Digital Art Zone
7 of 12
7
Official MANGA STYLE & VISUAL STYLE topic - Update May 19th 2013: GSO shader additional bugfix! [Commercial]
Posted: 12 November 2012 02:18 PM   [ Ignore ]   [ # 91 ]
Active Member
RankRank
Joined  2004-11-12
nDelphi - 12 November 2012 02:13 PM
BishounenTaurus - 12 November 2012 01:33 PM
nDelphi - 12 November 2012 12:58 PM
If you’re having issues with pokethrough (I assume you’re hiding the feet when you’re using shoes or something), it might just be better to not apply any shaders to them, and simply turn down the opacity.
Even if you don’t apply shaders to the feet, which I don’t since I am hiding them, applying shaders to say the arm will get the feet to show.
This is an auto-fitted boot and the feet seem to stick out and there is no way to move them or Poke-Away them away. Your suggestion to use opacity is the way to go, I will have to try that, I have even used that before several times, my brain is slow today. LOL
Glad to be of help. Just so you know, I don’t think your picture got through.
Profile
Posted: 12 November 2012 05:06 PM   [ Ignore ]   [ # 92 ]
New Member
Joined  2011-06-15
Ezaki - 12 November 2012 08:02 AM
Really been enjoying this program over the weekend especially the tutorials, shame work got in the way of my experimentation. Here is one of my efforts:
WOW i like your picture, do you have a deviant art account or your own web site with wrestling pictures?
Profile
Posted: 12 November 2012 07:50 PM   [ Ignore ]   [ # 93 ]
Member
Avatar
Rank
Joined  2007-10-01
I put this one up on a few sites and in one instance was asked if I would post the sketches! I felt like a cheater. LOL!
Image Attachments
 Signature
3D Celebrity Lookalikes
Profile
Posted: 12 November 2012 08:12 PM   [ Ignore ]   [ # 94 ]
Active Member
Avatar
RankRank
Joined  2005-01-19
BishounenTaurus - 12 November 2012 12:42 PM
This is not an issue specific to Manga Style, but is a general issue with shaders produced using Shader Mixer. If you were to do the same with any of the Shader Mixer examples included with Daz Studio (“Shader Presets/Shader Mixer”), you will encounter the same problem.
This is a problem I cannot fix, as it is a Daz Studio issue.
Aw, a Shader Mixer issue, OK. Looks like I compared with a non-Shader Mixer shaders; the DAZ Toon shaders.
I confirm it. It’s a Shader Mixer and Shader Builder Issue, it’s a general problem in DAZ Studio. I just now work in shader builder with a colourful toon shader, and hidden parts are rendered, an annoying thing. If you want remove it from render, revert the shader applied (shader builder tab, reset shader preset) and use in opacity map an image completely black to obtain total transparent render. To set only opacity strength to zero doesn’t work.
 Signature
Playing with shaders
http://www.daz3d.com/forums/viewthread/20283/
Profile
Posted: 13 November 2012 07:45 AM   [ Ignore ]   [ # 95 ]
New Member
Joined  2012-03-21
georgewrestling - 12 November 2012 05:06 PM
Just a one off so far, seemed like a good idea for a render.
Profile
Posted: 13 November 2012 07:57 AM   [ Ignore ]   [ # 96 ]
Member
Avatar
Rank
Joined  2007-10-01
gilikshe - 12 November 2012 08:12 PM
I confirm it. It’s a Shader Mixer and Shader Builder Issue, it’s a general problem in DAZ Studio. I just now work in shader builder with a colourful toon shader, and hidden parts are rendered, an annoying thing. If you want remove it form render, revert the shader applied (shader builder tab, reset shader preset) and use in opacity map an image completely black to obtain total transparent render. To set only opacity strength to zero doesn’t work.
Yep, that one worked. Thanks for the tip.
 Signature
Profile
Posted: 13 November 2012 04:26 PM   [ Ignore ]   [ # 97 ]
Active Member
RankRank
Joined  2010-11-30
Visual Style Shaders are at 1.2 now.
Profile
Posted: 13 November 2012 04:37 PM   [ Ignore ]   [ # 98 ]
Active Member
RankRank
Joined  2004-11-12
Jay_NOLA - 13 November 2012 04:26 PM
I honestly have no idea why. I haven’t changed anything, nor have I been informed of any chance.
Profile
Posted: 13 November 2012 04:54 PM   [ Ignore ]   [ # 99 ]
Active Member
RankRank
Joined  2010-11-30
The MetaData was updated according to the online Read Me.
Profile
Posted: 15 November 2012 10:28 AM   [ Ignore ]   [ # 100 ]
Active Member
RankRank
Joined  2004-05-14
Hiro 5 Cat.
Click the image to see it enlarged.
Image Attachments
Profile
Posted: 15 November 2012 12:15 PM   [ Ignore ]   [ # 101 ]
Active Member
Avatar
RankRank
Joined  2012-02-07
I should have asked about this months ago but for Visual Style, what would the preferred settings be for something along the lines of what was done with the Alchemy Chasm promo?  Essentially, using the original materials.  I had made an attempt but things looked incredibly off.  I would post an image but Daz decided to crash at 99% render completion.
 Signature
http://streetteam.bigcartel.com
Profile
Posted: 15 November 2012 12:58 PM   [ Ignore ]   [ # 102 ]
Active Member
RankRank
Joined  2004-11-12
I believe I used the “Visual Texture - Brown 2” presets when doing that Alchemy Chasm promo (it was such a long while ago I don’t clearly remember). Applied the preset to all the surfaces and then manually reapplied the textures. The preset is found under “Visual Style Shaders/Visual Presets/Visual Misc”.
Profile
Posted: 15 November 2012 01:48 PM   [ Ignore ]   [ # 103 ]
Active Member
Avatar
RankRank
Joined  2012-02-07
Ah, what I was attempting to do was hold down CTRL and selecting ignore on replacing the material.  Adding to that, I was attempting to use the same preset on everything (White 2) while I probably should have fluctuated things a bit per item.
 Signature
Profile
Posted: 17 November 2012 04:31 AM   [ Ignore ]   [ # 104 ]
Member
Avatar
Rank
Joined  2006-10-16
midnight_stories - 03 November 2012 11:32 PM
Thanks for the docs I was wondering where that was, yes a monkey see monkey do tutorial would be good.
It picks up Displacement mapping very well and the transparency looks impressive to.
Would you mind telling how you achieved that look?
Profile
Posted: 18 November 2012 08:44 PM   [ Ignore ]   [ # 105 ]
Active Member
Avatar
RankRank
Joined  2011-09-13
Was able to get these yesterday, and I really like them. Thank you, BishounenTaurus! Here’s the result of my first chance playing with them today.
Image Attachments
 Signature
My new deviantart gallery: storypilot.deviantart.com
Profile
7 of 12
7
