talihawk - 09 November 2012 12:49 AM
will these shaders only work on the full version of the millennium cat? or will it work on the LE model too?
You will need to own the texture set that these shaders are based on. The file doesn’t contain the texture maps only the network from shadermixer.
IIRC the LE is mapped the same as the full version…it just doesn’t contain the morphs. I can’t swear to it though as it’s been a long while since I’ve looked at the LE version and the shaders were not tested against it. That said I can’t see why it wouldn’t work if you own the texture files. It does contain the displacement map though…
