Digital Art Zone
Order 100002393 - failure to download
Posted: 23 May 2012 10:19 AM   [ Ignore ]
New Member
Joined  0
Hi,
    I have tried 3 times to donwload the Ultralight Poser for Windows file and each time it fails with an item not found error message.
I have tried contacting support and get another page not found.  On the invoice there is a contact e-mail which I also tried but got a delivery failure.  Now at last I can post on forums perhaps rhis can be looked at.
This is the e-mail I sent to .(JavaScript must be enabled to view this email address)
Hi,
    I have not been able to download one item from my order that I placed on your new site.  The error seems site related - unable to locate file.
The item is 14292 Ultralight.  I have tried 3 times at different times of the day but the same error occurs each time.  When I try to report this using
the new site I get a ‘page not found’ when I try to register the bug.  I have one last down load attempt left.  Please could you rest my downloads
and investigate the links to this object?  I was trying to download the PC poser version.
PS would it be possible to hide/show just PC/Mac files - the download list is twice as long as it needs to be (4 times if you also add Poser/DS split).
Thanks
Profile
Posted: 23 May 2012 10:21 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2006-03-19
Please contact support at the temperately at this address until zendesk is back up. cs @ daz3d.com. DO to a java error you have to post emails this way. Please take out the spaces before and after @
 Signature
ARTCollaborations Store on DAZ3D
Profile
Posted: 24 May 2012 12:13 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2006-09-16
Interestingly, I’ve been getting exactly the the same issue with exactly the same file. Everything else I’ve downloaded is just fine, but this one I’ve tried multiple times. I’m wondering whether anyone else has had this too. I’ve not contacted support because I’m not desperate to use the item at this time, and I figured it would get fixed.
Profile
Posted: 24 May 2012 04:39 PM   [ Ignore ]   [ # 3 ]
New Member
Joined  0
I have contacted support now.
Profile
Posted: 25 May 2012 05:43 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2011-02-03
Had the same issue with that file they suggested I go to my order history and reset it from there. That seemed to work for me. Just find the ultralight in your Itemized order history list and click on restset in the right hand column. (Hope that helps) Now that being said I can’t get my RHS Stagecoach to download correctly so i can install it even after two resets and Tech support has not answered me yet. Now CS was right on the ball with helping me out no complaints there.
Profile
Posted: 29 May 2012 04:42 PM   [ Ignore ]   [ # 5 ]
New Member
Joined  0
Thanks for the help.  The fix works and I was able to download the file and run it.
Profile
