Digital Art Zone
2 of 2
2
Need Help with UberSurface2
Posted: 08 November 2012 05:12 AM   [ Ignore ]   [ # 16 ]
Member
Rank
Joined  2011-08-05
Yes, applying them with ShaderMixer.
Profile
Posted: 08 November 2012 05:18 AM   [ Ignore ]   [ # 17 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Sorry why with Shader Mixer? Why not use them as intended, just select your surface apply the UberSurface Light Base preset and adjust to taste.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 08 November 2012 05:23 AM   [ Ignore ]   [ # 18 ]
Member
Rank
Joined  2011-08-05
I read a tutorial somewhere in the forums of how to create light emitting surfaces (e.g. to create glowing eyes or something like that). And in this tutorial it was done with the ShaderMixer. And as I am still a bit of a noob ( grin ) I did it exactly this way. But I will also try what you said. Maybe it works better then.
Profile
Posted: 08 November 2012 05:38 AM   [ Ignore ]   [ # 19 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Yes I would use the Base Preset so much easier as it is all there for you in one hit. Just remember to Turn ON Ambient in the Surfaces Pane for the light emitting surface.
 Signature
Pete
My Render Thread
Profile
Posted: 08 November 2012 06:04 AM   [ Ignore ]   [ # 20 ]
Member
Rank
Joined  2011-08-05
Ok, I will try it. Thank you!
Profile
Posted: 08 November 2012 08:46 AM   [ Ignore ]   [ # 21 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Can someone else try US2 “Stucco” with 4.5.1.6?
It is failing against 4.5.1.6 with:
3Delight message #2 (Severity 2): S2103: recompilation of shader ‘C:/Program Files/DAZ 3D/DAZStudio4/shaders/omnifreaker/surface/omUberSurface2.sdl’ failed with code 256
3Delight message #45 (Severity 2): S2068: shader ‘C:/Program Files/DAZ 3D/DAZStudio4/shaders/omnifreaker/surface/omUberSurface2.sdl’ uses a different interface version: please recompile
3Delight message #45 (Severity 2): S2051: cannot load shader ‘omnifreaker/surface/omUberSurface2’, will use ‘defaultsurface’
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 08 November 2012 09:18 AM   [ Ignore ]   [ # 22 ]
Member
Rank
Joined  2010-03-13
Kendall Sears - 08 November 2012 08:46 AM
Kendall
I just tried the specific “Stucco” preset quickly and it is working here. The error message indicates that the automatic recompile is failing, other presets work alright?
Profile
2 of 2
2
