Digital Art Zone
Help: viewport display switching to solid bounding box
Posted: 28 October 2012 01:57 PM   [ Ignore ]
New Member
Avatar
Joined  2005-01-20
I have set the viewport display to “texture shaded”. However, when I move the camera or modify any object in the scene, the viewport display switches automatically to solid bounding box. This is quite annoying since I cannot see my modifications in real time. Any idea on how can I get rid of this solid bounding box view?
Profile
Posted: 28 October 2012 04:22 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2010-06-18
Hi itsikw…
If this is only happening when you manipulate the scene (ie: camera view or posing), then what you need to do is change the viewport draw during manipulation setting in the Tool Settings pane.
Open the Tool Settings pane, menu bar > Windows > Panes (tabs) > Tool Settings, and then select the Universal Manipulator as the Active Tool. Find the section in the Tool Settings pane for During Manipulation, and change DrawStyle to Use Current (Off).
Hope this helps… smile
Image Attachments
Profile
Posted: 29 October 2012 07:14 AM   [ Ignore ]   [ # 2 ]
New Member
Avatar
Joined  2005-01-20
Yes, it solved the problem! Thank you niccipb.
Profile
