Digital Art Zone
2 of 3
2
3D-printing: share your pictures
Posted: 03 November 2012 12:44 PM   [ Ignore ]   [ # 16 ]
Active Member
Avatar
RankRank
Joined  2005-07-29
Yes, what Joe said. *smile*
 Signature
<End of transmission from Oz>
TUTORIAL - Creating a Genesis Full Body Morph for DAZ Studio Pro 4 by RKane_1
TUTORIAL - Creating a Genesis Partial Body Morph in DAZ Studio Pro 4 Using the DForm Tool by RKane_1
TUTORIAL - Applying Shaders by RKane_1 (as stolen blatantly from Jaderail)
Profile
Posted: 07 November 2012 05:33 AM   [ Ignore ]   [ # 17 ]
New Member
Joined  2009-05-29
Here some answers…
Yes, everytime a model is fit to be ‘3d-printed’, it has to be manifold, that is to say it has to be watertight and flipped and intersecting triangles are below a certain threshold. To achieve this, you have to ‘repair’ 3D-models in a third-party software like the open source ones: MeshLab or Netfabb. However, these programs ‘throw away’ any texturing and other color information. The only two programs I know that retain color information, are Materialise Magics and DeskArtes 3Data Expert (I use both). These do in essence the same job as Meshlab, but retain the color-information.
The biggest problem in printing ‘standard’ 3D-models like the ones you see in DAZ, are the parts of the model that are build up by ‘planes’. If you want to let these be recognized by the printer as ‘volumes’, you have to ‘thicken’ them. In a lot of programs there are solutions for this (by hand or automatic). The process called ‘shrinkwrap’ is the most elegant way to do this. The thing is that for instance hairs, need a lot more thickening than a human figure, so you have to break up your scene in the individual parts and thicken them seperately before you export them to the printer. The thickening itself is problematic because it produces errors in the mesh and with complex shapes, it places heavy recources on your computer. You will have to find out a balance between an acceptable endresult and what your computer can handle.
Profile
Posted: 07 November 2012 07:15 AM   [ Ignore ]   [ # 18 ]
Active Member
Avatar
RankRank
Joined  2005-07-29
Eric van Straaten - 07 November 2012 05:33 AM
Here some answers…
The biggest problem in printing ‘standard’ 3D-models like the ones you see in DAZ, are the parts of the model that are build up by ‘planes’. If you want to let these be recognized by the printer as ‘volumes’, you have to ‘thicken’ them. In a lot of programs there are solutions for this (by hand or automatic). The process called ‘shrinkwrap’ is the most elegant way to do this. The thing is that for instance hairs, need a lot more thickening than a human figure, so you have to break up your scene in the individual parts and thicken them separately before you export them to the printer. The thickening itself is problematic because it produces errors in the mesh and with complex shapes, it places heavy resources on your computer. You will have to find out a balance between an acceptable end result and what your computer can handle.
Please forgive my ignorance but I ask in order to learn…
What do you mean by models must be “manifold” to be 3D Printed?
What do you mean by “watertight”, “flipped” and “intersecting triangles”?
I am not clear on what this phrase means: “parts of the model that are build up by ‘planes’. If you want to let these be recognized by the printer as ‘volumes’, you have to ‘thicken’ them. “.
I thank you very much for helping us all understand this process better and look forward to hearing more about it. Thank you so much for lending your expertise and talent to us and helping us understand this process.
 Signature
Profile
Posted: 07 November 2012 07:38 AM   [ Ignore ]   [ # 19 ]
New Member
Joined  2009-05-29
Here is a tutorial on the Shapeways-site where they explain what kind of errors can occur in 3D-models: http://www.shapeways.com/tutorials/fixing-non-manifold-models
Basically the 3D-model you want to print, has to be able to ‘exist’ in reality. This means that nowhere in the model, there can be surfaces that have no ‘thickness’ (and are therefore infinately ‘thin’). If you for example have a sphere in which one triangle is missing, the printer doesn’t recognize this as a shape, but just as a curved surface with no thickness that cannot be printed.
Unfortunately, at this time you will have to find out yourself how to fix models if you want to get them printed. Everytime it’s different, so read a lot of tutorials, or ask someone to fix the models for you;)
Profile
Posted: 07 November 2012 07:39 AM   [ Ignore ]   [ # 20 ]
Power Member
RankRankRank
Joined  2011-11-16
Well the part about planes is pretty simple.. it has to have 3d depth, not single one sided poly deep.
hehe… cross-post wink
Luckily, the main issue with DAZ market objects would probably be these one sided single poly deep faces. duplicate verts and edges are pretty rare from what I’ve seen in DAZ market objects. So are missing polys where there should be polys (although this is more likely then dup vert/edges.) Blender has some good tools for finding and repairing these but I don’t have the links handy for showing one how to use these particular tools. One also has to tackle learning Blender’s basics if going this route. All of the items on the checklist are basically on the ‘is it well made’ checklist, which is part of what one gets when buying for DAZ store, after the object goes through Q&A. Older objects might be a problem, Gen3 and earlier… but I haven’t run into anything noticeable yet.
One way to get an idea of the quality of the mesh is to go into the data folder and double-click on the obj itself, look at it in wireframe/shaded wireframe. It is hard to see dup edges/verts this way however, one would have to load the obj up into Blender and use it’s tools afaik.
Btw, objects one gets ‘for free’ are highly likely to have many, even all of these problems… high unnecessary poly count, missing faces, dup verts/edges, reversed normals… All of which can cause problems for any software package trying to work with the object. 3D printing just happens to be more sensitive then most regarding these issues.
Oh, the intersecting triangles beyond a certain point mentioned I believe is also referred to as ‘extraordinary vertices’ and refers to where there are multiple polys joining on one vert. In good design this should be kept to a minimum and also kept off of any edges or areas where it would cause a perturbance in the surface of the mesh. If one is necessary, it should optimally be moved back to a flat surface.
One thing I’m curious about with 3D printing is uniformity of poly size. Uniformity of poly size and poly count is a tradeoff. It is my understanding (and correct me if I’m wrong on any of this) that uniformity of poly size comes into play if texturmapping, as it makes it easier/harder to get a uv map that one can get even detail out of. If one isn’t worried about uv mapping a given surface, and doesn’t need high poly count for active distortion of the mesh, one can often cut down poly count by going non uniform in poly size. How this exactly plays into current 3D printing I’m not sure. Many DAZ objects have a very non uniform poly size btw to keep down on poly count.
 Signature
Just because I may have a strong opinion doesn’t make it any more (or less) correct than any other, just that I feel passionately a particular way at that moment.
Profile
Posted: 07 November 2012 08:19 AM   [ Ignore ]   [ # 21 ]
Power Member
RankRankRank
Joined  2011-11-16
I should mention, Hexagon might also have tools for finding dup edges/verts, flipped normas, etc. I don’t remember off the top. If it does, this might be an eaiser way for many considering the interface is simpler and there is the bridge.
Very nice stuff btw Eric, ty for posting smile
 Signature
Profile
Posted: 07 November 2012 01:13 PM   [ Ignore ]   [ # 22 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Texture Atlas in DS might help with getting the colors back after export. However, I’m not sure how to make use of that if one uses a shrinkwrap function. I’m also not sure what would be the best candidate shape to start with for the shrinkwrap… I’m guessing a sphere? I know Blender has a function to do this, but I don’t know how to use it. I’d love a pointer to docs if anyone has one.
Blacksmith3D has a projection camera feature that lets one take a render from a particular angle, export to a 2D image editor, then bring it back in and project it back onto the surfaces from the same angle. Maybe something like that could be used to make a texture for a shrinkwrapped model. I’m sure many other software packages have similar features.
Profile
Posted: 29 November 2012 08:18 PM   [ Ignore ]   [ # 23 ]
Active Member
Avatar
RankRank
Joined  2006-06-12
zigraphix - 07 November 2012 01:13 PM
Zbrush will generate a loose mesh around an object and this mesh can then be shrink wrapped (or projected in zbrush lingo).  If you heavily subdivide the original object, you can polypaint it quickly from its texture atlas texture.  If the mesh you are shrink wrapping is also super high poly, you can transfer the polypainting as well (you could do this even with low poly meshes, they’d just look terrible).
Still though,  to make this look really good, I think you’d need a cpu that could handle two 15 million vertices meshes at once.
 Signature
My Daz Store
ShareCG Freebies
Tumblr
Profile
Posted: 22 December 2012 12:46 AM   [ Ignore ]   [ # 24 ]
Member
Avatar
Rank
Joined  2011-07-07
I work in Ottawa at Envirolaser.  Lucky for me, I get to use their 3D Systems ProJet HD 3000 to build my models.  Standard poly count is over 300,000.
Here is a side-by-side of my design and finished model.  Please excuse the poor photography, used my cell phone for the pic.
Image Attachments
 Signature
Reality is perception.
Profile
Posted: 22 December 2012 05:36 PM   [ Ignore ]   [ # 25 ]
Power Member
Avatar
RankRankRank
Joined  2007-11-30
Nice!!
 Signature
Still not bald.
Profile
Posted: 02 January 2013 05:36 PM   [ Ignore ]   [ # 26 ]
New Member
Joined  2009-05-29
That looks great! Does the printer also print the color?
Profile
Posted: 02 January 2013 05:51 PM   [ Ignore ]   [ # 27 ]
Active Member
Avatar
RankRank
Joined  2006-09-30
Have a look over here if you want to see what the Fractal Freaks over at Fractal Forums have been printing :
http://www.fractalforums.com/format-printing-and-post-production/shapeways-for-3d-printed-fractals/
Not one of mine, but a nice example :
Image Attachments
 Signature
MOO!
Profile
Posted: 02 January 2013 11:14 PM   [ Ignore ]   [ # 28 ]
Member
Avatar
Rank
Joined  2008-08-09
Eric van Straaten - 30 October 2012 07:52 PM
I thought it was nice to start a post in which users share their 3D-printed models. As you can see from my examples, they can be amazing (at least I think so;). Please share your own examples!
I’m stunned!  These are incredible.  I didn’t know this was possible.  How much does it cost to get one of these companies to make one?
Also, what is it made out of?  Plastic?  And, how big are these?
Profile
Posted: 07 January 2013 01:12 PM   [ Ignore ]   [ # 29 ]
New Member
Joined  2012-04-08
I’m going to be following this thread with interest.  I’m looking to get my own 3D printer so I can print my model masters.  Right now they’re being hand sculpted with all the benefits and drawbacks of that process.
I’ve got a ways to go just learning the 3D software itself much less learning how to make them printable. :D
Profile
Posted: 25 January 2013 04:37 PM   [ Ignore ]   [ # 30 ]
New Member
Joined  2013-01-25
Eric van Straaten - 07 November 2012 07:38 AM
I taught myself to model in Blender using the manual and YouTube videos. The Shapeways tutorial on fixing non-manifold models is excellent and I can highly recommend it. I also taught myself about 3D printing at the RepRap.org site and built my own printer for about $500.
Here is a recent project I have been working on, printing at a resolution of 0.15 mm, which is about the best that my printer can manage.
There are more pictures in this thread.
Image Attachments
Profile
2 of 3
2
