Digital Art Zone
Flat colours in Carrara
Posted: 02 November 2012 07:07 PM   [ Ignore ]
Member
Rank
Joined  2011-08-12
Hi
How do I render an object so that it looks completely flat in Carrara
I’d like to create the same effect I asked about in this question regarding Daz studio 4.5
http://www.daz3d.com/forums/viewthread/5420/
any help would be appreciated
thanks
Profile
Posted: 03 November 2012 02:50 AM   [ Ignore ]   [ # 1 ]
New Member
Joined  2005-05-15
- In Scene/Filters add “Toon! part III”. Edit and set Shadow to white and “Line Effect” to 0%.
- Or, if you own Carrara Pro, got to the Output tab in the Render room and add “Material Diffuse” in “Multi Pass”.
Render in both cases as usual with the photorealistic renderer.
Edit:
- In “Toon! part II”, set also “Shadow Size” and “Highlight Size” to 0%.
Both methods render also a texture in the color channel of a shader. If you needed a plain color, you would have to replace “Texture Map” by “Color” in every shader that’s visible in the render…
Profile
