Digital Art Zone
Does anyone know how to make objects glow?
Posted: 09 November 2012 09:10 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2005-05-03
I want to make glowing insects and other creatures, I assume there must be a way to do this in Daz but all I could find doing a google search was how to make a ball of light
Thanks
Profile
Posted: 09 November 2012 09:34 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2005-12-31
The common and easiest answer is to ramp up the ambient in the surface settings.You may have to adjust the color as well because it tends to “fade”. The second less easy answer is to use the uberarea light shader in light presets/omnifreaker. Those actually cast light but you may have to play with the surface settings some to get it to look the way you want.
Profile
Posted: 09 November 2012 09:36 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2005-11-27
Did you search under “Daz Studio ambient glow”? You might find something helpful then.
Profile
Posted: 09 November 2012 10:18 PM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
One way would be the approach in this thread…
http://www.daz3d.com/forums/viewthread/5958/
I’ll see if I can whip up a simple brick set up to post since, there wasn’t one posted in that thread.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 09 November 2012 11:34 PM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
If you just want it to glow but not emit light onto other content, then increase your ambient until the glow matches your tastes.
If, on the other hand, you wish for the glow to light other objects in the scene, you can apply the UberAreaLight on the surface you wish to emit light (Control-Click to maintain your current textures).  Then adjust the intensity in the “Surfaces” tab.
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 11 November 2012 04:21 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2005-05-03
Thanks everyone for the help, as soon as my machine stops crashing half way through a render I will see if it worked
Sparkles
Profile
Posted: 11 November 2012 06:24 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2011-07-20
If you use the REALITY 2 plugin, it should be real easy. Just select the relevant surfaces and select the option to turn them into light sources.
I’d elaborate more, but my stupid system recently malfunctioned and I had to uninstall DAZ Studio, and now I can’t recall the details…
Profile
