Digital Art Zone
Which Files Do I Need to Install?
Posted: 28 October 2012 10:28 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2011-11-29
I had to reset several bundles, and now am not clear which files to install.  I’m running DAZ Studio 4.5.1.6.
1.  Do I install the “DSON” or “DSON Core” files?
2.  Do I install the “Legacy” files?
3.  Do I install the “Poser Companion” files?
Thanks for clarifying this.
MrWizard1024
Profile
Posted: 28 October 2012 11:36 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
For DS 4.5 you only need the DSON Core
For earlier versions of DS (4.0 or 3) you only need the Legacy
For Poser 9/PP2012 you need DSON Core and Poser Companion Files
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 01 November 2012 05:10 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2007-03-07
fixmypcmike - 28 October 2012 11:36 PM
As I have both Poser Pro 2012 and DS 4.5, can I install the Poser Companion files in the Studio/My Library folder?
(Sorry if this has been asked and answered, but the search I tried has not given me the answer.)
Profile
Posted: 02 November 2012 06:49 AM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
LmWolfSpirit - 01 November 2012 05:10 PM
Yes, I do that (except it isn’t called My Library, but I use the main DS folder for the Companion files).
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 02 November 2012 09:43 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  0
Richard when you say you use the main DS folder for companion files…what folder and files are you referring to exactly ?  sorry if that sounds dumb but I am trying to set up a brand new system and am trying to figure out the best way to do that…(I am only using DS 4.5, no Poser ) but it seems that the same terms are being used for different setups and I am really confused, so I am trying to clarify some of the info going around
Kharma
Profile
Posted: 02 November 2012 12:29 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2007-03-07
Richard Haseltine - 02 November 2012 06:49 AM
Hmmm, interesting. I have been putting all trx files (except prop stuff that has a Poser counterpart) into the Content folder and all trx stuff that is related to people, clothes or hair in My Library. I will now be adding the CF files to My Library.
I think it is very confusing that some props are labeled trx rather than ds now. I am thinking that only Genesis stuff should get the trx label.
Profile
Posted: 02 November 2012 02:54 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  0
Some files I d/l tdo dooday, such AS THE TENT only have 2 files the tentmetadata_1.0_ds.exe - pc and thetent_1.0_dpc.exe-pc…..do I install both?  Is this just a poser file..there seems to be no continuity between how files are named.  Same with the V4 MFDExp1 and 2 there is the metadata file and the dpc file….
Kharma
Profile
Posted: 02 November 2012 03:09 PM   [ Ignore ]   [ # 7 ]
Member
Rank
Joined  2007-03-07
Kharma - 02 November 2012 02:54 PM
Kharma
I agree with the file naming issues. It just makes things more confusing.
If you are using DS, then you need the metadata files (installed in DS). If you are only using Poser, then you do not. Many of the dpc files contain both the DS materials as well as the Poser materials. It is usually noted on the product page.
If you are using Poser, then you definitely need the dpc files.
Hope that helps.
Profile
Posted: 02 November 2012 04:03 PM   [ Ignore ]   [ # 8 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Kharma - 02 November 2012 09:43 AM
Kharma
I mean I install to the folder that has the Genesis files in it - the equivalent of the My Library folder. I didn’t put the content in my documents folder, and I didn’t call the folder My Library, but it is the folder I told the DS installer to use instead of that.
 Signature
Profile
Posted: 02 November 2012 05:03 PM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  0
ok thanks for the explanation smile
Profile
