Digital Art Zone
looking for extreme platform boots - cothurni
Posted: 01 June 2012 05:25 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2010-06-12
These are the boots worn by actors to give them extra height and could have up to 20in thick soles.
The nearest I have found so far is:
http://www.daz3d.com/shop/gothic-couture
I intend to use them on a genesis character so (hopefully) autofit will fit them no matter what character they were originally designed for.
Or would there be another way to get the height effect?
Profile
Posted: 01 June 2012 11:44 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2005-08-03
I have that set and the flatter platform shoes work great. I wouldn’t use autofit unless you’re using the DS4.5 RC as DS4 trashes the morphs. If you’re using DS4.0 you’ll need to use the transfer utility on the shoes to retain the morphs. The shoes DO have morphs on the rfoot/lfoot portions of the tree to make the sole higher or shorter. The bottom 1/4 or so does start bowing outwards though the longer you extend them.
Gen 3 shoes tend to work better with Genesis than Gen 4 shoes do as the zero pose for the feet of the two generations are more similar.
Image Attachments
 Signature
User error.. replace user.
Soft kitty, warm kitty, little ball of fur..
@Deviantart
Profile
Posted: 01 June 2012 12:02 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2010-06-12
Thanks for that info and image.
The product page didn’t mention (to me anyway) that the height/depth of the soles is adjustable and that capability is just what I wanted.
And I am using 4.5 so the autofit should work.
Profile
Posted: 01 June 2012 12:13 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2005-08-03
If you look at the What’s Included tab for the product, you’ll see some of the shoes have a Sole Smaller morph listed. That is the platform height.
 Signature
@Deviantart
Profile
Posted: 01 June 2012 01:17 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2010-06-12
Oh! is that what that meant.
I see it is a Daz item so as soon as I get my PC $6 coupon I will buy it.
Profile
