Digital Art Zone
Walk Designer
Posted: 11 November 2012 06:52 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2011-01-13
How do i load the animation files from Walk Designer for M4 and V4 in DS? I can only find the poses/
 Signature
An expert is just an experienced novice.
Profile
Posted: 11 November 2012 07:04 PM   [ Ignore ]   [ # 1 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Time for a refund bro, those are POSER only for FULL features. They might work in Carrara but I do not know if they do or not.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 11 November 2012 07:39 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
Haven’t triedit in Carrara yet. I have a habit of building my scenes in DS and then rebuilding in C8Pro. I couldn’t find any walk cycles that look casual.
 Signature
Profile
Posted: 12 November 2012 01:03 AM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2012-06-11
I’m not sure what the issue is. The poses are animated and do work in DS. I understand there’s functionality beyond that not included in DS, but it sounds like you just want a casual walk cycle.
Profile
Posted: 12 November 2012 01:20 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
Yes, I do. But I only found the static poses in my Poses folder.
 Signature
Profile
Posted: 12 November 2012 02:12 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2012-06-11
Are the poses you speak of found under My Library\Runtime\libraries\Pose\WalkDesigner, and have you tried clicking on various frames of the timeline after applying one of the poses? No keyframes are added, so it might look like there isn’t an animation being added, but in my experience, there is.
If yes to the above and it’s still just a static pose, then I’m not sure what’s up.
Profile
Posted: 12 November 2012 03:21 AM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
try looking under pose/universal poses for the animations
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 12 November 2012 07:50 AM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI LOH smile
The walk designer files should be placed “automatically” into a Poser Format’s folder,. inside (Poses) called “Walk designer”
The Basic animation can be used in either DS or Carrara,. but only poser has an actual animation mixer, (walk designer)
which allows you to create a new walk style, by mixing values of the pre-set animations, plus any custom walk animations you’ve made.
smile
Profile
