Digital Art Zone
1 of 6
1
DSON Importer for Poser 1.0.0.27 is now available!
Posted: 07 November 2012 03:06 PM   [ Ignore ]
Administrator
Rank
Joined  2007-11-12
DAZ 3D is pleased to announce the release of DSON Importer for Poser, version 1.0.0.27!
What is new in this version? Do I need to update my copy?
The 1.0.0.27 version is a bugfix release. It resolves several issues with the loading and/or handling of DSON format content. All new downloads of the product will be of this version. A change log with additional information can be viewed on the Documentation Center.
The highlights are:
1) This release resolves the “SetGamma” error message popup for Poser 9 users, introduced by the previous release (1.0.0.13), when loading DSON based assets that apply images to a surface.
2) This release fixes loading issues with some saved scenes that the “Transfer Active Morphs” script had been used on.
3) Modified import so that only subd props come in with smooth polygons enabled.
For more information on the previous release (1.0.0.13), see this thread.
Has the Genesis Starter Essentials content been updated too?
No, the Genesis Starter Essentials content that is provided with the product has not been updated. There is no need to download it again if you already have the 1.6 version that came with the initial release.
How do I get the latest version?
If you have previously purchased DSON Importer for Poser, simply locate it within your Itemized Order History and then click the “Reset” link on its immediate right. This will cause new links for downloading the latest version to be added to your My Downloadable Products list.
If this is your first time downloading DSON Importer for Poser, simply follow this link, click the “add to cart” button on the page and then follow the checkout process.
Is there any documentation?
Yes, documentation is located here. Within the User Guide section, you will find information relating to:
- Installation and Requirements
- Using the DSON Importer for Poser
- Converting Content for use with the DSON Importer for Poser
Profile
Posted: 08 November 2012 03:31 PM   [ Ignore ]   [ # 1 ]
New Member
Avatar
Joined  2004-07-06
Daz should be a dear and automatically reset the “DSON Importer for Poser”, for all that have it in their “Itemized Order History”. So that their valued customers, can avoid having to bother with this flawed “Itemized Order History” list
Profile
Posted: 08 November 2012 03:33 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2003-10-09
Do we have to uninstall the previous version or do we just run the .exe again and it will overwrite?
Profile
Posted: 08 November 2012 03:57 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2005-04-05
Kalypso - 08 November 2012 03:33 PM
The installer asks if you want to uninstall and advises you do, I just made sure yes was checked and continued on with the instillation.
Profile
Posted: 08 November 2012 04:03 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2003-10-09
Is there a way in Poser to tell which version of DSON is currently installed or do we have to keep checking our account history for the version number?
Profile
Posted: 08 November 2012 04:19 PM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2007-03-10
Is there any kind of list of which files have been converted to DSON files. For example….The Troll for Genesis has been converted.
Profile
Posted: 08 November 2012 04:19 PM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Nester751 - 08 November 2012 04:03 PM
I can’t see one, but it might be possible to add the version number to the log (as DS does, for example) - you could make a feature request through the bug tracker.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 08 November 2012 04:29 PM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  2003-10-09
Sunfire - 08 November 2012 03:57 PM
Thanks, just installed it too.  I never did have any trouble with it but updated just in case.
Profile
Posted: 08 November 2012 04:30 PM   [ Ignore ]   [ # 8 ]
New Member
Joined  2003-11-08
Thank you DAZ! I just installed the new version of DSON. I have Poser 9 & I am now able to work with Genesis. I’ve found no problems so far. (Knock on wood.) I let it install over my old version & the only change I made was selecting Poser 9 instead of letting it install to the default Poser Pro 2012
Profile
Posted: 08 November 2012 05:03 PM   [ Ignore ]   [ # 9 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Richard Haseltine - 08 November 2012 04:19 PM
I’ve just been given a solution that works now:
Start Poser.
In Poser, go to Scripts>Python Shell
Into the window that opens, type
import dson.dzdsonimporter
and hit return, then type
dson.dzdsonimporter.version(){/code]
(as you type the second line a pop-up will appear with suggestions - once you see the one you want you can double-click on it to avoid having to type the whole thing out, but don’t forget to add the parentheses at the end)
and hit return - the version number of the importer will then be shown.
Image Attachments
 Signature
Profile
Posted: 08 November 2012 06:12 PM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2005-02-25
Very good Richard, easy to understand !!!
 Signature
The Mind on the other side!
http://www.daz3d.com/shop/midnight_stories/
Profile
Posted: 08 November 2012 08:16 PM   [ Ignore ]   [ # 11 ]
Member
Avatar
Rank
Joined  2007-03-10
Oh yeah….it’s working now.
Image Attachments
Profile
Posted: 09 November 2012 12:38 AM   [ Ignore ]   [ # 12 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
pete.c44 - 08 November 2012 04:19 PM
http://www.daz3d.com/shop/dson-all
 Signature
I like Bryce, DazStudio, Poser and Vue ... in alphabetical order. And I would probably like Carrara too, if I could find the time to become acquainted with it. Peace?
Profile
Posted: 09 November 2012 03:24 AM   [ Ignore ]   [ # 13 ]
New Member
Joined  2008-02-27
Glad the new built solves the library problemes some folks had, but when will the broken Poser scaling be fixed ?
With neither the (newly improved) Poser scaling working, nor Genesis’ built in moveable joint centers being directly acessible in Poser, Genesis’ flexibility is severely crippled.
All my characters are created strictly following real world proportions, so I do need a working and fully controlable way to lenghten or shorten limbs, broaden shoulders, re-scale feet and hands, etc.
Scaling works great in Studio and it (finally) works great for every other figure in Poser, too, so what is the problem ?
Profile
Posted: 09 November 2012 07:32 AM   [ Ignore ]   [ # 14 ]
Member
Avatar
Rank
Joined  2007-03-10
Kerya - 09 November 2012 12:38 AM
Thank you, Kerya.
Profile
Posted: 09 November 2012 10:49 AM   [ Ignore ]   [ # 15 ]
Member
Rank
Joined  2003-10-09
Thank you Richard. Will check. Noticed the new newsletter stating it’s been updated again. Hopefully I’ve already got it, but if not, now I have an easy way to check smile
Profile
1 of 6
1
