Digital Art Zone
Question about Scene images
Posted: 27 October 2012 07:23 AM   [ Ignore ]
Member
Rank
Joined  2011-08-12
Hi
I’d like to use reference images I’ve created to help with modelling a few head morphs using hexagon
However I don’t see any options for editing a scene images size or position can anyone tell me how I would go about aligning my reference images?
any help would be appreciated
thanks
Profile
Posted: 27 October 2012 08:44 AM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2009-08-21
Try to put your image on a surface.
No sfondo
Surface….
Sorry but I do understand the English language only 0.1%.
 Signature
“Il principio della scienza della pittura è il punto, il secondo è la linea, il terzo è la superficie, il quarto è il corpo che si veste di tal superficie”
Leonardo da Vinci
Profile
Posted: 27 October 2012 11:31 AM   [ Ignore ]   [ # 2 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Yes, create a plane of the desired size to put the image on, then you can position or size it as desired.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 27 October 2012 02:39 PM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2009-09-16
The process I use is:
Create a plane that has the same size as the image.
Then uv map the plane.
Create a material which includes the image and apply the material to the plane.
The flip image commands in the material settings are buggy when you reopen your scene so don’t use those. If the image is upside down then re uvmap and check the flip u or v options under the uvmapping options.
Profile
Posted: 27 October 2012 04:03 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
ausair - 27 October 2012 02:39 PM
Wow…that’s a lot of work just to get a background image to model against.
Can’t you just flip/rotate the plane manually?
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 27 October 2012 04:09 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2009-09-16
Possibly (I’ve never tried it) but it is just as easy to hit he uvmap button and click the flip V or U
Profile
Posted: 27 October 2012 05:57 PM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
I guess I’m spoiled…in Blender, you can load the image directly.  No need to map it to a plane….and then it’s a simple slider to position/scale it.  And you can load the same image to all views or a different image to each view. Doesn’t get much easier than that…
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 27 October 2012 06:06 PM   [ Ignore ]   [ # 7 ]
Member
Rank
Joined  2003-11-09
actually Hex does *most* of that as well… you can directly upload images in hex, but it does not allow you to reposition them—it has one set position for each of the three views… you can upload three images, one for each view.
of course the other workaround in hex is to size/position your images in an image editor before you upload them—i’ve done this as well…
8)
 Signature
Profile
Posted: 27 October 2012 06:23 PM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2009-09-16
hiker_1 - 27 October 2012 06:06 PM
8)
I think it is more flexible to have you images on planes that you can move around to align the 3 views. The planes can be locked once positioned correctly.
Profile
