Digital Art Zone
new version of the mcjCollider plug-in for DS3-PC 32/64bit - and a poke-through fix script
Posted: 30 October 2012 06:03 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2006-01-19
download and manual
https://sites.google.com/site/mcasualsdazscripts/mcjcollider-plugin
this plugin for DS3 is meant to be used mostly by script programmers
but clever users can also put it to good use !
i added a small script which can create a morph to push-or pull a face
which, yes, is a way to fix poke-trough with great precision
this new version also will not crash daz studio
- when one of the collision candidate nodes is removed from the scene
- when one of the collision candidate nodes is converted into a subD surface
the new version identifies the face of the collided-upon object that was hit
for example: blAiko3_72712 rButtock 1 662
means the 662d triangle of Aiko3’s rButtock mesh was hit
in figure 2 you can see the white line is the mcjCollider which collided against Aiko3’s skirt
in figure 3 you can see a morph channel named “face27” was added to the skirt
and it was used to pull face 27 of the skirt out of Aiko’s body
in figure 4 another face ( 29 ) was pulled out
figure 5 shows that, yes fixing poke-trough is nice, but better skirt rigs are needed
Image Attachments
Profile
Posted: 31 October 2012 09:01 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2003-12-16
Awesome! I can’t wait to try this!
 Signature
Gravy to potatoes, Luke to Darth Vader, I’m a souped up sucker and I’ll see you all later
Profile
Posted: 31 October 2012 08:41 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2010-02-05
Will this work in DS4 also?
Profile
Posted: 31 October 2012 08:56 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
ragaray - 31 October 2012 08:41 PM
for now, no it wont work with ds4 because it relies on a plugin for DS3 which really doesnt work with DS4 DS4.5
but i’m in the process of getting ready to write plugins for DS4.5
and the first plugin i will make is probably this one
unrelated image, aiko wearing a collision suit
Image Attachments
Profile
Posted: 31 October 2012 09:01 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2010-02-05
Thanks so much Casual. Your work truly amazes me!
Profile
