    GL_EXT_gpu_shader4 : NOT INITIALIZED
    GL_EXT_multi_draw_arrays
    GL_EXT_packed_depth_stencil : NOT INITIALIZED
    GL_EXT_packed_float : NOT INITIALIZED
    GL_EXT_packed_pixels
    GL_EXT_pixel_buffer_object
    GL_EXT_point_parameters
    GL_EXT_provoking_vertex : NOT INITIALIZED
    GL_EXT_rescale_normal
    GL_EXT_secondary_color
    GL_EXT_separate_shader_objects : NOT INITIALIZED
    GL_EXT_separate_specular_color
    GL_EXT_shadow_funcs
    GL_EXT_stencil_two_side
    GL_EXT_stencil_wrap
    GL_EXT_texture3D
    GL_EXT_texture_array : NOT INITIALIZED
    GL_EXT_texture_buffer_object : NOT INITIALIZED
    GL_EXT_texture_compression_dxt1 : NOT INITIALIZED
    GL_EXT_texture_compression_latc : NOT INITIALIZED
    GL_EXT_texture_compression_rgtc : NOT INITIALIZED
    GL_EXT_texture_compression_s3tc
    GL_EXT_texture_cube_map : NOT INITIALIZED
    GL_EXT_texture_edge_clamp : NOT INITIALIZED
    GL_EXT_texture_env_combine
    GL_EXT_texture_env_dot3
    GL_EXT_texture_filter_anisotropic
    GL_EXT_texture_format_BGRA8888 : NOT INITIALIZED
    GL_EXT_texture_integer : NOT INITIALIZED
    GL_EXT_texture_lod : NOT INITIALIZED
    GL_EXT_texture_lod_bias
    GL_EXT_texture_mirror_clamp : NOT INITIALIZED
    GL_EXT_texture_object
    GL_EXT_texture_shared_exponent : NOT INITIALIZED
    GL_EXT_texture_sRGB : NOT INITIALIZED
    GL_EXT_texture_sRGB_decode : NOT INITIALIZED
    GL_EXT_texture_storage : NOT INITIALIZED
    GL_EXT_texture_swizzle : NOT INITIALIZED
    GL_EXT_texture_type_2_10_10_10_REV : NOT INITIALIZED
    GL_EXT_timer_query : NOT INITIALIZED
    GL_EXT_vertex_array
    GL_EXT_vertex_array_bgra : NOT INITIALIZED
    GL_EXT_import_sync_object : NOT INITIALIZED
    GL_IBM_rasterpos_clip : NOT INITIALIZED
    GL_IBM_texture_mirrored_repeat
    GL_KTX_buffer_region : NOT INITIALIZED
    GL_NV_alpha_test : NOT INITIALIZED
    GL_NV_blend_minmax : NOT INITIALIZED
    GL_NV_blend_square
    GL_NV_complex_primitives : NOT INITIALIZED
    GL_NV_conditional_render : NOT INITIALIZED
    GL_NV_copy_depth_to_color
    GL_NV_copy_image : NOT INITIALIZED
    GL_NV_depth_buffer_float : NOT INITIALIZED
    GL_NV_depth_clamp
    GL_NV_explicit_multisample : NOT INITIALIZED
    GL_NV_fbo_color_attachments : NOT INITIALIZED
    GL_NV_fence
    GL_NV_float_buffer
    GL_NV_fog_distance
    GL_NV_fragdepth : NOT INITIALIZED
    GL_NV_fragment_program
    GL_NV_fragment_program_option : NOT INITIALIZED
    GL_NV_fragment_program2
    GL_NV_framebuffer_multisample_coverage : NOT INITIALIZED
    GL_NV_geometry_shader4 : NOT INITIALIZED
    GL_NV_gpu_program4 : NOT INITIALIZED
    GL_NV_half_float
    GL_NV_light_max_exponent
    GL_NV_multisample_coverage : NOT INITIALIZED
    GL_NV_multisample_filter_hint
    GL_NV_occlusion_query
    GL_NV_packed_depth_stencil
    GL_NV_parameter_buffer_object : NOT INITIALIZED
    GL_NV_parameter_buffer_object2 : NOT INITIALIZED
    GL_NV_path_rendering : NOT INITIALIZED
    GL_NV_pixel_data_range
    GL_NV_point_sprite
    GL_NV_primitive_restart
    GL_NV_register_combiners
    GL_NV_register_combiners2
    GL_NV_shader_buffer_load : NOT INITIALIZED
    GL_NV_texgen_reflection
    GL_NV_texture_barrier : NOT INITIALIZED
    GL_NV_texture_compression_vtc
    GL_NV_texture_env_combine4
    GL_NV_texture_expand_normal
    GL_NV_texture_lod_clamp : NOT INITIALIZED
    GL_NV_texture_multisample : NOT INITIALIZED
    GL_NV_texture_rectangle
    GL_NV_texture_shader
    GL_NV_texture_shader2
    GL_NV_texture_shader3
    GL_NV_transform_feedback : NOT INITIALIZED
    GL_NV_vertex_array_range
    GL_NV_vertex_array_range2
    GL_NV_vertex_buffer_unified_memory : NOT INITIALIZED
    GL_NV_vertex_program
    GL_NV_vertex_program1_1 : NOT INITIALIZED
    GL_NV_vertex_program2 : NOT INITIALIZED
    GL_NV_vertex_program2_option : NOT INITIALIZED
    GL_NV_vertex_program3 : NOT INITIALIZED
    GL_NVX_conditional_render
    GL_NVX_gpu_memory_info : NOT INITIALIZED
    GL_OES_depth24 : NOT INITIALIZED
    GL_OES_depth32 : NOT INITIALIZED
    GL_OES_depth_texture : NOT INITIALIZED
    GL_OES_element_index_uint : NOT INITIALIZED
    GL_OES_fbo_render_mipmap : NOT INITIALIZED
    GL_OES_get_program_binary : NOT INITIALIZED
    GL_OES_mapbuffer : NOT INITIALIZED
    GL_OES_packed_depth_stencil : NOT INITIALIZED
    GL_OES_rgb8_rgba8 : NOT INITIALIZED
    GL_OES_standard_derivatives : NOT INITIALIZED
    GL_OES_texture_3D : NOT INITIALIZED
    GL_OES_texture_float : NOT INITIALIZED
    GL_OES_texture_float_linear : NOT INITIALIZED
    GL_OES_texture_half_float : NOT INITIALIZED
    GL_OES_texture_half_float_linear : NOT INITIALIZED
    GL_OES_texture_npot : NOT INITIALIZED
    GL_OES_vertex_array_object : NOT INITIALIZED
    GL_OES_vertex_half_float : NOT INITIALIZED
    GL_SGIS_generate_mipmap : NOT INITIALIZED
    GL_SGIS_texture_lod : NOT INITIALIZED
    GL_SGIX_depth_texture : NOT INITIALIZED
    GL_SGIX_shadow : NOT INITIALIZED
    GL_SUN_slice_accum : NOT INITIALIZED
    GL_WIN_swap_hint : NOT INITIALIZED
    WGL_EXT_swap_control
    : NOT INITIALIZED
    WGL_ARB_buffer_region
    WGL_ARB_create_context : NOT INITIALIZED
    WGL_ARB_create_context_profile : NOT INITIALIZED
    WGL_ARB_create_context_robustness : NOT INITIALIZED
    WGL_ARB_extensions_string
    WGL_ARB_make_current_read : NOT INITIALIZED
    WGL_ARB_multisample : NOT INITIALIZED
    WGL_ARB_pbuffer
    WGL_ARB_pixel_format
    WGL_ARB_pixel_format_float : NOT INITIALIZED
    WGL_ARB_render_texture
    WGL_ATI_pixel_format_float
    WGL_EXT_create_context_es2_profile : NOT INITIALIZED
    WGL_EXT_extensions_string
    WGL_EXT_framebuffer_sRGB : NOT INITIALIZED
    WGL_EXT_pixel_format_packed_float : NOT INITIALIZED
    WGL_EXT_swap_control_tear : NOT INITIALIZED
    WGL_NVX_DX_interop : NOT INITIALIZED
    WGL_NV_DX_interop : NOT INITIALIZED
    WGL_NV_DX_interop2 : NOT INITIALIZED
    WGL_NV_float_buffer
    WGL_NV_multisample_coverage : NOT INITIALIZED
    WGL_NV_render_depth_texture
    WGL_NV_render_texture_rectangle
    : NOT INITIALIZED
    OpenGL features for current hardware:
    OpenGL provider: NVIDIA Corporation
    OpenGL renderer: GeForce GTS 250/PCIe/SSE2
    OpenGL version: 3.3.0
    Maximum number of lights: 8
    Number of auxiliary buffers: 4
    Number of texture units: 4
    Depth buffer bit resolution: 24
    Maximum OpenGL texture size: 8192 x 8192
    Current OpenGL Texture Quality Setting: Good Performance
    RGBA color bitplane resolutions: 8 8 8 0
    GLSL version: 3.30 NVIDIA via Cg compiler
    Shadow mapping supported
    VBO supported
    Clearing the Scene...
    *** Scene Cleared ***
    Loading plugins:
    aniMatePlusLite.dll
    daznews.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzautoriggerbasic.dll
    dzautoshaderbakeractions.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzdelightrenderer.dll
    dzdformeditor.dll
    dzdynlod.dll
    dzeasyloader.dll
    dzfbxexporter.dll
    dzfiguremixer.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzmanualshaderbaker.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzobjexporter.dll
    dzoptitexclothbasic.dll
    dzprimitives.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzquickstart.dll
    dzrenderedit.dll
    dzsavefilters.dll
    dzsceneinfo.dll
    dzscriptedrenderer.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadermixerbase.dll
    dzshadermixergui.dll
    dzspotrendertool.dll
    dzstartupwizard.dll
    dzu3dexporter.dll
    dzwinvideo.dll
    dzmimicbasic.dll
    dzpowerpose.dll
    Could not activate Auto Shader Baker Actions evaluation. Plugin disabled.
    Could not activate FBX Exporter evaluation. Plugin disabled.
    Could not activate Figure Mixer evaluation. Plugin disabled.
    Could not activate Map Transfer evaluation. Plugin disabled.
    Could not activate Morph Follower evaluation. Plugin disabled.
    Could not activate Scripted 3Delight Renderer evaluation. Plugin disabled.
    Could not activate Shader Baker evaluation. Plugin disabled.
    Could not activate Shader Builder evaluation. Plugin disabled.
    Could not activate Shader Mixer evaluation. Plugin disabled.
    Total class factories: 694
    WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
    3D mouse support library could not be loaded.
    Creating interface
    Successfully created OpenGL viewport for view1.
    Successfully created OpenGL viewport for view2.
    Successfully created OpenGL viewport for view3.
    Successfully created OpenGL viewport for view4.
    Executing startup script...
    Started in: C:/GRAPHICS
    DAZ Studio Started
    Creating Pixel Buffer
    Pixel buffer - Width: 1024 Height: 1024
    Compiling OpenGL Shader...
    Fragment Shader:
    Fragment Shader compiled successfully.
    Linking Shader:
    Fragment info
    0(29) : warning C7050: "rgb" might be used before being initialized
    Shader Program successfully linked.
    --------------- DAZ Studio 3.1.1.73 exited ------------------
    Qt Version: 4.5.2
    Current Memory Usage: 25%
    Tue Nov 13 09:40:52 2012
    Total temp disk size: 131061 Mb, Available: 48871 Mb
    Locale: en_US
    Creating managers
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_point_sprite
    GL_ARB_shadow
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_blend_color
    GL_EXT_blend_minmax
    GL_EXT_Cg_shader
    GL_EXT_fog_coord
    GL_EXT_shadow_funcs
    GL_EXT_stencil_wrap
    GL_EXT_texture3D
    GL_EXT_vertex_array
    GL_NV_blend_square
    GL_NV_depth_clamp
    GL_NV_fence
    GL_NV_float_buffer
    GL_NV_fog_distance
    GL_NV_half_float
    GL_NV_point_sprite
    : NOT INITIALIZED
    WGL_ARB_pbuffer
    WGL_NV_float_buffer
    : NOT INITIALIZED
    VBO supported
    Loading plugins:
    aniMatePlusLite.dll
    daznews.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzdformeditor.dll
    dzdynlod.dll
    dzeasyloader.dll
    dzfbxexporter.dll
    dzfiguremixer.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzobjexporter.dll
    dzprimitives.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzquickstart.dll
    dzrenderedit.dll
    dzsavefilters.dll
    dzsceneinfo.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzstartupwizard.dll
    dzu3dexporter.dll
    dzwinvideo.dll
    dzmimicbasic.dll
    dzpowerpose.dll
    Creating interface
    DAZ Studio Started
    Fragment Shader:
    Linking Shader:
    Fragment info
    WARNING: .\general\dzhelpmgr.cpp(410): NULL pointer passed to DzHelpMgr::setOnlineHelp()
    Opening file CUrved Picture.daz...
    Reading CUrved Picture.daz
    Unable to find file for storable: data/3_0/TREELINE_28/TREELINE_28/TREELINE.dso
    File read time: 0 min 0.0 sec.
    Building Scene...
    Ran tdlmake on image E:/HUNTER
    600 x 431 - 40K
    The only bit we needed to see was this
    Opening file CUrved Picture.daz…
    Building Scene…
    The 'Cannot find file for storable...' means that your 'data' folder is not where DS thinks it is, and it is not available to look at.
    Any .DAZ file that is saved, writes the geometry, amongst other things, to the data folder, and it needs access to that in order to reload the scene. Have a look inside E:/Content to see if there is a folder called 'data', if not, you will need to do a dearch for the data folder to find out where it is.
    You could open a new scene with the item treeline_28 in it, save it, and the older scene file may open for you, but I think there are probably other things missing as well. Can you create a new scene, and get it to open?
    No, I cannot save a new file and re-open it.
    How do I tell DAZ where to look for the data file? I see it in my contents directory and it is full of files.
    Have you recently changed the paths in Preferences? The entry you have should work, was it ever any different to that?
    Can you show a screenshot of the collapsed view of your E;\Content folder, showing what it contains? Is the 'data' folder directly under E:\content? For example E:\content\data. If so it is baffling me.
    Can you do a search on your machine for 'data', and see where the folder actually is, because DS3 will have created one.
    Ah ha!
    I copied my data folder from my E/ Directory and merged it with the data file in the DAZ program and everything seems to be back to normal. Woo Hoo!
    I cannot thank you enough for helping me overcome my blind stupidity.
    THANK YOU! THANK YOU! THANK YOU!
    You are most welcome.
    I am still not sure what is going on, but if it works, that is the main thing. :)
