Digital Art Zone
Prop modeling
Posted: 01 November 2012 11:08 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2011-01-13
I made a prop in Wings and exported to DS3A (yeah, I know talk about old). I had to adjust the scale because it loads huge, but when I export and re-import, it’s huge again. It’s no different in Carrara 8 Pro.
Is there a way to save my scale settings to the .obj?
 Signature
An expert is just an experienced novice.
Profile
Posted: 02 November 2012 01:10 AM   [ Ignore ]   [ # 1 ]
Power Member
RankRankRank
Joined  2005-09-05
LightofHeaven - 01 November 2012 11:08 PM
What setting are you importing it in at to DS3A? I would play with the different settings. The Poser scale is quite small but if you use DS scale it comes in larger…you can even set your own custom scale if you wish.
 Signature
Shadermixer tutorials and recipes
My Website
My ShareCG Gallery
Shadermixer Documents
Profile
Posted: 02 November 2012 01:34 AM   [ Ignore ]   [ # 2 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Once you SCALE the object file in DS you should EXPORT the Object from DS with the Default DS Setting in the options and Size set to 100%. Do not Over write your original file you might need other settings depending on UV maps and Morphs to get it to load 100%.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 02 November 2012 01:39 AM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
If you ‘import’ the OBJ at a scale, DS will always recognize it as the scale you imported it. Saving to PP2 file seals the deal with props and is well worth doing.
EG. I import a sword OBJ to DS at 90%, DS will now recognize it at the 90% scale. (90% Scale will be the default at 100% according to daz, it IS 90% scale of the OBJ)
 Signature
I’m not Spyro the dragon… We just look alike! tongue wink
“Anything in the real world can exist in 3D”
Eyeshine Tutorial for Daz3D vampire
- - My Render Thread - - My Deviant Art - -
- - xSPYROx ShareCG Freebies - -
Profile
Posted: 02 November 2012 01:45 AM   [ Ignore ]   [ # 4 ]
Power Member
RankRankRank
Joined  2005-09-05
Just wanted to mention in case you missed it…when you import at the bottom of the dialogue box(if closed) is a show options button.
Clicking this will allow you to play with the scale settings.
 Signature
My Website
My ShareCG Gallery
Profile
Posted: 02 November 2012 02:16 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
I had a NOOB momednt when I hit that and discovered I was importing on the BRYCE setting. Oops! But anything I import from Wings seems to be big, but i sort of have it figured out.
 Signature
Profile
Posted: 02 November 2012 02:41 AM   [ Ignore ]   [ # 6 ]
Power Member
RankRankRank
Joined  2005-09-05
LightofHeaven - 02 November 2012 02:16 AM
Try the poser scale as that is quite small…glad if I helped!
 Signature
My Website
My ShareCG Gallery
Profile
Posted: 02 November 2012 06:06 AM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Try the Blender or modo presets - a quick Google suggests that Wings uses the metre as its basic unit, so if you model to actual size that should work.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
