Digital Art Zone
2 of 2
2
Decoro
Posted: 05 November 2012 01:58 AM   [ Ignore ]   [ # 16 ]
Active Member
RankRank
Joined  2012-01-29
You are not alone with this problem. Several people wrote about it in this thread. It seems that they did not find a solution yet, but try to check the thread regularly, maybe someone will find a way to fix it and posts it there.
Profile
Posted: 05 November 2012 02:43 AM   [ Ignore ]   [ # 17 ]
Member
Rank
Joined  2009-08-21
Proxima Shining - 05 November 2012 01:58 AM
O.K.
Thanks.
Ciao
 Signature
“Il principio della scienza della pittura è il punto, il secondo è la linea, il terzo è la superficie, il quarto è il corpo che si veste di tal superficie”
Leonardo da Vinci
Profile
Posted: 05 November 2012 05:23 AM   [ Ignore ]   [ # 18 ]
Member
Avatar
Rank
Joined  2005-09-15
@m_m_italy   Have you checked that your file permissions have not been corrupted or missing in the control panel ?
For example .jpeg + .png + etc
Edit:    Durr!  I’m a twit;  He won’t be able to see the screen grab.
Image Attachments
 Signature
Cheers, Fanners.raspberry
Profile
Posted: 05 November 2012 06:13 AM   [ Ignore ]   [ # 19 ]
Member
Rank
Joined  2009-08-21
RedSquare - 05 November 2012 05:23 AM
blank stare
Image Attachments
 Signature
Leonardo da Vinci
Profile
Posted: 05 November 2012 05:09 PM   [ Ignore ]   [ # 20 ]
Active Member
RankRank
Joined  2012-01-29
Hi - two members already mentioned that antivirus software Kaspersky Internet Security 2012 they have on their computers might be causing it after a recent update. Do you have this antivirus also?
Profile
Posted: 05 November 2012 09:20 PM   [ Ignore ]   [ # 21 ]
Member
Avatar
Rank
Joined  2005-09-15
O’er, m_m certainly has serious issues.  gulp
Image Attachments
 Signature
Profile
Posted: 06 November 2012 01:37 AM   [ Ignore ]   [ # 22 ]
Member
Rank
Joined  2009-08-21
Proxima Shining - 05 November 2012 05:09 PM
Hi,
You are absolutely right!
Use this antivirus.
I think this is the cause.
I confirm.
The problem is that I can not find solution.
He also disable copy paste from google translator.
La causa is Kasperski.
 Signature
Leonardo da Vinci
Profile
Posted: 06 November 2012 01:38 AM   [ Ignore ]   [ # 23 ]
Member
Rank
Joined  2009-08-21
RedSquare - 05 November 2012 09:20 PM
Potrebbe andare peggio…...
Potrebbe piovere…..
Bye
 Signature
Leonardo da Vinci
Profile
Posted: 06 November 2012 02:20 AM   [ Ignore ]   [ # 24 ]
Active Member
RankRank
Joined  2012-01-29
It seems that updating from Kaspersky 2012 to Kaspersky 2013 should cure the problem - it worked for 2 forum members already. Also, one member added DAZ forum to Kaspersky white list and this helped also. You could also pause the antivirus for the time when you are browsing in the forum. Or just uninstall the evildoer alltogether and install another antivirus - that´s what I did with my antivirus when it crashed and nearly damaged my PC after an update.
Profile
Posted: 06 November 2012 07:20 AM   [ Ignore ]   [ # 25 ]
Member
Rank
Joined  2009-08-21
Proxima Shining - 06 November 2012 02:20 AM
O.K.
Grazie.
Bye.
 Signature
Leonardo da Vinci
Profile
2 of 2
2
