Digital Art Zone
1 of 2
1
PyCloid 0.2 beta available
Posted: 24 October 2012 03:25 PM   [ Ignore ]
New Member
Avatar
Joined  2007-09-21
The new release is available at http://www.f1oat.org/pycloid/index.html.
Many new features :
- particles collision with scene objects
- tube geometry along particle path
- fluid simulation
- isosurface geometry
- new sample files
- multi-core CPU support
Hope some CG artists will post very soon nice films done with PyCloid !
Frederic.
http://www.youtube.com/watch?v=tnNDJU8n17o
http://www.youtube.com/watch?v=8k6iVZlJLnM
Profile
Posted: 24 October 2012 04:48 PM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  2005-08-31
Frederic,
Any chance you’ll be creating a Mac version. I’d buy it in a minute!
Profile
Posted: 24 October 2012 06:11 PM   [ Ignore ]   [ # 2 ]
Addict
RankRankRankRank
Joined  2004-07-01
thank you !
Profile
Posted: 24 October 2012 07:14 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
yes thank you from me too smile
 Signature
http://andrewfinnie.blogspot.com.au/
Profile
Posted: 24 October 2012 09:52 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  0
Fredrick,
I have done some experimenting with your beta fluids. The fluid simulation works great, but had some trouble figuring out what what settings did what.
In the Isosurface tab, I found a radius adjustment, and in the fluid tab there is also a radius adjustment. In the radius adjustments, if I choose a setting much over 0.017 the particles disappear.
I did find that adjusting the viscosity all the way to 10.0 made the fluid smooth out much better. (lower viscosity = lumpier)
My render really doesn’t do justice to how good the water flow can look, but be assured, it works very well when animated !
I also found that the simulation does not reset to zero time when hitting the rewind button. To reset the simulation, rewind to 1-second, then to zero, or your animation render will show the last frame before starting the animation at frame zero.
(hope that made sense).
I need more time to play with it. wink
Image Attachments
Profile
Posted: 25 October 2012 01:52 AM   [ Ignore ]   [ # 5 ]
New Member
Avatar
Joined  2011-08-26
NICE!!!
Thanks a lot :D
Profile
Posted: 25 October 2012 10:40 AM   [ Ignore ]   [ # 6 ]
Active Member
RankRank
Joined  2012-04-01
Thanks again to f1oat for upgrading Carrara. Daz should hire you…
McGuiver, can you post a youtube clip of your fluid sim?
 Signature
Everything about Carrara: http://www.carraracafe.com/
Profile
Posted: 25 October 2012 11:10 AM   [ Ignore ]   [ # 7 ]
Active Member
RankRank
Joined  2006-08-21
Thanks, Frederic! Can’t wait to play.grin
 Signature
CG and Me
Profile
Posted: 25 October 2012 11:46 AM   [ Ignore ]   [ # 8 ]
New Member
Avatar
Joined  2007-09-21
Yes, there are many things to tune in the code, but as the pressure from users was high, I decided to release it !
The “Radius” parameter in “IsoSurface” tab applies only to rendering.
The one in “Fluid” tab is for fluid calculation only (SPH algorithm)
Both values should be similar, but I keep two different sliders to experiment.
IsoSurface applies to all PyCloid particles simulation, including those without fluid behavior.
Yes, there is something to fix for rewind function.
I have to update the PyCloid website with some docs about fluid.
What is difficult is to achieve stable behavior, with no “explosion”. That is managed by tuning all the parameters, including gravity, but I do not yet have a magic worflow for that ! Let’s experiment and share results.
Frederic.
McGuiver - 24 October 2012 09:52 PM
Fredrick,
Profile
Posted: 25 October 2012 01:13 PM   [ Ignore ]   [ # 9 ]
Active Member
RankRank
Joined  2012-04-01
Got a news post about PyCloid 0.2 here:
http://carraracafe.com/
http://carraracafe.com/?p=2336
And here:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2858450
 Signature
Profile
Posted: 25 October 2012 01:35 PM   [ Ignore ]   [ # 10 ]
Member
Avatar
Rank
Joined  0
3drendero - 25 October 2012 10:40 AM
Unfortunately, I can’t seem to get a YouTube account working….just keeps kicking me out ????
Here’s the settings I used for water. smile
Image Attachments
Profile
Posted: 25 October 2012 02:06 PM   [ Ignore ]   [ # 11 ]
Active Member
RankRank
Joined  2012-04-01
McGuiver - 25 October 2012 01:35 PM
Thank you for the screenshot.
Can you try Vimeo instead?
http://vimeo.com/
Supposed to be easy to use…
 Signature
Profile
Posted: 26 October 2012 07:16 PM   [ Ignore ]   [ # 12 ]
Member
Avatar
Rank
Joined  0
Attempting to imbed a video of second water test.
Edit:  Well….that didn’t work, I’ll try the url.
https://vimeo.com/52197357
Profile
Posted: 27 October 2012 08:22 AM   [ Ignore ]   [ # 13 ]
New Member
Joined  2005-09-19
Please mac version… please…
Profile
Posted: 27 October 2012 02:17 PM   [ Ignore ]   [ # 14 ]
Member
Avatar
Rank
Joined  2006-05-09
McGuiver - 26 October 2012 07:16 PM
Thats very cool!
Profile
Posted: 28 October 2012 01:07 PM   [ Ignore ]   [ # 15 ]
Active Member
RankRank
Joined  2012-04-01
McGuiver, crossposted on youtube for for, hope it’s ok, otherwise I will remove the it:
http://youtu.be/I2cpW-B04kc
Though I have no idea what tags to use to get the video embedded in the forum.
 Signature
Profile
1 of 2
1
