What is "IK"?
desperadodesperado Posts: 59
Every now and then I come across a product that gives the option to turn IK on or off. What is IK? and what does it do or not do? And, is it possible to turn it on/off at will? If so, how?
    Right click on the figure in the Viewport, and you can Enable or Disable IK in there.
    Inverse Kinematics, this will tell you more than I ever could : http://en.wikipedia.org/wiki/Inverse_kinematics
    Just think of 'the thigh bone's connected to the knee bone ...' etc etc.
  • desperadodesperado Posts: 59
    Thnkns for the prompt response. I'll try to make some heads or tails out of it and see if it affects anything i do. :O}
  • SzarkSzark Posts: 10,184
    You use this for posing. With IK and using the Active Pose Tool (Alt+Shift+P or Tools > Active Pose) if you grab the hand (hold mouse over the hand and move) the arm, shoulder etc will move with the hand. Same for any body part. You can also Pin for example the feet or foot so it doesn't move, unless you go too far then it will move when pinned.
  • cridgitcridgit Posts: 982
    Without IK, you need to pose the hip, then the abdomen, then the chest, then the shoulder, then the upper arm, then the lower arm. And THEN you find the hand is in totally the wrong place. So you start again, aaargh!
    IK allows you to pose "in reverse" by propagating joint movement "up" the skeleton. That allows you to pose hands and feet while IK ensures arms and legs reflect natural human body movement.
  • dawgzangdawgzang Posts: 0
    This was very helpful. Is there a way to have this set as a default when you first open Daz?
    Good question mine is always on when I load a figure, so I think it is on at default. I just tried to turn it off via Edit > Figure > Inverse Kinematics > checked off....restarted Daz Studio and it is back on.
  • SertorialSertorial Posts: 952
    I never pose my figures by, say, pulling a hand to where I want it because the whole figure then moves as well. This messes up all my careful positioning of the body. So I always pose joint by joint, using the sliders for "bend" "twist" etc.
    Doesn't everyone do it that way, then?
    Is there a better way of posing?
    From your description, though, I can't really see how you would pose a figure using IK, since you can only drag a body part in two dimensions using a mouse (as you are moving in the plane of the screen). Or have I missed the point?
  • NovicaNovica Posts: 17,614
    ZOOM.
    I spent hours doing a hand, every finger immaculate- only to discover if I turned off the body parts blocking my view so I could zoom in, I zipped right along on the second hand when compared to the first. It works on all body parts, the closer you get, the easier it is to pose (or at least for me, but I'm just a newbie.)
    And I actually enjoy clicking and dragging, and seeing what happens. Sometimes I was getting better poses than what I had in mind! Happy accidents that were worthwhile to consider, lol.
    When using IK you can PIN a body part so it doesn't move but it will move if the pose you are making gets past the point were the pinned body parts has to move but it does work nicely. How to Pin body parts http://www.daz3d.com/forums/discussion/19414/
    Generally I do the long hard way by doing it all myself bone by bone. Or I start with a pose preset that gets me close then I refine it. The is no wrong or right way just good and bad posing. :)
    edited April 2013
    Thanks, but I am apparently not allowed to view that link :(
    The following errors were encountered
    You are not authorized to view this forum
    Post edited by Sertorial on
    Dur yeah sorry it is in the PC section of the forum. Here is what I was linking to
    Szark said:
    Any of the Translation tools will show the Pinning Icon Richard. Rotation, translation, Scaling and the Universal except the Node Selection tool.
    Here I have the translation tool selected, selected the foot and clicked on the Pin Icon shown in the image below,
    505 x 327 - 74K
    Thanks.
    "PC" section? politically correct section? police controlled section? private and cool section?
    Problem children more like...only joking Platinum Club members before you beat me up and down the forums. :P
