Where do you find the Create Clothing sub menu in DS 4.5?
If I export clothing from MD2 as cm (DAZ Studio) instead of 8 ft (Poser), the clothing is invisible when I import it into DS. If I export it as Poser (8ft?), then import it as Poser, it’s visible, but loads off center and a bit above where it should. If I move it into place on Genesis, then run the Transfer utility, it pops it back to where it imported.
So ... clearly, this all wrong.
djrenderuser - 08 November 2012 02:35 PM
Here’s what I’ve done so far.
1.) I export the V5 Genesis figure out of Daz Studio in obj format.
2.) I add the obj avatar in MD2.
3.) I simulate the clothing to the imported V5 Genesis avatar.
4.) Then I export out the garment only in obj format.
5.) In Daz Studio I use the “create clothing” sub menu and apply the obj to the Genesis V5 figure.
After I do this the clothing is NOT fitted and the clothing follows the figure. When I look at the parameters “Fit To” setting for the clothing, it says “Genesis”. However, when I change this to “none” the clothing IS fitted BUT it doesn’t follow the figure.
Any ideas? And thanks!
