Digital Art Zone
Cool Sports… Hoodie…. Question
Posted: 29 October 2012 11:00 AM   [ Ignore ]
Power Member
Avatar
RankRankRank
Joined  2011-11-25
I bought cool sports, and I like the outfit. But…. I can’t seem to fit hair under the hood. There is a morph for adjusting hat, but it just doesn’t give enough head space. I don’t want my characters to look bald. Any advice on this one?
http://www.daz3d.com/shop/cool-sports-for-genesis
Profile
Posted: 29 October 2012 12:04 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2012-07-21
Had the same problem with this outfit. I tried to set as much of the top and the back of the hair to invisible in the scene tab, then had to play around with camera angle. Not optimal, but i really like the look of the outfit so i’m considering making morphs for this as well as for dropping the hood.
Haven’t made one before, so it might take me a while…
 Signature
my ShareCG
Profile
Posted: 29 October 2012 12:26 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
This is the ‘usual’ fix…
http://www.daz3d.com/shop/deformers-plus-hat-head
And some more suggestions here…
http://www.daz3d.com/forums/viewthread/3967/
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 29 October 2012 12:35 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-06
I’ve got a product for that also.  Hat and Hair Fixer.
Basically you conform this snug hood to Genesis, conform the hair to it, and use the hood morphs to smush the hair down.  It won’t do anything on the bottom parts of long hair, but usually you can swing those forward with their own morphs.
 Signature
My store at DAZ.
My Deviantart gallery.
Profile
Posted: 29 October 2012 01:58 PM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2011-11-25
Hm… I like the outfit, but I guess, I feel I shouldn’t have to buy more stuff to make it fit properly… Yeah, I know, but that isn’t a cheap outfit. Seems kind of a strange bug, since the promo art implies hair is possible under the hoodie.
Profile
Posted: 29 October 2012 02:01 PM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-06
SereneNight - 29 October 2012 01:58 PM
Only the first promo shows any, and it’s one shock sticking out the front.  It could easily be something like the OOT Super Updo, which has bangs but no back on some pieces, or one of DAZ’s ponytails with bangs that has the ponytail turned off.  What hair are you trying to use?
 Signature
My store at DAZ.
Profile
Posted: 29 October 2012 02:06 PM   [ Ignore ]   [ # 6 ]
Power Member
Avatar
RankRankRank
Joined  2011-11-25
Thanks SickleYield. You are always so helpful. Its melody hair…. I’m trying to use. The existing morphs don’t cover it entirely.  Will try making parts invisible when I get home at night, not sure if that is possible with that hair, since I’m at work and can’t try it.
I see in the promo material had morphs listed for adjusting the hat, and a picture of a character with hair. I
Profile
Posted: 29 October 2012 02:30 PM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2009-01-09
As a matter of purest curiosity, what happens if you turn off limits on the hood morph and then try again to use it to enlarge?
That said, I wouldn’t expect Melody hair to fit under most hoods—you probably have some ferocious pokethrough in the back, although that may not matter. For that look, you need something relatively flat all the way around.  Pure Hair Nightlife or Charming, for example.
 Signature
VWrangler at deviantArt (NSFW for some images; login required to view those)
Profile
Posted: 29 October 2012 02:32 PM   [ Ignore ]   [ # 8 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-06
Yuh.  The Melody hair has that giant ponytail that sticks up even past the level of the actual head hair.  It’s gorgeous, but it’s not really made to go under things as big as a hood (it’d look great with a crown or tiara,I bet).  If you can’t turn the ponytail off it’s just not going to fit under headgear.
 Signature
My store at DAZ.
Profile
Posted: 29 October 2012 10:24 PM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
To be honest, for something like a hat or hood, there is no effective way to make certain all the hairs out there fit them properly. Sure, the creator COULD buy every single hair model out there and create a morph to make sure it fits under said hat or hood, but that is (IMHO) incredibly unreasonable. Sickle’s hat and hair fixer is a good thing, but it’s not JUST for the hood - it’s good for pretty much any hat / hair combo except the most extreme hairs.
There’s also Lyrra’s version, in the MP here; http://www.daz3d.com/shop/deformers-plus-hat-head
 Signature
A good pun is its own reword
“The greatest sin is to be unteachable” - Dr. Pat Allen
Profile
Posted: 30 October 2012 08:39 AM   [ Ignore ]   [ # 10 ]
Power Member
Avatar
RankRankRank
Joined  2011-11-25
Hmm.  agree it is unreasonable to test every hair, but the hood should allow for more adjusments than two on the side. It only has 2- ones on the side, which hardly adjusted anything.
The hood should also be removable or lowered position. this way, hair could be used freely.
Another way that works is making the hood a different piece.
Profile
Posted: 30 October 2012 09:24 AM   [ Ignore ]   [ # 11 ]
Member
Rank
Joined  2005-10-16
In Poser, the way I have gotten around hoods and such is using a magnet to collapse a portion of the offending hair,
or
using a product like this:
http://www.renderosity.com/mod/bcs/biscuits-partial-hair-fronts/95777
 Signature
Gone.
Profile
Posted: 30 October 2012 10:00 AM   [ Ignore ]   [ # 12 ]
Power Member
Avatar
RankRankRank
Joined  2011-11-25
jmper - 30 October 2012 09:24 AM
or
Thats a cool product. Def. Worth a look. Thanks for the suggestion!
Profile
Posted: 30 October 2012 10:02 AM   [ Ignore ]   [ # 13 ]
Member
Rank
Joined  2005-10-16
Only problem I see is that it uses materials that may need adjusting in Studio.
 Signature
Gone.
Profile
