Digital Art Zone
1 of 3
1
How do I turn on the Content Management Service?
Posted: 09 November 2012 01:25 PM   [ Ignore ]
Member
Rank
Joined  2005-09-22
Mine doesn’t seem to be working & it isn’t in the task manager either.I tried uninstalling & re-installing & still isn’t running.I’m on a 64 bit ,Win7 laptop though I have the 32 bit installed.I was curious how to get this running as I’d like to try to figure this out:)
 Signature
May the hands of fate be kind to you & yours. smile
Profile
Posted: 09 November 2012 01:31 PM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
If you are on Windows, go to the Start menu and there under DAZ3D should be a command to Start CMS
Image Attachments
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 09 November 2012 01:51 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2005-09-22
Szark - 09 November 2012 01:31 PM
thanks very much. now to figure how to set it up for things to be visible there smile
 Signature
Profile
Posted: 09 November 2012 01:53 PM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
My pleasure guardian angel 671
 Signature
Pete
My Render Thread
Profile
Posted: 09 November 2012 01:58 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2005-09-22
Szark - 09 November 2012 01:53 PM
think i’m not meant ta use it -it still refuses to show up in either my ds or my task manager.
 Signature
Profile
Posted: 09 November 2012 02:11 PM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Make sure your firewall is not blocking it.
 Signature
Pete
My Render Thread
Profile
Posted: 09 November 2012 02:30 PM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2005-09-22
Szark - 09 November 2012 02:11 PM
I think I’m using windows firewall-how do I set that not to block the CMS?
 Signature
Profile
Posted: 09 November 2012 04:46 PM   [ Ignore ]   [ # 7 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Windows 7 or Vista?
Vista Go to the Control Panel > Security > Windows Firewall > Allow a Program Through Wndowss Firewall and naviagte to CMS and hit accept/ok
 Signature
Pete
My Render Thread
Profile
Posted: 09 November 2012 08:41 PM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2005-09-22
Szark - 09 November 2012 04:46 PM
Windows 7 or Vista?
windows 7, I think I got it added but it still refuses to run & it does not show in task manager.Would it affect it if my DS4.5 is located on an external harddrive?
 Signature
Profile
Posted: 09 November 2012 08:47 PM   [ Ignore ]   [ # 9 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
guardian angel 671 - 09 November 2012 08:41 PM
Windows 7 or Vista?
It shouldn’t matter if DS4.5 is installed on an external drive, as long as you installed it on this system.  Did you have earlier versions of DS4 installed?  CMS doesn’t get uninstalled when you update DS4, so you may have an old version.  If you uninstall CMS using “Start > Programs > DAZ 3D > DAZ Content Management Service > Uninstall CMS”, then reinstall DS4.5 you’ll get the latest CMS.  If that doesn’t solve it, what other security software are you running?
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Profile
Posted: 09 November 2012 08:53 PM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  2005-09-22
fixmypcmike - 09 November 2012 08:47 PM
Windows 7 or Vista?
I did uninstall it thru the control panel so I’m hoping any older copies were removed. I have Avast & Malwarebytes on my system & the
User Account Control is set at the default area.I did a reinstall with ds4.5 today trying ta solve this -no luck
 Signature
Profile
Posted: 09 November 2012 10:12 PM   [ Ignore ]   [ # 11 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
I would try going offline and deactivating Avast, and see if that resolves the problem—if it does, then we can try to find out how to configure Avast to allow CMS.
 Signature
Products In Zips
Profile
Posted: 09 November 2012 10:59 PM   [ Ignore ]   [ # 12 ]
Member
Rank
Joined  2005-09-22
fixmypcmike - 09 November 2012 10:12 PM
k i’ll try that in the morning:)
 Signature
Profile
Posted: 10 November 2012 07:36 AM   [ Ignore ]   [ # 13 ]
Member
Rank
Joined  2005-09-22
nope i get same results even after disabling the avast.
 Signature
Profile
Posted: 10 November 2012 03:48 PM   [ Ignore ]   [ # 14 ]
Addict
Avatar
RankRankRankRank
Joined  2011-10-04
In my case, I noticed that for some reason CMS has started to die and leave me sans Smart Content. This is probably related to Windows Update pertaining to some .dll redistributable thingies…
 Signature
Thanking: M F M for a gift of dragons!
My DeviantArt page.
My DAZ Studio 4 freebies.
Profile
Posted: 10 November 2012 04:38 PM   [ Ignore ]   [ # 15 ]
Power Member
RankRankRank
Joined  2005-09-05
Skiriki - 10 November 2012 03:48 PM
I’ve had problems with the CMS stopping as I boot up DS…I’m still trying to work it out and I’m seriously considering using the other options.
And yes I just did a windows update but I was having problems prior to that. I’d been beta testing the garibaldi plugin and it crashed. I haven’t been able to get 4.5 to work since then despite lots of clean reinstalls. : ((
 Signature
Shadermixer tutorials and recipes
My Website
My ShareCG Gallery
Shadermixer Documents
Profile
1 of 3
1
