Digital Art Zone
1 of 2
1
How do you install Darkside Style/Layout to DS 4?  SOLVED!!!
Posted: 09 November 2012 09:40 PM   [ Ignore ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
OK, I’ve finally installed DS 4 64-bit to my newish laptop, but I’m having a problem installing the Darkside Style/Layout addon.
First I’m on Win7 Pro with XP Mode, and I don’t install any software to Program Files or Program Files (x86).  Instead I install to folders at the root of C:\ called 2D Applications and 3D Applications.
That said, the Darkside installer only asks if I want Start Menu shortcuts or an Uninstaller when I choose Customize Install, but it doesn’t ask where I have DS 4 installed.
Needless to say, nothing’s happening.  Anyone have any ideas on how to get this installed to my DS 4 installation?  Any and all suggestions, tips or workarounds would be greatly appreciated, as I really hate the look of DS 4 by default.
 Signature
OK . . . Where’s my chocolate?     Post Count —> 3,263 and growing!     Visit my Renderosity Gallery
It’s what you learn after you know it all that counts ~ John Wooden
Profile
Posted: 09 November 2012 10:35 PM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
I think depending which version you have Darkide could already be installed with the program….did you look in Window > Style > Select Style to see if it is there already.
If not from memory I don’t think it asks where to install as it will read from the registry where Daz Studio is installed. Mind you it has been a while.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 10 November 2012 08:53 AM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
That’s the problem in a nutshell Pete.  I installed DS 4A and it’s only included with DS 4P.  You are correct that it doesn’t ask where to install, and it’s obviously not reading the installation path from the registry, so now I’m stuck without it unless someone else has had this problem and found a way to overcome it.  I so hate the default look of DS 4.
 Signature
Profile
Posted: 10 November 2012 01:17 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Have you installed DS4.5 Pro? I’m not sure what would happen if you entered your Advanced serial number, but I’m not sure it would matter (the only thing the free pro serial doesn’t give you is Decimator, and I don’t think Advanced had that either).
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 10 November 2012 02:13 PM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
Decimator’s listed on that popup that shows plugins that you have to enter serial numbers for, but then again, I would assume whichever s/n you use, that would allow for certain plugins to become active when you enter the appropriate s/n for it.
My problem is, I don’t want to deal with 4.5 Pro at this point as I’m not ready to deal with file formats other than what I’m used to in the older versions.  At least for now.  I do think, however, I can add the DS 4 Pro s/n I have and see if that works.  I don’t recall now if there was a separate s/n issued when DS 4.5 Pro update came out.  I downloaded it, but keep it in a separate folder from the original DS 4.0.  If it’s the same s/n for both Pro versions, then that may be my answer.  I’ll try that and see what happens.
 Signature
Profile
Posted: 10 November 2012 02:14 PM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
I remember when I purchased DS4Advanced and I did have to install Darkside seperately and yes no Decimator for any version.
 Signature
Pete
My Render Thread
Profile
Posted: 10 November 2012 03:43 PM   [ Ignore ]   [ # 6 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
Well I tried the DS 4 Pro s/n but that only opened up all but the Decimator, and I think aniMate2 plugins.  I just don’t understand why the Darkside installer isn’t working unless, and this is a guess on my part, it’s because I install my apps in locations other than C:\Program Files for 64-bit, and C:\Program Files (x86) for 32-bit.  I would’ve thought your initial comment about the registry directing it to the install would work a treat, but it didn’t, and the uninstaller it’s supposed to create doesn’t exist even though the Start Menu folder has a shortcut that states it’s in the C:\ root directory.  Either it doesn’t really install, or it’s lost somewhere and I just don’t feel like searching the whole hard drive for it.
Anyway, I guess no one else has come across this problem, so I may give DAZ a call during the week and see if they have any suggestions.  Why they didn’t do what they did with the plugins and just make it available to those with the proper s/n, I don’t know, but they must’ve had some reason for it.  ~sigh~
 Signature
Profile
Posted: 10 November 2012 03:55 PM   [ Ignore ]   [ # 7 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Sorry I am no help Miss B and yes I have never come across this.
On a side note I never ever install Daz Studio in Program Files, yeah I know folks do and it is ok if it is just the software and not content and in doing so I hardly get any content or installing issues…only crashing at render time…still. But I might as well face facts that it is my old computer after all seeing I can’t get a cleaner install than I have now.32bit with 3 GB of ram is no good for how I used to use Daz Studio so I am back with 3A.
 Signature
Pete
My Render Thread
Profile
Posted: 10 November 2012 04:10 PM   [ Ignore ]   [ # 8 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Pro and Advanced of a given version use the same file formats - the difference is only in which add-ons are activated (and available fro download). Older versions of DS didn’t include the Darkside style - exactly which version are you using?
 Signature
Profile
Posted: 10 November 2012 04:50 PM   [ Ignore ]   [ # 9 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
DS 4.0.3.47, which I first registered with the “Advanced” serial number, and then I re-registered it with the “Pro” serial number which, as you stated, opened up all but the Decimator and aniMate2 plugins.
I’ve been using DS 3 Advanced on this laptop since I got it the beginning of the year, and I know it and DS 2 (which I used on my old laptop) didn’t come with Darkside.
 Signature
Profile
Posted: 10 November 2012 05:40 PM   [ Ignore ]   [ # 10 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
I’m pretty sure 4.0.3.47 had Darkside built in.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Profile
Posted: 10 November 2012 06:20 PM   [ Ignore ]   [ # 11 ]
Active Member
Avatar
RankRank
Joined  2003-12-06
Miss B - 10 November 2012 04:50 PM
It wasn’t needed back then — the Darkside style is apparently the closest we’re ever going to get to the old Classic style, which wasn’t included in D|S4 and many people have been asking, begging and pleading for it ever since. DAZ just doesn’t want to know.
FWIW, the separate Darkside installer is only for D|S versions that don’t have it incorporated in the main program installer — if you run it after installing a D|S version that includes it, you’ll overwrite the files with possibly older ones that might not work. If anyone’s done that by mistake, the only solution is to re-install D|S.
 Signature
Gone to Vegas to play poker. Back when I run out of clothes.—Your Muse.
Profile
Posted: 10 November 2012 07:31 PM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2010-06-18
Hi Miss B…
DS 4.0.3.47 does not have the Darkside style built in, so you do need to run the separate installer. I think Darkside_1.2_ds was the last one before it was built in to the DS installer…
Just to see if your install path was the problem, I installed 4.0.3.47 on another laptop I have, and installed it to C:\DAZ instead of Program Files… and then ran the Darkside installer, choosing custom…
In the Installation Summary window you should see the install path for DS 4, it should look like this…
  DAZ Studio 4.x Files Path:C:\ your path
If the field is blank, then the Darkside will not install, even though the installer completes… If it shows a different path, navigate to that location after the installer completes and look for the file Darkside.style, and move that to the resources\style folder in the folder that you installed DS 4 to…
For my test install, it did install the Darkside to the correct path and is available and working in DS 4
The only difference between my install and yours is that the laptop I used is 32 bit Win 7 Home and not running XP mode, so I installed the 32 bit DS… I don’t know how much if any difference that makes though…
I hope you get it sorted out… smile
Profile
Posted: 10 November 2012 09:50 PM   [ Ignore ]   [ # 13 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
niccipb - 10 November 2012 07:31 PM
This is the problem!!!  The only thing I have when I click Custom Install is 3 checkboxes for shortcuts in the Startup Menu and the Desktop, and to create the Uninstaller.  I’m NOT getting the path box with a “browse” button.  If that were the case I wouldn’t have a problem.
I have two installers, the older one I got when I bought DS 4A and it was called DarksideTheme_1.2.  The newer one I got with DS 4P and it’s called Darkside_1.2.  Neither of them have that path field.  Sot it seems that it’s the installer that’s the problem and not where I installed DS 4.  Sheesh.  I’ll reset my downloads again, because I’m not sure whether it’s been corrupted.  I’ll have to see.
Thanks for at least letting me know I’m not going crazy.
 Signature
Profile
Posted: 10 November 2012 10:17 PM   [ Ignore ]   [ # 14 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
OK, I was wrong, there is a “path” field, but it doesn’t say “DAZ Studio 4.x Files Path”.  It says, “Start Menu Folder: DAZ 3D\Installed Content\Darkside”, so I still can’t install it.  This is very weird.
Here’s a screenshot of what I’m seeing when I click on Custom Install.
Image Attachments
 Signature
Profile
Posted: 10 November 2012 11:19 PM   [ Ignore ]   [ # 15 ]
Active Member
Avatar
RankRank
Joined  2010-06-18
Hi…
When you click Next you should see the Installation Summary like the pic below. The path should be to where DS 4 is installed… if not, then that’s why it’s not installing… I don’t know why it’s not reading your DS install path
nicci… smile
edit: this pic was from my 4.5 computer, but it is the same on the 4.0 install I did…
edit2: the installer doesn’t ask for your DS4 install path, it just finds it and displays it in the summary box… you can’t change it
Image Attachments
Profile
1 of 2
1
