Saving data with new format. |
| Posted: 01 December 2012 05:41 PM |
[ Ignore ]
[ # 16 ]
New Member
Joined 2009-07-27
thanks alot, that helps.
one more question on 1.
Most convenient way to go for me is MyCustomModifier way, but what asset type should I set to it? Modifier has a special constant for it, but my objects are custom and it seems that existing constants do not fit into the model.
IDzSceneAsset::AssetType MyCustomModifier::getAssetType() const { return ModifierAsset; }
| Posted: 01 December 2012 05:45 PM |
[ Ignore ]
[ # 17 ]
Member
Joined 2010-12-31
Vasily Levin - 01 December 2012 05:41 PM thanks alot, that helps.
| Posted: 02 December 2012 04:22 PM |
[ Ignore ]
[ # 18 ]
New Member
Joined 2009-07-27
still a problem I return owned assets but write write functions are never called; I register my custom type with
DZ_PLUGIN_CLASS_FACTORY( ParticleConnector, PARTICLE_CONNECTOR ); DZ_PLUGIN_CLASS_GUID( ParticleConnectorIO, 50DC77CD-6780-4EA3-BDC6-08D8C0C32684 ); DZ_PLUGIN_REGISTER_MODIFIER_EXTRA_OBJECT_IO( "Particle_connector", ParticleConnectorIO, ParticleConnector );
what am I missing?
thing to note, when it was registered by DZ_PLUGIN_REGISTER_NODE_EXTRA_OBJECT_IO DS crashed on saving scene somewhere on creationg IO object for extra modifier, and there were no any of my functions on stack trace. When I changed this to DZ_PLUGIN_REGISTER_MODIFIER_EXTRA_OBJECT_IO macros crashes gone, but still no writing for those objects.
| Posted: 02 December 2012 05:20 PM |
[ Ignore ]
[ # 19 ]
New Member
Joined 2009-07-27
can I treat
virtual DzError DzAssetExtraObjectIO::finalizeInstance( QObject *object, const DzFileIOSettings *opts ) const;
as PostLoadFile in previos saving scheme?
| Posted: 03 December 2012 10:27 AM |
[ Ignore ]
[ # 20 ]
Member
Joined 2010-12-31
Vasily Levin - 02 December 2012 05:20 PM can I treat
It’s is sort of implied by the header file but yes, finalizeInstance is the last thing called. Like the following
for all
- applyInstanceToObject
for all
- resolveInstance
for all
- finalizeInstance
| Posted: 04 December 2012 11:30 AM |
[ Ignore ]
[ # 21 ]
New Member
Joined 2009-07-27
and what about previous question about write functions never called?
maybe you need more details?
| Posted: 04 December 2012 11:32 AM |
[ Ignore ]
[ # 22 ]
Member
Joined 2010-12-31
Vasily Levin - 04 December 2012 11:30 AM and what about previous question about write functions never called?
That I will have to investigate.
| Posted: 08 December 2012 04:14 PM |
[ Ignore ]
[ # 23 ]
New Member
Joined 2009-07-27
One more strange thing, after loading saved file hierarchy structure is lost, do I have to store it by hand and restore on load?
| Posted: 10 December 2012 10:27 AM |
[ Ignore ]
[ # 24 ]
Member
Joined 2010-12-31
Vasily Levin - 08 December 2012 04:14 PM One more strange thing, after loading saved file hierarchy structure is lost, do I have to store it by hand and restore on load?
I am unsure what you mean by “saved file hierarchy structure”?
| Posted: 10 December 2012 10:33 AM |
[ Ignore ]
[ # 25 ]
New Member
Joined 2009-07-27
I mean that scene I save has Nodes, child nodes, etc, when I load it it flattens to the list of nodes, I do not see how I could screw it since no reparenting is done on load.
So question is is structure is kept automatically and I actually destroy it on load somehow, or I should specifically do something to restore parent-child relations?
| Posted: 10 December 2012 10:54 AM |
[ Ignore ]
[ # 26 ]
Member
Joined 2010-12-31
Vasily Levin - 10 December 2012 10:33 AM I mean that scene I save has Nodes, child nodes, etc, when I load it it flattens to the list of nodes, I do not see how I could screw it since no reparenting is done on load.
I just double checked MyCustomNode put into a hierarchy of nodes, it is working.
Are you setting the names of your node to be unique? use setName on your dznode
| Posted: 10 December 2012 10:56 AM |
[ Ignore ]
[ # 27 ]
Member
Joined 2010-12-31
it might be helpful to pm me your duf file so I can take a look at it.
| Posted: 10 December 2012 11:43 AM |
[ Ignore ]
[ # 28 ]
New Member
Joined 2009-07-27
from the smallest particle scene resulting file is still big, would not fit into PM, here is dropbox link.
https://dl.dropbox.com/u/21104304/particles.duf
it is big, but when most autogenerated data is folded it is ok to explore.
| Posted: 10 December 2012 01:08 PM |
[ Ignore ]
[ # 29 ]
Member
Joined 2010-12-31
Search for the lines in the file that look like:
"scene" : { "nodes" : [ { ...
The first node is the camera and looks fine.
The second node looks fine
The third node has no id or name. I am pretty sure that is the problem. Please give all the nodes you create a name, it does not have to be unique.
| Posted: 20 December 2012 07:19 PM |
[ Ignore ]
[ # 30 ]
New Member
Joined 2009-07-27
I managed to move significantly futher in my save/load code.
Now I have a question, can I control order of finalize calls for sibling nodes? Or maybe there is some guaranteed order of calls to apply instance, finalize instance?
