Digital Art Zone
How can I change the shader of the sub-parts of an object?
Posted: 26 October 2012 06:26 AM   [ Ignore ]
Member
Rank
Joined  0
How can I change all the sub-objects in an object tree to the same shader, without doing it one by one?
Is there a quick way to do it?
Thanks for any tip.
Profile
Posted: 26 October 2012 07:00 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
You can drag and drop a single channel shader onto the item, (each shading domain will highlight in red)
or,..
In the shader tab (list) you can drag a single shader, and drop it into a shader channel, then drag and drop that icon onto the next channel down until they’re all the same.
NOTE: If the shader is texture based,. then depending on the model, and the way it’s been mapped, applying the same texture to al pats may not produce what you expect.
it also helps if you say what model you’re working on.
Hope it helps smile
Profile
Posted: 26 October 2012 08:12 AM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  0
Thanks, I will try it.
grin
Profile
