I see there is a free utility that enables V3 clothes to be used with genesis/V5 but I don’t exactly understand how it works. Ideally I’d like to convert many V3 clothes for use in v5 and wonder whether all, or just some of them are suitable. Does this utility adjust the V3 cloth morphs to fit genesis, and if so does that also mean I can also use V3 (which overall I prefer) body morphs for use in v5 or genesis.
The V3 morphs are still very useful and actually provide in many cases a much more detailed manipulation of face and body. For example: hip spandex, male spandex, breasts smooth, sternum narrow, hip narrow, hip small and many others.
The reason I ask is because the genesis/v5 body morphs have a similar flaw to V4: there is a big gap between left and right buttocks. Just to be clear, there is an exaggerated distance between the top inner thighs and that causes an exaggerated (and unrealistic looking) very wide crotch area. In v3 you could easily adjust this by using the inner thigh and hip spandex morphs. They would close the unsightly gap from the back and this might explain why in the vast majority of screenshots of V4 and V5 renders, there are very few views from directly behind the buttocks as I think the artists are aware it just doesn’t look right.
mjc1016: Thank you very much for that. Am I right to assume that after installing your suggested addon morphs, they will appear either as a master morph heading with a master slider, or will appear as “extra” morphs in the params list of general morphs for each section (torso,upper/lower etc)?
Some of each…although both sets have their own ‘section’ in the Parameters tab (under actor)...
Together, they are almost as useful as the Evolution morphs with some items that the Evolution morphs don’t have.
RAMWolff is working on getting a male set up, to go along with the female set he already has up,
I must ask, WHAT way to put Generation 3 clothing on Genesis. All I know about is the Gen4 Autofit. Even the Gen3 shapes do not give you Autofit for Gen3 clothing that I know of.
The only way I know of, for sure…CrossDresser (Wardrobe Wizard) > convert Gen3 item to Gen4 > then manually use the Transfer utility, as opposed to Autofit. (did that for the M3 Norman’s outfit…but I need to redo it at the CrossDresser level as I let CD put handles in it…and well, fitting it with themm in DS4.5 is NOT recommended…they kind of stick around with no way of getting rid of them I can find. The other parts work, the tunic is the problem part).
Hi Jade, when you buy the gen 3 iconic shapes you get autofit for them. I have autofitted a lot of Gen 3 stuff to genesis. Here’s a few
Sam character wearing edwardian suit
Mavka/kiyoko mix with chiton
Playing with the dress
kiyoko in the dna morphing gown for v3
With Iconic shapes for gen3, links is above post by GreyMouser69. It is not free. Never, it had been free. Morphs can be obtained using genx add-on for gen3, also using morph loader, free with DS4, but you need repair some il-posed points with hexagon, so, is better pay genx add-on for gen3.
It’s a render with shukky free armor for V3 autofited in genesis with toon amy morph.
According to daz the gen 3 iconic shapes give you the gen3 clones for auto fit so it is supposed to work, at least as well as the gen4 auto fit does. I have the shapes but have yet to try the auto fit functions.
Opps, I’m behind the times. You folks are 100% correct. Just never sunk in to my thicker than normal head. I’ll jump on this bandwagon as I could use it for some of my stuff. (Place broken Red faced Smiley here)
Are you kidding? The whole auto fit option is 99% of the reason I grabbed the gen3 iconic bundle and d3 shape in the first place lol. I have TONS of gen3 and gen4 content that is VERY helpful to be able to use auto fit to use with genesis!
