Is there a "best" uv map to use as your source to do conversions from?
Zev0Zev0 Posts: 5,244
I'm wondering if it matters what uv set you convert from? Eg does M4 converted to V4 give better results or Does V4 to M4 give better results? I plan on doing a couple of conversions via daz's map transfer, and was just wondering does it matter what source you transfer from? Or are the results all the same? I need to know so I'll have a UV set base to use as my primary and transfer to various other uv's such as m5 and V5. I am aware of the seam issues, that I know how to fix. It's the accuracy of the translation data I am interested in. If they are all the same then even better. Thanks.
