Digital Art Zone
1 of 3
1
Question about morgue/mortuary sets
Posted: 25 October 2012 05:30 AM   [ Ignore ]
Member
Rank
Joined  2012-10-05
I’m looking at obtaining one or both of the two currently available morgue sets, the Eerie Morgue at Renderosity: http://www.renderosity.com/mod/bcs/eerie-morgue-poser-vue-obj-/59101 and the West Park Morgue (which means I’ll have to get the West Park Basement as well) http://www.daz3d.com/shop/west-park-morgue . I’d like to find a funeral home set as well but the only one I can seem to locate that’s currently available is the Old West Undertakers Interior: http://www.daz3d.com/shop/old-west-undertakers-interior which isn’t quite what I want.
My real question, though, is that both morgue sets, West Park and Eerie, look VERY grungy and rusty. Is there a reasonably easy way to alter/change/remove the mats on those props so as to take away the rust and dirt and make the tables, drawers, etc., look clean and shiny? (This question is actually applicable to any prop set that seems to have a dirty, disused look by default.)
Profile
Posted: 25 October 2012 05:55 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Yes, you need to use a paint program, such as Photoshop or Paintshop pro, or even Gimp, which is a free one, and make you own textures for them, if there is not already an addon texture pack available.
hopefull there will be a texture template for you to work from, the West Park morgue certainly has a template, it can be found under the resources tab on the product page.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 25 October 2012 11:44 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2012-08-31
HA! Shows what a dope I am. I thought you meant an illustrator’s morgue.
Profile
Posted: 26 October 2012 03:09 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2008-03-27
As well as using a paint program to make your own textures, you can directly apply shader presets to the surfaces.
You’ll need to obtain shader presets for the particular program you’re suing (i.e., Poser presets don’t work in DAZ Studio and vice versa). While the purchase of the presets is a bit of an upfront expense, you can then use them to retexture any other environments.
Calida3D is just one source of shader presets — they do both Studio and Poser presets.
Profile
Posted: 03 November 2012 03:21 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2012-10-05
I actually now have a second question, related to the request I put up in the Freepozitory a little while ago. I downloaded Karth’s free coffin model from ShareCG at http://www.sharecg.com/v/50162/gallery/11/Poser/Coffin , but I can’t get the materials to work properly. I’m certain that I unzipped all the files into the correct places into my Daz3D/Studio/My Library directory - I checked - but while the basic model and its accessories load just fine, I can’t change the mats/colors of anything. I select an object, click the corresponding mat in the “Materials” directory, but nothing happens; it stays the default color. Can somebody get this model, give it a try and tell me what, if anything, I might be doing wrong?
Profile
Posted: 03 November 2012 03:29 PM   [ Ignore ]   [ # 5 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
joea64 - 03 November 2012 03:21 PM
This item uses Poser Shaders for the Materials, those will not work in DS. Just looked for you. You can use any DS shaders you like to to get a look you like. Or try to make your own textures with the provided template.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 03 November 2012 03:36 PM   [ Ignore ]   [ # 6 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
I just Checked the Item folders. It does come with some Basic jpg textures you could load by hand.
 Signature
Profile
Posted: 03 November 2012 03:39 PM   [ Ignore ]   [ # 7 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
I take it you are using Daz Studio. I am checking it out now brb
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 03 November 2012 03:46 PM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2012-10-05
Jaderail - 03 November 2012 03:36 PM
I’m not sure how I could load those textures by hand, and I have no experience with creating textures, so I guess I’m stuck, at least for now. :\
Profile
Posted: 03 November 2012 03:47 PM   [ Ignore ]   [ # 9 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Szark - 03 November 2012 03:39 PM
OPPS!! It loaded just fine, for me, textures and all. I just read the Readme and assumed it was Shaders.
 Signature
Profile
Posted: 03 November 2012 03:52 PM   [ Ignore ]   [ # 10 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
joea64 What steps did you follow to install it?
 Signature
Profile
Posted: 03 November 2012 03:55 PM   [ Ignore ]   [ # 11 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
You are corect the Material presets will not load. You don’t need to creat textures as there are already made.
Jad it loads with one set of textures but the MC6 mats will not load no matter what I try and MC6 mats now work with Ds4.5
If you are using Daz Studio then select a section of the coffin, one at a time. It is split in to sections, pillow, base, left and right top. Then with a section selected go in to the Surfaces Pane and beside (our left) the Diffuse colour is a drop down arrow. choose Browse and naviagte to where the texture maps are installed. (that will be where you installed the Runtime). Select a map and repeat. You will have to play with the specular highlights etc to get them right for Daz Studio.
 Signature
Pete
My Render Thread
Profile
Posted: 03 November 2012 04:11 PM   [ Ignore ]   [ # 12 ]
Member
Rank
Joined  2012-10-05
Jaderail - 03 November 2012 03:52 PM
I unzipped the archive file (I use ALZip) and then copied the various directories to the correct places in the Daz3D/Studio/My Library/Runtime directory. It has files for the following subdirectories:
/geometries/Karth/Coffin
/libraries/Karth/Coffin
/readme/Karth/Coffin
/templates/Karth/Coffin
/textures/Karth/Coffin
Profile
Posted: 03 November 2012 04:16 PM   [ Ignore ]   [ # 13 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Libraries should have two folders Materials/Karth/coffin and Props/Karth/Coffin. But it looks right not a clue what happened on your PC.
TIP: It does look pretty good with some DS Shaders on it. Of course I have a pretty good collection of shaders.
 Signature
Profile
Posted: 03 November 2012 04:20 PM   [ Ignore ]   [ # 14 ]
Member
Rank
Joined  2012-10-05
Jaderail - 03 November 2012 04:16 PM
I actually wonder if there might be some files missing from the archive file I got from ShareCG. In the Textures folder, I have the following files:
black_cloth
black_pillow
red_cloth
red_pillow
test_cloth
test_coffin
test_lcoffin (for the left lid)
test_rcoffin (for the right lid)
test_pillow
wood_coffin
wood_lcoffin
wood_rcoffin
Does that match what you have in your own installation’s Texture folder?
Profile
Posted: 03 November 2012 04:22 PM   [ Ignore ]   [ # 15 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
All I did (I use Vista) was open the zip file, without unzipping, copeid the whole runtime, pasted that in to my content library, choose yes to merge the folder with the runtime that was there alreay and bobs your uncle.
 Signature
Pete
My Render Thread
Profile
1 of 3
1
