Digital Art Zone
Growing 3D Vines?
Posted: 23 October 2012 08:39 PM   [ Ignore ]
New Member
Avatar
Joined  2003-10-09
As I can achieve the same effect in Carrara Pro 8? Some of you already identified than I speak: http://www.videocopilot.net/tutorial/growing_3d_vines/
I want to do the same as 3D Studio but in Carrara 8 Pro.
is it possible, anyone know any tutorial or way of doing the same?
Well, in fact I need do a 3D ribbon “grow” like the sample of videocopilot, but straight, to use like break cut.
Profile
Posted: 24 October 2012 01:32 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
Hi Ruben
sorry fell asleep during the video but the answer is yes
carrara has a spline room
you should be able to do it if you read the m anual carefully
splines are also animatable so you can change the shape over time if you need to get them to look like they are growing
 Signature
http://andrewfinnie.blogspot.com.au/
Profile
Posted: 29 October 2012 10:11 PM   [ Ignore ]   [ # 2 ]
New Member
Avatar
Joined  2003-10-09
Thak you Andrew, I need to learn quick from some tutorial of you tube, and refine with the manual. Thank you again for the answer.
Profile
Posted: 29 October 2012 10:14 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
Hey Ruben pleasure !
Have you seen this plug in ?
http://www.daz3d.com/forums/viewthread/10339/
it was posted after I answered your question
looks good.
you could grow vines inside a transparent mesh by the look of it!
 Signature
Profile
Posted: 02 November 2012 07:15 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  2008-05-05
Have you considered these options:
1) Morphing vine that’s grouped with the camera.  As both advance, the vine morphs.  The ending could just have the vine extend farther than the camera.  EvilInnocence has some inexepensive vines & tentacles.  He also has a Poser plug-in that creates bones complete with an assortment of built-in morphs.
2) A really long vine that has a transparancy shader.  As the camera advances, adjust the transparancy. Shaders have an option for the x,y, & z axis.  There’s also a shader plug-in called Proximity, but it hasn’t been updated for Carrara 8 yet. Digital Carvers Guild might have something similar.  The Proximity changes a shader according to it’s location to an object or coordinate within the work space.
3) The spline object works as well.  Possibly more efficient when used with option 1.
Profile
