Just a few user oriented suggestions. I have been using Genesis in Poser-mostly pleased! There are a few things that might make things smoother for others.
One: the morph packages- people need to know that they add morphs to Genesis characters already in the Character library. We are used to injection poses. For instance- I have a character created with my early morph purchases-she is in a PZ3 file-so when I looked for Morph set 2,3, and muscularity-they were not there. Of course-I found them in the base characters.
As a long time poser user-I would generally-make a character I like-then add more morphs through injections-to that character.
I suppose-I could save her as a character-then go back to the installers-and add the new morphs.
Also- let people know that face morphs can be found under Body- not head.
I think all this can be found in various threads-but a simple sticky stating what is different-would help!
A request- add the Poser Companion files to the SubD dragon. I bought it-it indicates that it is for Poser and Daz-but
there are no companion files-so unless I create them in Daz 4.5 it is not fully functional. I was able to inject poses into the LE version-but some presets-like Baby Dragon- do not work. SubD shows up in character (with LE)-but it is missing many files and will not load.
Request 2: V5 Gens- please update-fix! Thanks.
Again-mostly pleased-and have purchased a few hundred in Genesis items so far.
Note: Cath Harders has PCF files for the Neanderthal on her site. I bought from Daz in the Poser+ Daz section-it lacked the PCF-so I returned it-only to buy it from Mec4D-with PCF. It is a great character. BTW!
A request- add the Poser Companion files to the SubD dragon. I bought it-it indicates that it is for Poser and Daz-but there are no companion files-so unless I create them in Daz 4.5 it is not fully functional. I was able to inject poses into the LE version-but some presets-like Baby Dragon- do not work. SubD shows up in character (with LE)-but it is missing many files and will not load.
The SubD Dragon IS a Poser-ready product already. I’ve owned and used it in Poser well before Genesis and DAZ 4. Just run the installer again and install directly to Poser. The DAZ-only materials are in a separate installer.
Thanks!
I find the Subdragon-along with the LE version. When I click on the Subdragon to load it-I get a bunch of calls for files that are not on my computer. I ran all the installers that appeared in my order.
fixmypcmike - 27 October 2012 09:44 PM
The Gens have now been updated—reset your M5 Pro Bundle or V5 Pro Bundle to get the DSON/PCF version.
The SubDragon should be in the GSE Poser Companion Files under Figures > DAZ Dragons.
The Gens are there- but what about materials? Grey?
Eric Walters - 28 October 2012 12:09 AM
Thanks!
Could you please clarify - which items do we need to actually download and install again? I re-downloaded the V5 Gens and see no difference - no icon in Poser etc. Does V5 need downloading again also?
I downloaded a newer TRX file- was version 1.5 vs 1.4, and a separate Poser PCF. First I uninstalled version 1.4. I restarted Poser. I see it under Anatomy. I added it. Conformed to Genesis. Opened the DSON script and transferred active morphs. It moved into place. I don’t find any materials or pose file textures.
The material groups are the same as V5-including, face, head, etc. I applied V5 bree-but the gen remains neutral grey.
BTW: there are morphs in the Genesis Body morph kit 1 that work well in place of this. Obviously the hip textures work in that case. For my purposes-at least-it is “good enough.”
I have a free UV map selector from Cath at Mec4D- I am going to try that.
Dim Reaper - 28 October 2012 06:05 AM
Just to clarify-did you just reset your download? When I did the version changed from 1.4 to 1.5 and the PCF installer appeared.
Thanks Eric. Where I was going rong was that the downlods were still available, so I thought they would link to the updated version. Resetting the downloads and downloading the two Gens files worked.
As you mentioned though, I can’t get the textures to apply properly - it keeps leaving a grey area. Also having to scale the gens to 80% on V5, otherwise it looks really strange.
Thanks!
The SubDragon that comes in Genesis Starter Essentials is the LE version in DSON format. If you purchased the SubDragon separately, it uses legacy Poser rigging. If you had DS4.0 installed previously, the legacy-rigged LE version was included, but it was labeled SubDragon without the LE—if so, and you purchased the full SubDragon, reinstall it to replace the files that DS4.0 disrupted.
Hi Mike
I bought the “full” dragon a few days ago.I installed it. I now have poses and injection poses for the SubdragonLE. I also now have “Subdragon” as well as SubD Dragon in my Poser Runtime. The SubD dragon shows Installed?Modified Mar 14 2008, whereas LE is August 2012. I never had SubDragon in my Poser Runtime previously.
When I select Load- I get a LONG list of missing files- starting with “Please locate “SDrgnBODYGrps.pz2” This file does NOT exist on my Mac. I then get “Warning, Cannot Open /Applications?Poser Pro 2012 Content?Runtime/libraries/!Daz/Subdragon/SDrgnBODYGrps.pz2
It next warns that it cannot open SDrgnBODYchannls.pz2” Etc.
I guess I’m not quite sure what you are suggesting.
I have Daz4 and 4.5 on my computer-don’t use them
fixmypcmike - 28 October 2012 09:10 PM
Thanks!
Hi Mike
Thanks!
When you installed the SubDragon did it initialize successfully? Go to “:runtime:libraries:!DAZ” and run “DzCreateExPFiles-SDrgn.command”
Hi Mike
I did not see an option to do so. I found the file you suggested-it opened a Unix command box-and indicated it ran. BTW: I pressed “OK” for about 100 of those Warning-cannot Open messages-and the Dragon appeared, Seem funtional-except for the scale morphs like “Baby”. I’ll try again now that I initialized it.
Thanks for your help, btw!
Eric
fixmypcmike - 29 October 2012 12:05 AM
Eric Walters - 28 October 2012 11:52 PM
Hi Mike
Thanks!
Hi Mike
Initializing did not change anything. However, after pushing OK on all the many warning cannot load messages, I saved out the Dragon that
did load-as SubDCannot Load-in my character library. It DOES load.
