Congratulations! You are a March Madness BONUS BUYER!
Enjoy 10% OFF* ALL PURCHASES STOREWIDE or enjoy 30% OFF items with a SKU number lower than 16000 & 30% OFF items from Runtime DNA.
Offer valid for intended recipient only
* 10% discount DOES apply to Gift Cards and Memberships. **Items must be in cart simultaneously for discount to apply.
[ collapse ]
render script question
ktg1ktg1 Posts: 0
I have no experience with Daz scripts. I'm hoping something already exists that will meet my need. I'm doing a 2D game and hope to automate at least part of the render process. There are several animations per character, which will need to be rendered one at a time in 8 directions. This will be done by rendering all frames of a given animation, rotating the viewport 45 degrees, render all frames again, rotate 45 degrees again, etc. Ideally, the file name used would change with every rotation - i.e. each direction has a different file name. Is there a script that can do this? If so, where and how do you use it?
  • ReDaveReDave Posts: 815
    edited June 2012
    Hi!
    I had this script here that did the camera rotation. I have now updated it to include animation of the currently loaded scene. It isn't tested much but it should work. Renders are going to be saved in: Users\\AppData\Roaming\DAZ 3D\Studio4\temp and named Angle#Frame##.png
    You can change a few things by editing the top few lines, which are commented. To use it, copy the code in Wordpad (if you are on Windows), and save the file, then change its extension from txt to dsa. Place it anywhere inside your My Library folder (but outside Runtime subfolder), for example in My Library/Scripts. Access it from your Content Library tab and it will render your animation. If your animation is less than 30 frames it may render the last frames several times. Remember to cut the rendered frames elsewhere, since they would be overwritten by a second animation rendered.
    // DAZ Studio version 2.3  filetype DAZ Script
     var oDistanz=360; //initial camera position in the z direction
     var oHeight=105; //camera height
     var oSteps=8; //number of renders
     var Save=1; // 1= yes; other values=no
     var oOrbitCentre=1; // 1=orbit bounding box's center, else orbits oCentre
     oCentre = new DzVec3(0,0,0); //0,100,0 useful if camera aims at the wrong height.
     var oEccentricity=1; // 1=circle; else ellipse. Affects X, not Y nor Z
     // Get current camera
     var oViewport = MainWindow.getViewportMgr().getActiveViewport();
     var oCamera = oViewport.get3DViewport().getCamera();
     var oNewPos=new DzVec3;
     function CameraPos(oCam,oiSteps,oCentre){
            var oSin=Math.sin(Math.PI*2*oiSteps/oSteps);
            var oCos=Math.cos(Math.PI*2*oiSteps/oSteps);
            var oNewPos=new DzVec3 (oEccentricity*oSin*oDistanz+oCentre.x,oHeight,oCos*oDistanz+oCentre.z);
            oCam.setWSPos(oNewPos);
     //Aimat script from the help
      const g_sTOOL_NAME = "Aim Camera";
      // Box3 : Method for building a box
      function buildBox( oCamera ){
          // A box to grow; encompassing target nodes
          var boxTarget = new DzBox3;
          // Check if a node is selected
          var oPrimaryNode = Scene.getPrimarySelection();
          // A flag for whether or not any node warranted inclusion
          var bValid = false;
          // If nodes are selected, get the number of selected nodes, otherwise get the number of all nodes in the scene
          var nNodes = oPrimaryNode ? Scene.getNumSelectedNodes() : Scene.getNumNodes();
          // Iterate over the nodes
          for( var n = 0; n < nNodes; n++ ) {
              // If nodes are selected, get the 'current' selected node, otherwise get the 'current' node
              var oNode = oPrimaryNode ? Scene.getSelectedNode( n ) : Scene.getNode( n );
              // If the node is defined and it is not the 'current' camera
              if( oNode != undefined && oNode != oCamera ) {
                  // Grow the box to include the node bounding box
                  boxTarget.include( oNode.getWSBoundingBox() );
                  // BINGO!... we got one!
                  bValid = true;
          // If the scene is empty or there were no worthy nodes
          if( !nNodes || !bValid ) {
              // Um... Houston?
              return undefined;
          // Ahh... done.
          return boxTarget;
      // Set the busy cursor to let the user know we're working
      setBusyCursor();
      // Get the active viewport
      // Get the current camera
      // Get a box encompassing the nodes to aim at
      var boxTarget = buildBox( oCamera );
      // If the box is defined
      if( boxTarget ){
          // Start collecting actions for the undo stack; for non-'view' cameras
          if( !oCamera.isViewCamera() ) {
              beginUndo();
              oCamera.beginEdit();
          // Aim the camera at the center of the box
          oCamera.aimAt( boxTarget.getCenter() );
          // Stop collecting events and accept; for non-'view' cameras
              oCamera.finishEdit();
              acceptUndo( g_sTOOL_NAME );
      // We're done working, let the user know
      clearBusyCursor();
     // end aimat script
     var currentFrame = Scene.getFrame();
     var range = Scene.getAnimRange();
     var tick = Scene.getTimeStep();
     var startFrame =  range.start / tick;
     var endFrame  =  range.end / tick;
     var step = 1;//wStep.value;
     for( var fr = startFrame; fr <= endFrame; fr += step )
     Scene.setFrame(fr);
     for (var i=0; i
    Post edited by ReDave on
  • ktg1ktg1 Posts: 0
    Great script. Thank you, ReDave! Just a couple of things that would be nice to change.
    1. I'd like to change the camera height to, perhaps, 135. I tried changing the 2nd line to have var oHeight=135; but it did the same thing. I even tried restarting Daz Studio, but it still looks like the same angle (105).
    2. Daz opens up its small render window with each frame rendered. This could be around 100 per animation. I have to close every one of those windows after its done. Is there a way to prevent that or have it automatically close when done?
    If you have any ideas on these things, let me know.
    Thanks again.
    Hmm, camera height works for me (I tried with 5, and I saw the feet all right ;) ), however camera height is only half of the pointing vector. I completely forgot until now how the aiming was done in that script: it automatically aims at the center of the bounding box of the selected nodes, so select your whole figure, plus hat if any, to raise the view.
    Regarding the second problem I have made experiments, but it doesn't seem to work with Save=1 (it always wants to overwrite the same file for some reason). So you can set Save=0 and look for the empty line between
    var oRenderMgr = App.getRenderMgr();
    and
    oRenderMgr.doRender();
    In that empty line add the following:
    var oROptions = App.getRenderMgr().getRenderOptions();
    oROptions.RenderImgTarget=2;
    oROptions.renderImgFilename=String( "%1.%2" ).arg( "Angle"+i+"Frame"+fr ).arg( "png" );
    This should save the pictures elsewhere, though, they ended up in my Content folder for me. But it may be based on the last Content folder you rendered to, I'm none too sure. I'd advise making short experiments first, I use three frames and 1 step, myself.
  • ktg1ktg1 Posts: 0
    You're right, the camera height (oHeight) works. It just wasn't what I had expected. I was thinking it would be like an angle, with 90 = straight on, 180 top down, or something like that. I see now that its not like that. Not sure what the unit is, but I will work with it and decide on a setting I like.
    As for the script changes, I added it, and running it that way gave an error (and didn't render anything). I determined the line it didn't like is the one that started with:
    I then tried hardcoding a filename to eliminate the error. It ran like that, but still had the issue of many windows poping up that need to be closed.
    This one isn't a show-stopper for me, but if you have any other ideas, I'd like to hear.
    Thanks again for helping me out.
    Regarding the aiming, remember it points at the center of the bounding box of whatever is selected, so if you can't find a bodypart that allows the camera to point at the proper angle, try creating a box (Create->New primitive) at frame 0 and set it at the correct height, keep only it selected and turn it invisible.
    What version of DS are you running? I don't get that error on 4.5 RC1. However it doesn't like my hack (which actually worked for me the last time I tried, but doesn't work right now :-S ). I'd like to figure out how to make the renders save themselves without windows popping up, but I don't think I can troubleshoot it until mid-week.
  • ktg1ktg1 Posts: 0
    I'm using Daz Studio Pro 4, the 64-bit version. Running on Windows 7.
    edited June 2012
    I would never have found it on my own, but after getting the correct keywords yet again from a script by Casual, I think I've managed. There's now a variable to change the render to folder (add double slashes \\ instead of just one) in the declarations block near the top.
     var oHeight=135; //camera height
     var oSteps=3; //number of renders
     oCentre = new DzVec3(0,100,0); //0,100,0
     var s_OutputPath = "d:\\test\\";
          var bValid = false;
                  bValid = true;
              // Um... Houston?
              return undefined;
          // Ahh... done.
          return boxTarget;
      setBusyCursor();
      if( boxTarget ){
              beginUndo();
      clearBusyCursor();
     // end aimat script
     Scene.setFrame(fr);
     for (var i=0; i
    I hope it works this time!
  • ktg1ktg1 Posts: 0
    Worked like a charm - no more little windows to close. Fabulous script. Thanks again, ReDave!
    No problem, since most of the script is old! ;) Glad to have gotten it to work at last!
